| | LinkBack (1) | Thread Tools | Search this Thread | Display Modes |
| | #81 |
| Spoolin Jr. Survivor | Re: 4x4 6.0L/4L80e with a front mount turbo
And higher stall speed would help quite a bit with spooling the turbo. I also suggest running ethanol or methanol. Save you the huge fabrication hassle of bringing the drivetrain from the Silverado to the Colorado.
__________________ ![]() Mike B's 08 Colorado LT Z85 regular cab 3.7L auto 3.73 G80 e85 + 61mm |
| | #82 | |
| New To The Nation Join Date: Sep 2012 Location: Ohio
| Re: 4x4 6.0L/4L80e with a front mount turbo Quote:
__________________ '05 Colorado LT 4x4 '99 RCSB 4x4, Rex Forged 6.0L, WCCH 6.0l heads, 212/218-.600@115 cam, Trick turbo kit w/ a 76mm, Magnaflow, FLT 4l80e, Circle-D proIII 3000, hydro-boost, HPTuners, SS 6 lug 14 bolt and its all going into the Colorado with a bigger turbo | |
| | #83 | |
| Spoolin Jr. Survivor | Re: 4x4 6.0L/4L80e with a front mount turbo Quote:
__________________ ![]() Mike B's 08 Colorado LT Z85 regular cab 3.7L auto 3.73 G80 e85 + 61mm | |
| | #84 |
No, just changing out the diff, and having axle shafts made to fit. Probably bigger tie rods, and strapping the front down at the track.
| | #85 | |
| I'm doing SCIENCE! Join Date: Feb 2011 Location: Port Orange, FL
No kidding? I've been toying around with the idea of a 6L80 swap, if I could figure it out, once my warranty or 4L60 blows up. LOL
__________________ ![]() 2012 Colorado 5.3L 4x4 Z71 | |
| | #86 |
The bolt pattern isn't symmetrical, so you can't just flip it. I found an old gasket in my basement and measured. It's not off by much, but it is off.
| | #87 |
I ordered my CP harness yesterday. Jared knows what he's talking about. 6 weeks out sucks though.
| | #88 |
| New To The Nation Join Date: Jul 2012 Location: Akron, Ohio
Jared does know his shit. He has my harness right now for the trans conversion and tcm programming.
__________________ 2000 Sonoma Zq8 Extcab '08 Ly6 6.0,'10 Colorado e67 ecu/5.3 base tune, Nx nitrous plate, TSP vvt-2 cam + more goodies, TDP Stage 2 T56, HPTuners, Narrowed 8.8 swap: Moser axles, 3.73 gears, disc brakes, posi. Caltracs. Afco Coilovers Best time 12.6@114mph na Ly6 + Sonoma Swap thread: http://www.ls1tech.com/forums/conver...00-sonoma.html '96 Maxima Se 5sp - Warpspeed Y-pipe + Stillen B-pipe, otherwise stock |
| | #89 |
Running yet??
| | #90 |
Still waiting on my harness, and pistons. Diamond only stock 4.030 pistons, but I didn't want to go that far. I have to wait on the harness anyways, so I had them make me some 4.010 with the top ring down a bit. They should be here this week, so I should be putting the engine together in the next week or 2.
| | #91 |
Nice, Glad its still coming together. Going to have to hurry to make the lsx dyno day in may
| | #92 |
I might get it together by the dynoday, but I doubt it. I just now found a 4L80e that is low miles enough to put back in my old truck, so I pretty much have 2 projects right now. The old truck won't take long, but there will be some fab work on the Colorado.
| | #93 |
Nice, once I get my truck back I still have to rip out the interior to complete the auto swap, redo the front half of the exhaust to meet the new longtubes, do the ac box delete redo the crossmember notch since the new one came out too close for comfort, and a list of other stuff to get the truck back together. Highly doubt itll be running by dyno day.
| | #94 |
Ok guys, it's getting close. Whats the deal with the firewall, and how much is in the road? Is it just the truck intake that's a problem, and is it just the rib that runs across it?
| | #95 |
Well, the machine shop called with some bad news yesterday. My heads have little cracks between the valve seats, that everyone missed, including me, until they were being torn down to replace the seats. ![]() These are the heads in the picture that I have, so I'm getting a bare set, and re-using my valves, and I already bought dual spring kit with titanium retainers, and seals. http://www.proheads.com/WCCH%206.0L.html My piston finally came in, but I only snapped a couple quick pics, as I was dropping them off at the machine shop the other day. They are 4.010, with the top ring lowered, so they are a "custom", I guess that was the hold up. My new LS2 crank is already balanced today, and I got to see it being polished. ![]() ![]() This is the intake f-body guys like because it fits, and it flows well. I think this is what I'm going with, instead of spending all the time, and money finding f-body/corvette accessories. Edelbrock 29085 Edelbrock Victor Series EFI Intake Manifolds
| | #96 |
| That's movin Jack... | Re: 4x4 6.0L/4L80e with a front mount turbo
The truck intake fits with minimal massaging. That pinch weld needs to be knocked down and in just a touch in a little section like 2-3 inches. The 4l80 fits with zero mods to the tunnel
__________________ -Cory- 05 Colorado - racecar 09 Pontiac G8 GT - not so racecar 94 Trans Am - racecar |
| | #97 |
I always wanted to get an intake when this was in my silverado, but never had a good excuse to. Do you know how much power your truck is making, if you don't mind me asking? I'm wondering what WG spring to go with. I have 6/8/10lb springs, with an electronic boost controller, so I can go up from there. I'm wondering what would be a good whp to dd this thing with. I had the 8lb (actually 8.5-9psi) spring in it before, and it made around 420whp, but it should make a little more this time around.
| | #98 |
Non right now. My million mole junkyard 5.3 had an oiling issue and washed a cam lobe off sending glitter everywhere. 2008+ low mile gen4 with the beefy rods and flat tops is in the garage waiting to be dropped back in. If you have a boost controller I would just put the softest spring in there for valet mode lol
| | #99 |
When your on it hard is it twitchy in the rear like a car is, or does it stay pretty straight like my silverado did. I have driven my buddys vette a few times, and another buddys 03 cobra, and they felt like they were almost trying to kick out and throw you into a ditch.
| | #100 |
Its stays straight and floats. It doesn't have that IRS feel to it
LinkBack to this Thread: http://www.355nation.net/forum/engine-swaps/58360-4x4-6-0l-4l80e-front-mount-turbo.html | ||||
| Posted By | For | Type | Date | |
| Engine Swaps on Chevrolet Colorado and GMC Canyon Forum | BoardReader | This thread | Refback | 01-12-2013 12:55 AM | |
