Go Back   Chevrolet Colorado & GMC Canyon Forum > Tech Area > Aesthetics > Audio/Multimedia
Old 03-17-2010, 10:35 AM   #1
It's not RED!
Nation Elite Contributing Member Calendar Spread NESM 09 NESM 10
Chris0nllyn's Avatar
Amp integration using stock radio
Putting a system in my truck and i need a 12v trigger for the amp turn on...i can't find anything. I tried doing the RAP mod that James did, but apparently in 08 there isnt a RAP/ACC relay or fuse or anything...any ideas?
November 6, 2010 Cap Chap meet at Buffalo Wild Wings Dover, DE:
http://www.355nation.net/forum/north...-6-2010-a.html
Capital Chapter
Chris0nllyn is offline   Reply With Quote
Old 03-17-2010, 11:05 AM   #2
The Wise OWL.........
355Nation Admin Chapter Founder Nation Elite Lifetime Contributing Member Nation Vendor SuperMeet Organizer Nation Advocate Calendar Spread MTS Good Samaritan NESM 08 NESM 09 NESM 10
Send a message via AIM to Supermodulation
Re: Amp integration using stock radio
Try tapping off of your sun roof fuse for the RAP signal.
You may want to go through a relay to isolate any feedback from the sun roof motor or prevent over loading the SR circuit.
Old 03-17-2010, 11:21 AM   #3
It's not RED!
All the fuses i tested were hot all the time...i even tried the sunroof...I'm wondering if the BCM is controlling everything.
Capital Chapter
Old 03-17-2010, 11:40 AM   #4
For 2008's the RAP relay is # 58.
Tap off of your Power Window fuse # 42. Located at the top right of your fuse box, second one down. It should be a square 30 amp fuse.
Old 03-17-2010, 11:44 AM   #5
It's not RED!
I'll double check when i go to lunch...thanks James!
Capital Chapter
Old 03-17-2010, 01:06 PM   #6
It's not RED!
Found the relay and fuse...guess I was a little tired last night and looked right over it...I'll probably get to wiring it up this weekend
Thanks again!
Capital Chapter
Old 03-17-2010, 09:18 PM   #7
Honorary Cap Chap Member
TOTM Winner Nation Elite Contributing Member SuperMeet Organizer Calendar Spread NESM 09 NESM 10 MESM 10
rkramer19's Avatar
Send a message via Yahoo to rkramer19
Thanks again!
you can always go to the ignition wire on the steering column, its easy to get to and you know it will work
http://www.355nation.net/forum/image.php?type=sigpic&userid=2633&dateline=1264855  980
Originally Posted by Freewood View Post
I want a g/f who lets me beat off on her food. I knew a lady like that who liked eatting her pizza with jizz.
rkramer19 is offline   Reply With Quote
Old 03-18-2010, 08:24 AM   #8
It's not RED!
Yea, im sure...but I really dont want to be poking around wires dealing with the ignition...This truck is my daily, I've learned all my lessons the hard way, and I don't feel like learning another
Thanks though!
Capital Chapter
Old 03-18-2010, 02:00 PM   #9
You could alternatively tap the Ignition fuse rather than the wire.
Tyson is offline   Reply With Quote
Old 03-18-2010, 02:03 PM   #10
It's not RED!
Yea, I'll figure something out...I won't be able to get to it until this weekend (hopefully) So I'll check back in when i get it done. Thanks for the suggestions!
Capital Chapter
Old 03-18-2010, 02:48 PM   #11
MESM 10
07ColoradoBLK's Avatar
you should do a HOW TO . write up with pictures. !!
facebook
'07Colorado Z85 LS
07ColoradoBLK is offline   Reply With Quote
Old 03-18-2010, 02:56 PM   #12
It's not RED!
I was thinking about it....may as well. I always seem to forget my camera...lol
Capital Chapter
Old 03-18-2010, 03:48 PM   #13
MESM 10
Awesome cause im considering throwin a system that i had laying in the garage in but dont know how to hook up 2 factory radio. Or if i want to just yet. Oldskool subs and 13year old amp .
facebook
'07Colorado Z85 LS
Old 03-18-2010, 03:49 PM   #14
It's not RED!
K, well I wanna see how the stuff i got works then I'll let you know...But i'll def take some pics
Capital Chapter
Old 03-18-2010, 03:53 PM   #15
MESM 10
Thanks bro. Where you gona mount yer stuff i was thinkin takin out the seat behind my driverseat and puttin a box there with either one 10 or a 12 idk yet
facebook
'07Colorado Z85 LS
Old 03-18-2010, 04:55 PM   #16
It's not RED!
I got a box for 2 8's from a member on here who got it from a guy on ebay that goes under the back seat...not sure about my amp yet...its so small i may put it under my driver seat.
I mounted my line level converter behind the radio and i'm also running basically a bass knob for line level in my glovebox....all stealth!
Capital Chapter
Old 03-23-2010, 10:24 AM   #17
It's not RED!
Got it working last night...actually suprised me how well it sounds...especially for having a stock radio.
Heres the run down of my setup:
PAC SNI-35 line level converter
PAC LC-1 Bass control knob
Some old ass 150w amp i had laying around (mounted under the seat)
Rockford P1 8"
Ebay box that goes under the seat for crew cabs
For anyone wanting to do this: you'll need an amp turn-on wire (remote turn-on)...i got a "Tap-a-fuse" from the local parts store and tapped off the IGN fuse...it should have a 15 amp fuse in it...put that back in th spot closest to the prongs and use a 5A for the amp turn on wire.
Capital Chapter
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
