Go Back   Chevrolet Colorado & GMC Canyon Forum > Tech Area > Engines/Performance/Tech Questions > Engine & Drivetrain
Old 07-29-2010, 10:48 PM   #1
Radiator fluid amounts question
Ok. So I feel like an idiot but need to know whether I have made a mistake. So I drained my radiator and flushed it 2 times. I go to add in the new Dexcool. First gallon 100% goes in. So I feel the gallon jug back up with pure water. I am pooring it in and only get half of it in and its full. So I crank up and the fluid does not go down any. So I drive around the block mean time the temp gauge gets to normal operating status. I chill out for a minute and check the fluid level hoping it has went down. I am under the impression that I have to put 2 gallons and then some in. As of right now I have 1 1/2 gallons in. Will the fluid level go down some so I can put the remainder in there? Or is there an air lock or something I am suppose to be doing. Thanks for the help. Oh by the way....my middle name is Murphy. That is short for Murphy's Law. I have the worse freakn luck.
Swamp Rabbit is offline   Reply With Quote
Old 07-29-2010, 10:49 PM   #2
Kentucky 295 Canada 205
TOTM Winner Nation Elite Contributing Member Calendar Spread 355 Celebrity Good Samaritan 100K NESM 09 SESM 09 MESM 10
Re: Radiator fluid amounts question
How To: Change Coolant and Inspect Cooling System
Order DRL covers here > http://www.355nation.net/forum/class...rl-covers.html
Old 07-29-2010, 11:04 PM   #3
Those are the directions I call myself following. It calls for 10.6 L of fluid though I believe. I only have about 5.5 L in there now I suspect.
Did I miss something?
Old 07-29-2010, 11:08 PM   #4
Nation Elite Contributing Member Calendar Spread WCSM 08 WCSM 09 WCSM 10
rune's Avatar
Don't forget the heating system as well. Heater core. And from what I found cooling system is actually 11.6 quarts.
I'll keep my freedom, my guns, and my money.
You keep the "change".
rune is offline   Reply With Quote
Old 07-29-2010, 11:09 PM   #5
Military Service
NativeColorado's Avatar
did you drain the block when you flushed it?
2008 Colorado Z71 4X4
NativeColorado is offline   Reply With Quote
Old 07-29-2010, 11:25 PM   #6
rune's Avatar
I always drain block and heater core. That was on my mustang though. With the rado, and deathcool, I let GM handle it. Too much of a hassle to dispose, and I'd rather have as uncontaminated of a system as possible.
Old 07-30-2010, 09:30 PM   #7
Update. Apparently I didn't drain the block. So instead of redraining and dealing with more headache......I drained some fluid out and put in some more water. I just went for a ride and during the ride it went to half way mark. So I sat in my drive way with AC on full blast and it bumped up to almost 2 dots above half way just sitting there at 8:30 PM. Frustrating. Does my skid plate being off right now have anything to do with this by chance? I am going to check my freeze ratio again in the morning while the truck is nice and cool. I may have to drain some more fluid out and add just water. What is the lowest ratio I can go to? It does freeze here in the winter. Sometimes down to 10* but that is extreme cold here.
Old 07-30-2010, 09:41 PM   #8
Military Service
Choosing the temp you think is safe is up to you based on where you live. And the way you get to that temp is by purchasing the coolant test guage and trial and error until you get to the number you predetermine. Skid plate will have some bearing since the bottom of the factory skid plate is an air diffuser to increase air flow to the radiator. But if you are just parked in the driveway, that being off won't matter.
Old 07-31-2010, 09:10 AM   #9
Ok. So I checked it this morning while everything was cool. The ratio thing says it is at 0* F now. I may leave it there and see what happens. Don't expect it to get to 0 around here.
Also, I understand the skid plate would have nothing to do with it sitting still. I was just wondering if driving around it would cause my temps to get up therefore when just sitting still with AC rockin would have actually cause to heat up therefore just sitting it would actually started at a higher temp than normal if the plate would have been on there. Wow that makes no dang sense.
Old 07-31-2010, 02:12 PM   #10
Military Service
No, it doesn't make any sense. But on the highway the air diffuser will make a difference.
Old 08-03-2010, 09:17 PM   #11
Ok. So here is my update.
I changed the Rad fluid. My current freeze point mix is 0*. I cleaned the K&N air filter. Put a bottle of Royal Purple Ice in. Changed transmission fluid and filter. And put a transmission cooler on the front (no fan). Still running same temps. 2 notches above 1/2 way. Keep in mind it was 102 here today and the heat index was like 112. It is stupid HOT
Old 08-03-2010, 11:21 PM   #12
rune's Avatar
Honestly man if you are only 2 notches above 1/2 at 102. You are fine. When I was running back from Cali with SC's parents, and it was 105 out, we both were running 3/4 mark. Where you are sitting right now is prolly around 215 degrees. Its warm but its not OMG the truck is on fire hot. It will be fine. I think that sometimes we tend to overthink these things way to much. Way till you get a scanguage. Then you really start to find problems that don't exist.
Old 08-04-2010, 12:34 AM   #13
Ron Lopes
xronx's Avatar
Send a message via ICQ to xronx Send a message via AIM to xronx
oem spec is 10.0 liters (10.6 quarts)
xronx is offline   Reply With Quote
Old 08-04-2010, 02:13 AM   #14
Military Service
x2. 2 notches about half is only 200-205 on my scanner. That is the hottest mine has gotten too after making my changes. That temp is good.
Old 08-04-2010, 06:12 AM   #15
Global Moderator/MTS Crew
355Nation Moderator Military Service Chapter Founder TOTM Winner Nation Elite Lifetime Contributing Member MTS NESM 09
Send a message via Yahoo to 1BADI5
That line is so true!
To much knowledge can be as bad as not enough!
Join the CAPITAL CHAPTER! PM Chris0nllyn, Downtime Designs or 1BADI5
Notice, Capital Chapter covers VA, DC, MD, DE, southern PA.
Originally Posted by Freewood View Post
My best advise to you Sean is to flip your selector switch to Rock-n-Roll and jam out like Mr. Clean.
http://www.355nation.net/forum/image.php?type=sigpic&userid=462&dateline=12138503  42
Old 08-04-2010, 06:21 AM   #16
Military Service Contributing Member
gbc43's Avatar
I put some cooling fluid in mine because I was pulling a trailer when I first got my truck .
2004 Canyon Z-71 Ext Cab SLE 3.5 auto 3.42 gear Michigan 355 63,000 miles
gbc43 is offline   Reply With Quote
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
