My truck just started to exhibit the common PassLock symptoms. Cranks and cranks but no start with the security red light flashing on the dash. It did this to me Monday and almost made me late for work.
From my understanding and reading around between CF and here is that it will get progressively worse.
I found this How To in CF and it has great info on how to fix this the right way. I take no credit for this as it was not done by me.
Pass Lock How To: Ignition - Chevy Colorado & GMC Canyon
Also from what I have been reading is that there are like 15 different passlock modules that can be purchased and all have different resistive readings that it sends back to the BCM.
Ideally you should be able to take a DMM to your wires from the passlock and read what your particular passlock modules resistance reading is and match it up to one of the 15 available replacements. That would make it a plug and play installation without having to do a Re-Learn.
In the above How To link it states that you have to go to a dealership to get it reprogrammed. Is that not the same as doing a Re-Learn on your own?
I'll probably get around to doing this once my passlock starts acting up more since its only done it once to me. Any thoughts?
