the UNending mod....... FINAL CHAPTER!!!!! - Page 23 - Chevrolet Colorado & GMC Canyon Forum
Go Back   Chevrolet Colorado & GMC Canyon Forum > 2004-2012 Chevrolet Colorado Forum / GMC Canyon Forum - First Generation Tech Area > Engines/Performance/Tech Questions > Engine Swaps
LinkBack (2) Thread Tools Search this Thread Display Modes
Old 04-30-2012, 08:06 PM   #441
Really Colorado Obsessed!
TOTM Winner  Lifetime Contributing Member  How-To CM  Calendar Spread
Zeuce's Avatar
Re: 04 to 08 conversion
just because its interference doesnt mean its bent a valve. might have gotten lucky. ive done timing belts on interference engines that ran afterwards.
Join the fun north of the border!______www.canada355.ca_____________CLICK IT!
4" skyjacker 3" BL 33x1250R18 way too many mods to list!
Zeuce is offline   Reply With Quote
Old 05-01-2012, 03:08 AM   #442
xkmacx86
TOTM Winner  Nation Elite  OG Lifetime Contributing Member  How-To CM  SuperMeet Organizer  Calendar Spread  Skitz Award  100K  USASM2012  WCSM 10  WCSM 2014  WCSM 2015
BADLANDER's Avatar
I got a bit done tonight. Pulled the oil pan and timing cover. Got the timing chain set and the remain sty nice and tight. Still a little confused about the rotating the exhaust actuator before tightening. It only moved all of a degree or so. But it's in there all put back together. I'm going to install the manifold and intake tomorrow to see how i did. I took a video of the timing chain and what not for you guys. Hope it helps explain more/show more how it motors work. If it's not uploaded by the time i pad out tonight anyone of you guys can get it off my photobucket in the morning and pussy it here. Should be almost done tho.
BADLANDER is offline   Reply With Quote
Old 05-01-2012, 09:25 AM   #443
Nation Elite  Lifetime Contributing Member  How-To CM  100K  SESM 2013
jdmalone's Avatar
Originally Posted by xkmacx86 View Post
pussy it here.
mustve been really tired and had a woman in bed waiting on ya! haha
Jonathan
2005 CC Xtreme black is for sale
jdmalone is offline   Reply With Quote
Old 05-01-2012, 11:19 AM   #444
xkmacx86
BADLANDER's Avatar
Lol post. 18 hour day. It won't upload. I've tried it twice. Maybe on wifi later.
Old 05-01-2012, 09:43 PM   #445
Nation Elite  Lifetime Contributing Member  How-To CM  MTS  355Loyalty  USASM2012  WCSM 09  WCSM 10
04colyZQ8's Avatar
lol.. pussy! And glad you made-some good progress so did the old tensioner brake?
"Like A Rock"
HP tuning at efituning BC
R.I.P 2004 Chevrolet Colorado reg cab Victory Red ZQ8 2.8L/4.8L..used to be 5spd...now its a MN12 T56!!! 6 speed H3 rear disk brakes, custom backing plates, 09 fronts
Imported 2004 Chevrolet Colorado LS Victory Red ZQ8 3.5L Auto/ repowered with 4.8L
2013 U built trailer (rear half of R.I.P)
04colyZQ8 is offline   Reply With Quote
Old 05-01-2012, 09:52 PM   #446
xkmacx86
BADLANDER's Avatar
I have a bad feeling is not the tensioner. I'm hooking up the Trans cooler in a few.
Old 05-01-2012, 10:01 PM   #447
04colyZQ8's Avatar
What else then? Bad chain,or the new sprocket is smaller?
"Like A Rock"
Old 05-01-2012, 10:28 PM   #448
xkmacx86
BADLANDER's Avatar
I thought i could run it with out the cooler for just a sec but i was wrong lol. i turned it over for just a second and it sounded just like it did before
Old 05-01-2012, 10:38 PM   #449
if you just replaced the tensioner and not the chain it probably will sound the same because I'm sure that timing chain got stretched.
How did the teeth on the sprockets look?
Old 05-01-2012, 11:34 PM   #450
xkmacx86
BADLANDER's Avatar
Sprockets are perfect. There's no way that chain got stretched.
Ineed to get more info on the install of the exhaust sprocket. There's a mention of rotating it before filly tightening it down.
Old 05-01-2012, 11:53 PM   #451
jdmalone's Avatar
is the noise for sure from the front of the engine? thinking maybe the balancers are off somehow...doubt it tho. looking on alldata for info on the exhaust cam sprocket
Jonathan
Old 05-01-2012, 11:55 PM   #452
jdmalone's Avatar
Install the intake camshaft sprocket into the timing chain. Aligning the marked link (1) on the timing chain with the timing mark on the intake camshaft sprocket. Important:
To aid in aligning the sprocket to the camshaft, use a 25 mm (1 in) wrench on the hex of the camshaft to rotate.
Ensure the alignment pin is properly engaged with the camshaft.
Install the intake camshaft sprocket onto the intake camshaft. Notice: Refer to Fastener Notice (See: Service Precautions\Vehicle Damage Warnings\Fastener Notice).
Install the new intake camshaft sprocket bolt. Tighten the bolt to 20 N.m (15 lb ft) plus an additional 100 degrees using the J 45059 .
Remove the J 44217 (1) and J-44217-45 (1).
Remove the J 44221 from the camshafts.
Install the intake CMP sensor. Refer to Camshaft Position Sensor Replacement - Intake (See: Powertrain Management\Computers and Control Systems\Camshaft Position Sensor\Service and Repair).
Install the camshaft cover. Refer to Camshaft Cover Replacement (See: Valve Cover\Service and Repair).
Jonathan
Old 05-02-2012, 12:04 AM   #453
jdmalone's Avatar
this appears more in depth
Important: Ensure the #1 piston is at TDC. The pin on the crankshaft for the timing chain sprocket should be straight up.
Install the crankshaft sprocket to the crankshaft snout. Important: Every 7th link of the timing chain is darkened to aid in aligning the timing marks.
Install the intake camshaft sprocket into the timing chain. Aligning the dark link (1) of the timing chain with the timing mark on the intake camshaft sprocket.
Feed the timing chain down through the opening in the cylinder head.
Install the timing chain on the crankshaft sprocket. Align the dark link (2) of the timing chain with the timing mark on to the crankshaft sprocket. Important: Ensure the alignment pin is properly engaged with the camshaft
Ensure the camshaft actuator is fully advanced prior to installation. Refer to Camshaft Position Actuator Diagnosis (See: Testing and Inspection\Component Tests and General Diagnostics).
Install the exhaust camshaft actuator into the timing chain. Aligning the dark link (1) of the timing chain with the timing mark (1) on the exhaust camshaft position actuator sprocket. Important:
To aid in aligning the actuator to the camshaft, use a 25 mm (1 in) wrench on the hex of the camshaft to rotate
Install the exhaust camshaft actuator onto the exhaust camshaft.
Install the new exhaust camshaft actuator bolt. Tighten the bolt to 25 N.m (18 lb ft) plus an additional 135 degrees using the J 45059 .
Remove the tee in the timing chain tensioner to regain tension on the timing chain.
The dark links (1) on the timing chain should be aligned with the marks on the sprockets as shown.
Install the engine front cover. Refer to Engine Front Cover Replacement (See: Timing Cover\Service and Repair).
Install the exhaust CMP sensor. Refer to Camshaft Position Sensor Replacement - Exhaust (See: Powertrain Management\Computers and Control Systems\Camshaft Position Sensor\Service and Repair).
Install #1 cylinder spark plug. Refer to Spark Plug Replacement (See: Spark Plug\Service and Repair).
Jonathan
Old 05-02-2012, 12:06 AM   #454
SCSM2012  SCSM 2013
PasadenaCanyon's Avatar
Gasoline and matches...
Originally Posted by ivan29 View Post
my body is a temple that welcomes ANY kind of creatures of socal. to make their soul pure and full of joy :wink:
PasadenaCanyon is offline   Reply With Quote
Old 05-02-2012, 12:28 AM   #455
xkmacx86
BADLANDER's Avatar
^^^^^^^^quitter
Jd thx. I just got the file from all data too. It looks like the actuator/reluctor is rotated clockwise by a 1/4 in. That's the only thing i haven't done.
Old 05-02-2012, 12:58 AM   #456
xkmacx86
BADLANDER's Avatar
The reluctor moves all of 2-3 degrees. The reluctor itself is attached to the cam and the sprocket is technically separate.
Old 05-04-2012, 01:35 AM   #457
355 O.G.  Chapter Founder  SuperMeet Organizer  355 Celebrity  WCSM 08  WCSM 09  WCSM 10  WCSM 2015
Turbizzy's Avatar
Send a message via AIM to Turbizzy
OMFG i just sat here and finally read all this BS and im about ready to start an 07 Longblock Swap fund for you Kevin lol, cuz i woulda gave up on this shit weeks ago!
I talked to my buddy who's done a bunch of I5 heads and he told me there wasn't anything special about torquing down the cam sprockets or their rotation prior to installation. Just to make sure the exhaust cam sprocket/actuator is locked? Cuz i guess the oil pressure unlocks it and actuates is and the spring pulls it back to locked but yeah anyway this sucks.
Seems like your getting closer though. I still have my doubts about this engine and it's past history....
PM me for hookups on Belltech and DJM parts
Turbizzy is offline   Reply With Quote
Old 05-04-2012, 02:17 AM   #458
xkmacx86
BADLANDER's Avatar
I set that sprocket tonight and put it all back together and still no improvement. I'm out of ideas.Daddy screw it and track down an 07 i guess.
Old 05-04-2012, 02:19 AM   #459
xkmacx86
BADLANDER's Avatar
One of my neighbors made a comment about fuel pressure. I'll check that tomorrow. I think I'll be buying a car tomorrow. I can't do $500 for a rental a month
Old 05-04-2012, 02:38 AM   #460
04colyZQ8's Avatar
Check out the bottom end I think you may have spun a bearing.
"Like A Rock"
LinkBack to this Thread: http://www.355nation.net/forum/engine-swaps/53149-unending-mod-final-chapter.html
GMLAN - forum communication | BoardReader This thread Refback 03-10-2012 07:22 PM
Engine Swaps on Chevrolet Colorado and GMC Canyon Forum | BoardReader This thread Refback 03-10-2012 04:12 PM
