| Premium Member | HELP! Passlock
EDIT: THIS ISSUE HAS BEEN RESOLVED, CHECK POSTS BELOW! YOU DON'T NEED TO BUY A BYPASS MODULE (04-07 confirmed) So I had an alarm with remote start installed yesterday ( crimeguard 810i6, and I think the installer used a dei passlock bypass ). It's great, and now I can unlock the passenger door for my wife without running around to the drivers side to unlock everything. When I left the installer, everything worked fine. This morning, I hop in the truck, put the key in and the truck just cranks, and won't catch. The car w/ padlock indicator shows up on the dash. I had to ride my bike to work, and have yet to call the installer ( they open in about half an hour ) Any ideas?
__________________ "Make it idiot proof and someone will make a better idiot." Last edited by vf1kf; 03-01-2011 at 12:52 PM. |
| Nation Citizen | Re: HELP! Passlock
happened to me too, after 4 years of getting the alarm installed though. i think the passlock is bad? I just got the remote start disconnected and it's been working fine? |
| | #3 | |
| NW Surfrider | Re: HELP! Passlock
Try a relearn cycle. on 10 minutes, off 10 minutes, On.
__________________ ![]() Quote:
| Premium Member | Re: HELP! Passlock
I'll try the relearn. Does anyone here belong to the dei website? I'm trying to get a copy of Directed Doc 1603 I have the audiovox equivilant, I just want to have all the possible info when I go back to the installer.
__________________ "Make it idiot proof and someone will make a better idiot." |
| Nation Citizen |
Don't take it to the dealer they'll just give you a new battery and say it's fixed... Also charge you out the ass for the battery
| | #6 | |
| Premium Member | Re: HELP! Passlock Quote:
__________________ "Make it idiot proof and someone will make a better idiot." | |
| Nation Advocate Join Date: Dec 2009 Location: .
| Re: HELP! Passlock
so how do u fix this problem? i will be gettting new alarm as well, and dont want that to happen to me.
| Nation Citizen | |
| Re: HELP! Passlock
alright i wont
there seems to be a simple passlock wiring workaround using two relays and a resistor to match the key cylinder's resistance. I'll show it to my installer this afternoon and see what he thinks. https://docs.google.com/viewer?a=v&p...thkey=CMPOrvAG Has anyone tried this?
__________________ "Make it idiot proof and someone will make a better idiot." Last edited by vf1kf; 02-22-2011 at 04:19 PM. |
OK, so I wasn't able to get the truck back to the installer yesterday. I blew out my rear tire on my R6 doing 80 on the freeway...and spent all night getting it back home. On an upbeat note, while the remote start sets off the passlock, if I wait 15 minutes, I can start the truck with the key again...so I am once again mobile. After hours of research, I believe I understand the problem with passlock bypass modules and our trucks. The 04-07 Collolado, Canyon, and H3 all have a BCM voltage stabilization issue. For up to 10 seconds after the car is turned on the voltage in the BCM does not stabilize ( not everytime, just sometimes, like after the truck has been sitting in the cold all night ). The passlock unit is programmed to match the resistance of our ignition switch, but with varying voltage, the IC in the modules fails to do so accurately enough to fool passlock. The link I posted above resolves this issue by simply using a resistor ( not an IC ) that matches the ignition switch values. I will see if this theory holds true this weekend. Thanks for all your input, I'll keep this post updated.
| | #12 | |
| New To The Nation Join Date: Jul 2010 Location: Windsor, Ontario Canada
Make sure all connections are soldered and good ground location also if your by-pass needs to be flashed make sure it's the latest firmware. | |
| | #13 | |
I believe the i-datalink module's current firmware revision deals with the BCM voltage stability issue. My installer insisted on using the dei module ( I supplied the idatalink at the recommendation of this forum, they didn't want it )The following was taken from a post on chevroletforum.com: http://www.chevroletforum.com/forum/...ad.php?t=30139 Quote:
__________________ "Make it idiot proof and someone will make a better idiot." Last edited by vf1kf; 02-23-2011 at 05:19 PM. | |
| | #14 | |
| | #15 | |
Interesting. Glad you found a solution. Also seems this would make it easier for more members to install remote start in their vehicle as well.
| Nation Affiliate Join Date: Feb 2010 Location: Just Moved to the Pacific NorthWest from Miami... What was I thinking?!?!?! Seattle
| Re: HELP! Passlock
I used the flashlogic module that best buy has ($100) and no issues. I think you have to have them flash the module with the right software, they did mine for my 06 with no issues.
| Nation Citizen | How long have you had the remote start? Mine didn't start acting up till like 3 years of having it.
| Member's Technical crew | Re: HELP! Passlock
I can look tomorrow on the bypass module? I used it has been working fine since about 2007 I installed it my self, never a problem, only shortly after the install I had the light come on because my tach wire signal pulled out and it over cracked, then the security light came on, after I fixed that been fine I would take it back to the alarm installer and tell them to fix it! They may not of calibrated the module correctly. I think you are right in the fact the the resistance is based off voltage, the installer probably wore down your battery during testing and installation set the bypass module to learn off the lower voltage, after you charged the battery (engine running), you now have the wrong Resistance. Take the truck back and get a relearn done on the bypass module for free!
__________________ ![]() "Like A Rock" HP tuning at efituning BC R.I.P 2004 Chevrolet Colorado reg cab Victory Red ZQ8 2.8L/4.8L 5spd Imported 2004 Chevrolet Colorado LS reg cab Victory Red ZQ8 3.5L Auto |
| | #19 | |
![]() FYI: How to Calculate Resistors. Resistors in Series: When connecting resistors in series, simply add the values to get your total resistor value: Resistor Total (Rt) equals Resistor #1 (R1) plus Resistor #2 (R2) and so on... Rt=R1+R2.... So if you put your resistors in series, you would end up with: Rt=2700+27000 Rt=29,700 ohms or 2.97 kohms Resistors in Parallel: A little more tricky, you have to calculate the reciprocal number of the resistor value: 1/Rt=1/R1 + 1/R2 and so on... Again, if we use the above resistor values, we would have: 1/Rt= (1/2700) + (1/27000) 1/Rt= 0.00037037 + 0.000037037 1/Rt=0.000407407 To find out your total resistor value, enter 1 divided by the total decimal number into your calculator. Rt= (1 / 0.000407407) Rt=2,454.547909 ohms rounded off to 2,455 ohms. I know this is a bit off of the mechanics side of things, but it might help someone to figure out what resistors they need to bypass the passlock security system.
__________________ "Make it idiot proof and someone will make a better idiot." Last edited by vf1kf; 03-01-2011 at 12:50 PM. | |
| | #20 | |
| Member's Technical crew | Re: HELP! Passlock Quote:
__________________ ![]() "Like A Rock" HP tuning at efituning BC R.I.P 2004 Chevrolet Colorado reg cab Victory Red ZQ8 2.8L/4.8L 5spd Imported 2004 Chevrolet Colorado LS reg cab Victory Red ZQ8 3.5L Auto | |
