Window won't work! - Chevrolet Colorado & GMC Canyon Forum
Old 03-16-2012, 11:24 PM   #1
GMInlinePower's Avatar
Question Window won't work!
I was playing with my speakers today and went to put the door panel back together, that went fine, but when I tried the window it wouldn't work; door look switch either. This has happened before, but I tried everything I can think of; resetting the bcm by pullin the neg on the battery, I also pulled the switch assembly plugs back out and plugged those back in to see if this would work(it has before) but I got nothing.
Any help would be greatly appreciated.
Thank you in advanced.
GMInlinePower is offline   Reply With Quote
Old 03-16-2012, 11:28 PM   #2
Est. 1992
Lifetime Contributing Member  How-To CM
Colorado Kowalski's Avatar
Re: Window won't work!
I've been having this same issue off and on for quite sometime... tried EVERYTHING... it has now been not working for about a month.. seriously about to convert my drivers side door from power to crank lol
2004 Chevy Colorado z71 4x4 - SOLD
Colorado Kowalski is offline   Reply With Quote
Old 03-16-2012, 11:43 PM   #3
It's just so stupid how it won't reset when I try pulling things on it and plugging them back in
Old 03-16-2012, 11:59 PM   #4
Est. 1992
i hear yah man
Old 03-17-2012, 12:02 AM   #5
Have you thought of any ways to make it work?
Old 03-17-2012, 12:16 AM   #6
Est. 1992
no and I've tried every suggestion I've heard... GM dealer might be my next stop but they're probably gonna wanna charge a shit ton of money thats why i might just convert my drivers side window to manual crank lol because i really don't care that much i just want to be able to put it down
Old 03-17-2012, 12:17 AM   #7
chevy911's Avatar
check the fuses? i had the same issue and it was a fuse
06 colorado 5cyl crew cab 4x4
http://tatcave.net
chevy911 is offline   Reply With Quote
Old 03-17-2012, 12:22 AM   #8
I'm thinkin that's what I might be this time because it won't reset like it normally does. I'll check them in the morning
Old 03-17-2012, 12:40 AM   #9
Military Service  Contributing Member  How-To CM  SuperMeet Organizer  Calendar Spread  355Loyalty  100K  SESM 11  SESM 2013  SESM 2014  SESM 2015  SESM 16  CFSM 2016
DigEm's Avatar
Guys, no reset will happen with just pulling the negative, got to pull both cables, BEFORE, you unplug any harnesses, and plug the harnesses back in before you put the battery cables back on. Then make sure that you put the negative back on first then the positive. Also remove the negative first. Make sure you have them both off the battery at least 45 minutes to an hour. I had the same issues you guys are having and this solved my problems. I got it from the tech at the local chevy dealer.
DIG EM
2005 Colorado Z71 2WD
DigEm is offline   Reply With Quote
Old 03-17-2012, 12:51 AM   #10
yup pull both connections from the battery touch them together and leave it like that over night so it drains the capacitor then hook them back up in the morning and give it another go.
Also make ure the pins in the connector for the door switch are properly seated.
Old 03-17-2012, 12:53 AM   #11
Doing that won't hurt anything?
Old 03-17-2012, 01:52 AM   #12
No only if you touch the terminals together with voltage hooked up to them. If they are both off and away from the battery it just pulls the voltage from the capacitor in the computer and grounds it. If you just pull one terminal off the battery the capacitor keeps the memory working so you want that capacitor drained so the memory is reset fully.
Old 03-17-2012, 09:53 AM   #13
Oh, ok; that makes sense.
Thank you for the help!
Old 03-17-2012, 04:36 PM   #14
It works again!
Old 03-17-2012, 05:48 PM   #15
chevy911's Avatar
What was it?
Sent from my Desire HD using AutoGuide.com App
http://tatcave.net
Old 03-17-2012, 06:07 PM   #16
Bcm, I unplugged it and went for a drive, shut tw truck off started it back up a couple hours after that and everything was back to normal.
Old 03-23-2012, 07:48 AM   #17
SuperH's Avatar
Send a message via ICQ to SuperH Send a message via AIM to SuperH Send a message via MSN to SuperH Send a message via Yahoo to SuperH
This happened to my mom's truck, also, a couple of years ago.
I hate our BCMs.
SuperH is offline   Reply With Quote
Old 03-23-2012, 12:01 PM   #18
xkmacx86
TOTM Winner  Nation Elite  OG Lifetime Contributing Member  How-To CM  SuperMeet Organizer  Calendar Spread  Skitz Award  100K  USASM2012  WCSM 10  WCSM 2014  WCSM 2015
BADLANDER's Avatar
this
BADLANDER is offline   Reply With Quote
Old 03-23-2012, 12:05 PM   #19
This was all resolved after talking to a friend of mine who is a retired GM warrenty person, he seems to know every code there is out ther with every symptom. I give him the problem(s), he replies with the exact answer and fix.
