Anyone remove the intake manifold?
48K views 54 replies 20 participants last post by  FlyingTomato
My starter needs replaced and I think the only way I can get it off is taking off the intake manifold like the service instructions say. I tried getting it out with out doing it and I got the bolts out but cant get the starter off. Anyone ever do this? Is it very hard? All I would have to worry about is replacing the gasket right?
#2 ·
There are a few that have, I guess its a bitch. I know that does not help though.
I would recommend replacing the gasket though. Let me see if I can find someone that knows.
#4 ·
No gaskets, it uses o-rings. They shouldn't really need replaced if you don't damage them. Personally I would recommend removing the bolt for the driver's side engine mount and using a hoist to raise that side of the engine up a couple inches. That's how I removed mine. :shrug:
#5 ·
Thanks Don, I was hoping you would pop in here!
#10 ·
I don't remember anything particularly complicated about it other than it's just a whore to get to some of the bolts. There's no way to get the starter out from underneath? I haven't looked too closely at it.
#13 ·
And we thank you Chris!
#28 ·
with the fender wells in, it would be a task getting it out. I still can't get it yet with my fender wells out. taking the plastic off wont do much to help I don't think. You would be best taking off the intake or finding a friend with a hoist or buying/making one. There not THAT expensive. BTW dealership wants a grand to change it.
#30 ·
If you don't have a hoist you might be able to get away with a jack under the oil pan to lift the engine a little, you'd have to be careful though and I'd recommend something between the jack and oil pan to make sure the weight is distributed evenly across the bottom of it. You mainly need to pay attention to the passenger rear of the engine when lifting up the driver's side, make sure you don't crush anything into the firewall. It doesn't make it a cakewalk to get the manifold out but it gives you a couple extra inches to get your hands/ratchet in there so it doesn't seem impossible at least.
I guess now that I think of it the engine block sticks out from that side blocking access to the starter from underneath. That's the side of the engine that the balance shafts are on.
#31 ·
holy shit $1000 to change a starter!!!! thats total nonsense! the one on my cherokee shit out every 6-10 months i had to do it 3 times! it was done without even a jack though lol just crawl under, drop it down, install new.
thats insane.... guess if i have to do this i'll be trackin down a buddy and a haynes repair manual.
