installing fog lights - Chevrolet Colorado & GMC Canyon Forum
Old 02-05-2011, 12:47 PM   #1
Nation Elite  Calendar Spread  355 Celebrity  100K  MESM 11
BLUE STEEL's Avatar
hey guys, gonna b installing my fog lights i got from jesse, they came wit brackets and bulbs, plus for me.
but no harness, what bulb harness do i need? gonna do that mod where they go on when the drls come on. seen that how to. i wanna do that, just need a better how to do the wiring aspect of it. ie... how to wire up the fog light wires, and where do i bypass them to
can sum1 help??? can xplain better over phone 2199512068 javier
if not can do it thru here,
3/4" drop
18" titans
forward tilt hood
Originally Posted by AceX View Post
I just realised that if this forum were an actual room, most of us would walk in, take inventory of the group and think to ourselves, "Sausagefest." Then leave without saying anything.
R.I.P FORREST
BLUE STEEL is offline   Reply With Quote
Old 02-05-2011, 01:09 PM   #2
BLUE STEEL's Avatar
Re: installing fog lights
anyone???
3/4" drop
18" titans
forward tilt hood
R.I.P FORREST
Old 02-05-2011, 01:31 PM   #3
Monkey Slut!
TOTM Winner  Nation Elite  Contributing Member  SuperMeet Organizer  Calendar Spread  355Loyalty  100K  WCSM 10  SCSM2012  SCSM 2013  SCSM 2014
Jesse's Avatar
I would suggest you go to the junk yard and clip the plugs off of another Colorado and hard wire them on a switch.
#Loser!
# @ivan29
Jesse is offline   Reply With Quote
Old 02-05-2011, 01:35 PM   #4
MESM 11
Jlemm's Avatar
Send a message via AIM to Jlemm
I ordered new fog lights for my bro's lancer, they came with wire and a switch that I'm not using, I could sell you them?
Jlemm is offline   Reply With Quote
Old 02-05-2011, 01:49 PM   #5
BLUE STEEL's Avatar
would i be able to jump/splice the fogs to the drls??? if i find sum harnesses, splice into the drl lites?
3/4" drop
18" titans
forward tilt hood
R.I.P FORREST
Old 02-05-2011, 01:53 PM   #6
Contributing Member  MESM 15  TXSM 11
vakeromx's Avatar
i think thats possible. you will only need a relay.
your truck is gonna look really good!
RIP SKITZ
vakeromx is offline   Reply With Quote
Old 02-05-2011, 01:59 PM   #7
Nation Elite  SESM 10  TXSM 11
TomD's Avatar
I went to advance auto and got some 9005 bulb connectors (real cheap) and then tapped it into my radio. The reason I tapped I into my radio is because I wanted to make sure that if I left the switch on, the fogs still turned off when I turned the truck off. All the materials to do this cost me around $20 I think.
Just trying to help
TomD is offline   Reply With Quote
Old 02-05-2011, 02:00 PM   #8
BLUE STEEL's Avatar
i kno advance sells headlight harnesses wit the 3 wires, how do i kno which wire goes to which wire??? think theyre brown,black,blue if im not mistaken, thats what i need help wit. ill splice em into the driving lites when they come on the fogs wil also
3/4" drop
18" titans
forward tilt hood
R.I.P FORREST
Old 02-05-2011, 02:02 PM   #9
BLUE STEEL's Avatar
yeah i kno, but they have 3 wires on them"harness: idk what wires/colors are ground,hot,etc???
Just trying to help
3/4" drop
18" titans
forward tilt hood
R.I.P FORREST
Old 02-05-2011, 02:03 PM   #10
BLUE STEEL's Avatar
tryin to holmes, tryin to
3/4" drop
18" titans
forward tilt hood
R.I.P FORREST
Old 02-05-2011, 02:03 PM   #11
IF you just want them goin on n off with teh DRL's all you have to do is tie them into it man. Simple as that. Then run a ground wire from them to the frame. They will turn on n off with teh drl's that way. IF you want a switch, then you will need to run a single hot wire from the battery to the cab. Then run a wire from the cab to the lights. You can run both lights off one 14awg wire. Now, after you do that, wire a ground wire close to the lights, and your done. Make sure you insatll a fuse as close to the battery as you can to protect ALL your wiring. have any issues bro, you know my number...
Old 02-05-2011, 02:04 PM   #12
The switch is gonna have two or three terminal's or more depending on how many things you want it to run bro...if you want it coming on n off with teh drl's lik eyou said, then you wont even need a switch at all.
Old 02-05-2011, 02:09 PM   #13
TomD's Avatar
I think mine only had 2 wires coming out of each plug. We may be talking about 2 different things
Old 02-05-2011, 02:09 PM   #14
CUZICAN's Avatar
I personally would not put all of that extra load on the DRL circut. You'll want to use a standard bosch style relay for this. I don't have a relay in front of me to look at, at the moment, and I don't remember off the top of my head which terminal is which on the relay, to tell you how to wire it up, but when I get home I can give you the whole rundown on it.
I'm a responsible adult, whenever anything goes wrong, I'm responsible.
Old 02-05-2011, 02:11 PM   #15
CUZICAN's Avatar
Tom you are correct, he is looking at the drl plug. It has three wires: + for running and blinker and a common - if I remember correctly, but it could be the other way around. The plug for the 9005 will only have two wires, a + and a -.
Old 02-05-2011, 02:11 PM   #16
BLUE STEEL's Avatar
yeah, i dont wanna switch, think it looks cheesy... so gonna sound funny, i kno about ground wire to the chassis. what bout the other 2 wires? hard wire those to the drls???
3/4" drop
18" titans
forward tilt hood
R.I.P FORREST
Old 02-05-2011, 02:14 PM   #17
BLUE STEEL's Avatar
these fogs i got from jesse have 9045s in them, ddoes that make a difference? could i switch bulbs to do a different bulb?
3/4" drop
18" titans
forward tilt hood
R.I.P FORREST
Old 02-05-2011, 02:14 PM   #18
TomD's Avatar
Ok thanks for clearing that up.
Old 02-05-2011, 02:21 PM   #19
CUZICAN's Avatar
No, the plug for the 9005's will work.
Old 02-05-2011, 02:25 PM   #20
BLUE STEEL's Avatar
hey cruzican, so i run a 9005 harness, ideally i could run a 9005 bulb then.. correctly
3/4" drop
18" titans
forward tilt hood
R.I.P FORREST
