Routing speaker wire in crew-cab... also into doors? - Chevrolet Colorado & GMC Canyon Forum
Go Back   Chevrolet Colorado & GMC Canyon Forum > 2004-2012 Chevrolet Colorado Forum / GMC Canyon Forum - First Generation Tech Area > Aesthetics > Audio/Multimedia
Old 08-03-2012, 03:25 PM   1 links from elsewhere to this Post. Click to view. #1
Rick_crew's Avatar
Where / how is the best route to run speaker wires from under the rear seat to the front doors?
Under the cab inside the frame rails? Inside under the carpet?
Also, has anyone managed to run speaker wires into the front doors without removing the door from the hinges?
Maybe by using the factory speaker wire as a pull-wire I'm guessing?
Thanks for any experience you can share.
-355 Sport Touring edition-
"Whoever looks upon them as an irregular mob will find himself much mistaken. They have men amongst them who know very well what they are about.."
-Lieutenant General Hugh Percy of Britain regarding the American patriots following the battle of Concord, April 1775.
Rick_crew is offline   Reply With Quote
Old 08-03-2012, 03:56 PM   #2
Military Service  TOTM Winner  Nation Elite  How-To CM  100K  USASM2012  NESM 2013  SESM 2014  Skunkwerx Super Mod Meet 2015
gway's Avatar
Re: Routing speaker wire in crew-cab... also into doors?
I dont know about running the wires through the door but i believe it'd be easier to run it under the carpet instead of outside the truck. It you find out how its routed through the door if you can i'd try and cut the wires and take the new wires to them and then pull them through with the old wires. Just a thought.
SAS with 4.88 and 37s 1/2 ton suspension
5speed to auto swap: done
Np241 tcase swap: done
Bored over 3.7 swap: done
Next up: 6.0l giggidy
My truck is going through an identity crisis. I keep trying to tell it to stop thinking it's a h3.
gway is offline   Reply With Quote
Old 08-03-2012, 04:02 PM   #3
355 Parts Hoarder
355Nation Moderator  Nation Elite  Contributing Member  How-To CM  SuperMeet Organizer  Calendar Spread  MTS  Skitz Award  NESM 09  NESM 10  NESM 11  NESM 2013
comdrop9073's Avatar
Under the carpet to the door sill molding (Just pull up on it, It will come off), to the kick panel. Use a long skinny zip tie and try to fish it through the tube where the wires run from the body to the door. If you get the zip tie through, electrical tape the wires to it and pull them through.
-Dave
comdrop9073 is offline   Reply With Quote
Old 08-03-2012, 04:06 PM   #4
vanillaone86's Avatar
using stock wires as a pull wire sounds like a good idea. Not sure how it works in practice but let us know what you end up doing.
Throttle causes and fixes all your problems - some wise guy
vanillaone86 is offline   Reply With Quote
Old 08-03-2012, 04:14 PM   #5
Traditionally you'd run it through the door sills, pull up the kick plate that you step on when you enter the vehicle.
Make sure you run your signal wires from your HU to your amp away from the battery power feed.
Old 08-03-2012, 06:00 PM   #6
How-To CM  355Loyalty  100K  SESM 2013  SESM 2015
FlyingTomato's Avatar
Remove the door sills and the interior trim pieces, pull your carpet up a little(depending on where this wire is coming from under the seat, you may need to loosen the bolts or remove the back seat) run the wire under the carpet/door sills to keep it hidden. Open the desired door, and pull the rubber boot back. Run wire up to and through the boot(which can be a bit of a pain). Mission accomplished!
FlyingTomato is offline   Reply With Quote
Old 08-03-2012, 09:51 PM   #7
CUZICAN's Avatar
I thought these trucks had male/female plugs on the door harness that would make pulling wires through impossible without poking a hole.
I'm a responsible adult, whenever anything goes wrong, I'm responsible.
Old 08-04-2012, 01:52 AM   #8
Military Service  Lifetime Contributing Member  Public Service  100K  WCSM 10  WCSM 2014  WCSM 2015
BigR's Avatar
They do so what I did was drill a hole in the plug and ran the wires through . As for pulling the wires without removing the front doors I couldn't get it done so I pulled the doors. It was pretty easy but you need a helper.
Here is a few pics of how I did it.
What I Am Doing Today Is Important, Because I Am Exchanging A Day Of My Life For It.
07 Chevrolet Colorado Crew Cab 2WD Victory Red 3.7L I-5
BigR is offline   Reply With Quote
LinkBack to this Thread: http://www.355nation.net/forum/audio-multimedia/57054-routing-speaker-wire-crew-cab-also-into-doors.html
Thread front driver door speaker wire color? | Chevrolet Colorado and GMC Canyon Forum | BoardReader This thread Refback 09-18-2012 08:09 PM
