| Nation Affiliate | oil change question Does our truck really need synthetic oil? I know a lot of ppl here using synthetic oil cuz its not that expansive compare to regular oil. but is it really necessary? whats the downfall for using regular oil? |
| Kentucky 295 Canada 205 | Re: oil change question this is why I use it............no work done to a 8.1 2001 3500 hd only used Mobil 1 synthetic in it
__________________ -Cowan Order DRL covers here > http://www.355nation.net/forum/class...rl-covers.html |
| Nation Affiliate | Re: oil change question |
| Kentucky 295 Canada 205 | Re: oil change question hahaha, that is on a truck used for hauling cars at the dealership. I have 146K + on my 04 right now and use only Mobile 1 syn.
| Nation Affiliate | Re: oil change question how about the oil filter? Do I need to get synthetic oil filter as well? |
| Nation Elite | Re: oil change question i get it all yeah i fork over like 50bucks give er take $$ that price. to get the best Mobil 1 fullsynth.. with the mobil 1 extended performance filter. cause everytime i change my oil its still clean looking.usually. but i dont have to change mine for like 7k with the extended performacne stuff i got on sale when i changed myoil the last time it was 1/2 off. ' i used to use synthetic blend and the motor would just hessitate . now it screams. but tis still slow. |
| | #7 | |
| Nation Elite Join Date: Sep 2007 Location: canton , MI
| Re: oil change question Quote:
Wait for the light on the dash to say its time . Right now there about 16,000 on the oil. This is my third change and I got 56,479 right now. Your truck will start a lot better in the winter. oldman (MI.)
__________________ 2004 Canyon Z-71 Ext Cab SLE 3.5 auto 3.42 gear Michigan 355 63,000 miles | |
| Nation Citizen | Re: oil change question that is A LOT of miles! |
| Nation Elite | Re: oil change question /shrug The I5 is a temporary thing, in my mind. I use "cheap" Castrol GTX. I'm at 90k miles, and the engine has never so much as made a burble that I didn't like. Everything I've had problems with (very few things, btw) have been accessory issues that engine oil has nothing to do with.
__________________ - Jody - |
| Nation Advocate Join Date: Apr 2009 Location: Marysville, WA
| Re: oil change question Not so much emphasis as to what type of oil you use but rather how often you replace it. Using reg oil can be just as good if you replace it on a regular basis (3,000mi). |
| Nation Affiliate | Re: oil change question Please do not post bad information. Thank you. Use a filter that is made to last longer for sythetic oils. |
| Nation Affiliate | Re: oil change question Again, bad information. Synthetics are much better for your engine and seals than conventional oil. Please research this stuff, then come back. |
| | #15 | ||
Synthetic oils protect your engine better over the projected life of the oil. If you were to compare the two oils up to even 8k miles, syn wins right? (protects longer & better over that period than con.) But if you're on a reg. maintenance routine, is the added benefit of dumping that $40.00 dollars worth of oil (5 x $8.00) every 3k worth the added life & protection in such a limited amount of time compared to reg. old con. oils? That's where we all have to be the judge & weigh cost vs. benefit. My filter response was assuming he was replacing his oil (whether syn or con.) every 3k in which, no, he would not need a longer lasting filter. Again, opinions are that of the beholder. But a routine maintenance schedule should always be taken into account when talking about what's better & what's not. Last edited by 88_Train; 11-08-2009 at 01:52 AM. | ||
| | #16 | |
| Nation Affiliate | Re: oil change question Quote:
| Re: oil change question Do the math - if you get the filters for $5.00 each and your oil is $2.00 a can = $15.00 and you do the dirty work . At 24,000 miles you spent $75.00 on 5 oil changes... My way, 5 filters ($25.00) and two jugs of M1 @ $19.95 ($39.90) . $64.90 at this point. Now for the next 5 changes it coast you $75.00 again and me $25.00 plus 2 qts of Mi at $5.75 each , cost to me of $36.50 .( save money buy the jug )... oldman (MI.)
| Old Guy Join Date: Apr 2007 Location: Orange Ct.
| Re: oil change question I thought we need 6 quarts of oil? |
| New To The Nation Join Date: Jan 2009 Location: Kansas
| Re: oil change question Synthetic oil must be better just pop the hood on any newer Corvette or like the 2005 GTO I used to have with the LS2 or LS3 engines and right on top of the oil cap it says Mobil 1 Synthetic Oil |
| Re: oil change question you right , the tv adds say oil change for $14.95 plus tax . I do 5 and 1/3 qts on top and 2/3 in the filter. Never start with a dry filter...
