#1 |
| Nation Advocate | List of parts needed for V8 swap... First of all ofcourse you need your LSX based engine and I recomend you just get a doner tranny as well. However much you can get that for is totally up to you. I recomend you get a motor that has everything on it which by that I mean like the coils,compressor,starter,alternator, pretty much all your accesserios so you dont have to buy everything seperate and new which will cost more money. If you would like any aftermarket parts that would be all up to you on the prices and stuff. You will need to contact current performance so they can build you a Custom harness-$950. Custom motor mounts-$150. You need Trailblazer 5.3(2006) pcm and tcm bought both for-$300. You also need the gas pedal from the trailblazer 5.3 -$90. Modified ignition switch from current as well-$125 E-fans are very recomended-$100. LS1 style fit perfect. Also need 2 LS2 knock sensors -$10.00 for each You will need the heater hoses as well for a 5.3 chevy truck-$30.00 The rest will probably be just labor. These parts are the most important and most expensive that you need after all this is done and installed. You will need a bunch of little hoses and wires and I believe fuel lines as well. You will also need for somebody to Tune it with HP tuners, current performance can do it for you as well. Here are the parts that you can and cant reuse with the V8. You can use the stock radiator it seems to be working fine with the fans helping it out. You can use your stock A/C lines just someone will have to modify them a bit. You can use your stock driveshaft fit's perfect. Like 1/2inch shorter no prob. The stock rear end seems to be holding up pretty good still ![]() You can use your stock power steering lines but since the power steering from the V8 will be in the opposite side you will need to shorten them, better to have them custom made instead. I dont know why people say this swap takes allot of $$$ and time when it's just a simple swap since the harness from current performance is just a plug and play real bad assss and everything works. Im sure im missing little stuff here and there so if your going to do the swap hit me up and ill be more then glad to help you out. BTW I wasted not counting the performance parts that I got for my truck just regular swap and all that was like ....$4700 on everything besides the the performance parts and im including labor already. BTW if you guys are willing to do the swap and willing to drive to Edinburg TX the shop where I did mine are more then willing to help you all out and do the work for ya. I think this is it I need to upload pics of the swap but im too lazy to go get the camera from the shop lol. Like I said hit me up and ill be more then glad to help you out with whatever problems you are having or whatever. I would like to thank currentperformance -jared for an awesome job and for helping me out whenever we got stuck with the swap thanks man and I recomend him to everyone cool guy to work with. Also like to thank XHRCUSTOMS for giving me his # and letting me call him to ask for more info on the swap and helping me out thanks man. Also LS1blazer for your info as well thanks allot man. Finally I would like to thank Xessive Motorsports where (TALK IS CHEAP LET"S RACE) is their model. They did an awesome job. (956)384-9200 that is there # if anyone is interested on a price range. |
| Nation Elite | Re: List of parts needed for V8 swap... do you know what PCMwas used? E67? E40? E38?
__________________ -Brian 2008 Black 4.8L Reg Cab Sierra - sold 2001 Acura Integra LS <3 37 MPG |
| Nation Advocate | Re: List of parts needed for V8 swap... Dont know but it was for a 2006 (5.3) trailblazer just as simple as that. |
| Nation Elite | Re: List of parts needed for V8 swap... I just ask because in 08 they switched PCM's in the colorados so a new pcm/tcm may not be needed.
| Nation Affiliate Join Date: Apr 2008 Location: St Louis MO
| Re: List of parts needed for V8 swap... Awesome. This will help alot of people. |
| New To The Nation | Re: List of parts needed for V8 swap... An 06 ECM from a TrailBlazer would be an E40 ECM. Sounds like a sick swap man, I would love to get a Coly and drop like a 427 LS2 into it. Ultimate sleeper for sure. But, if Im about to drop around 10-15K for a Coly + 5 (well prob 8-9 with the LS2) Id rather just get a VW GTI and make it crazy fast. Yea its not as unique, but crap they get 30+ on the hwy.
__________________ ~Erik~ 2008 Chevy TrailBlazer SS 3SS AWD Summit White - 6.0L LS2, 4L70E, NAV, RSE, sunroof, engine block heater, Bose, aux adapter, Epic Performance custom tune coming summer 09 2002 Chevy TrailBlazer LT 4X4 Summit White - 4.2L I6, 4L60E, Epic Performance custom tune w/EFILive V2, K&N FIPK2, Magnaflow Catback, 6000K Low & fog HID, The NorthFace Clearance lights, mirror turns w/running lights, Eibach 1.5/2, Bilstein HDs, Hotchkiss rear, Dueler AT Revos, more... |
| | #7 | |
| Nation Advocate | Re: List of parts needed for V8 swap... Quote:
| Nation Elite | Re: List of parts needed for V8 swap... good job man. Thats an awesome truck. I think im goin with a turbo but when i blow the 5 banger i'll do this. It seems like it actually came together quite fast. How long exactly did it take?
__________________ "As an American I am not so shocked that Obama was given the Nobel Peace Prize without any accomplishments to his name, but that America gave him the White House based on the same credentials." - - Newt Gingrich |
| New To The Nation | Re: List of parts needed for V8 swap... I hear ya for sure man, but Im 19 and in college so I need a reliable (fast) car. My TrailBlazer has been an awesome first truck, but Ive got 97K on it now with no problems (knock on wood). Im a little hesitant turboing an almost 7 year old engine... But my TB sounds pretty sick right now with the Magnaflow dual catback, the Ix motors make such a different sound than the Vx motors and it turns heads. Plus I can throw my boat on the back and yank it around to the lake and back. But, I cant afford gas right now (kinda an oxymoron if Im looking to buy a 25+ thousand car right?) and I want something smaller, faster, and more efficient. Id love to get a Coly with the V8 and ZQ8 (whenever GM releases them), but I think that'd cost me about the same as a GTI and still be slower...I dont know, time will tell my friend, time will tell. Im still envisioning having the first turboed I6 using 100% GM electronics but I doubt it will happen.
| Nation Elite | Re: List of parts needed for V8 swap... Sweet man, thanks for the write up. I can't beleive knock sensors are so cheap Nissan ones are 200 retail but anyway... thanks. Ill definately be considering this in the future if i ever manage to blow up my 3.5 with nitrous lol.
| Nation Advocate | Re: List of parts needed for V8 swap... man $4700 is not bad at all but how long did it take to get your truck up and running? |
| | #12 | |
| walking is for the poor | Re: List of parts needed for V8 swap... dammit now I want to do a v8 swap. I have money burning a hole in my pocket that was sapoused to be a down payment on a tahoe but I can't seem to get a fair deal on a loan.
__________________ Quote:
| Nation Elite | Re: List of parts needed for V8 swap... DO IT
| | #14 | |
| walking is for the poor | Re: List of parts needed for V8 swap... I really want to but I also really want to get into a tahoe. Plus I do not know a shop here that would do it. I also keep telling my self I'm going to stop spending money on my truck since its only worth like 7k and I put over 30k into it
| Nation Elite | Re: List of parts needed for V8 swap... All the more reason to do it. Never gonna be worth whats invested so might as well make it go fast too.
| | #16 | |
| walking is for the poor | Re: List of parts needed for V8 swap... I'll probably end up doing it when I move to palm coast Florida. I would do it right now if I had a crew cab but I guess I have to save up some more for somthing bigger.
| Nation Affiliate | Re: List of parts needed for V8 swap... Great info. Thanks
__________________ 2006 Colorado Xtreme Crew Cab - SOLD 1985 GMC S15 Jimmy - the Tyclone - LT1 & AWD Miata race car... Tahoe SS here soon??? |
| New To The Nation | Re: List of parts needed for V8 swap... thanks for the list of parts, i plan on putting a ls2 in mine, to bad im no where neat TX or i would defiently look you guys up. ill let you know how it goes and ill probably be askin some questions so this is defiently not the last time ill be chatin with ya. |
| | #19 | |
| Nation Affiliate | Re: List of parts needed for V8 swap... Quote:
Why do you need to swap the gas pedal? And what is the ignition modification for?
__________________ 2006 Colorado Xtreme Crew Cab - SOLD 1985 GMC S15 Jimmy - the Tyclone - LT1 & AWD Miata race car... Tahoe SS here soon??? | |
| | #20 | |
| Nation Elite | Re: List of parts needed for V8 swap... Quote:
different pedal for different throttle body...DBW I think the stock colorado ignition doesn't send a start signal straight to the ecu...so you need this modified switch or a push button start.
__________________ -Brian 2008 Black 4.8L Reg Cab Sierra - sold 2001 Acura Integra LS <3 37 MPG | |
