BCM (Body Control Module)? - Chevrolet Colorado & GMC Canyon Forum
Old 01-04-2017, 08:19 PM   #1
Question BCM (Body Control Module)?
2007 Colorado LS 2.9 litre,5 speed manual:
This is the last part i did not replace on this unreliable truck.Did anybody replace the BCM on n the first generation of Colorado or Canyon.I am still experiencing no start,no crank at time.So far I replaced the battery,both battery cable to starter & ground,Replaced starter,replaced 3 times ignition switch& now the cylinder lock key switch.I replaced the clutch switch too.I also replace the crank relay,run relay .clean the fuse box,clean all connection from starting diagram.Still a click at the starter at time.If I put a 12 volts wire on the starter relay,it cranks & start.kind of bugging to open the hood to start this truck....
kidcharger is offline   Reply With Quote
Old 01-11-2017, 01:54 PM   #2
2005 3.5 L automatic. I think I am having a similar issue to what you're describing I haven't placed any parts yet. It seemed to have started a couple months ago when my battery went bad. It was pretty infrequent but in the last two weeks has gotten a lot worse and sitting in my driveway for two days. Initially thought it was a negative terminal on the battery replaced that twice still not fixed. All the lights on come on like normal you here the relays clicking in the fuse box under the hood when it will not start. When it does turn over it will initially start but stall right away. And then at times it will start like nothings wrong. I'm going to have my GM mechanic friend look at an a few days. When I told him the problem he suggested a BCM. I will be sure to update as this is the only thread that somebody's had the same problem described as me.
j225 is offline   Reply With Quote
Old 01-24-2017, 04:25 PM   #3
Re: BCM (Body Control Module)?
A BCM fixed my issue. $150 used/programmed on ebay. You will probably need a GM Tech 2 programmer or another high end one to do a crank case relearn (I borrowed one). I think the code I was getting was P0601.
2006 Hummer H3 Engine computer 12597521 "Programmed to your VIN" ECM PCM ECU | eBay
Old 04-10-2017, 04:47 PM   #4
Please a need the part number of the BCM chevrolet colorado 2007 LT Gas, 3.7L .
Csaenz is offline   Reply With Quote
Old 04-10-2017, 04:52 PM   #5
2009 3LT ZQ8 5.3L V8
rshadd's Avatar
Post Re: BCM (Body Control Module)?
01 MODULE. Body Multifunction Electric Computer. Door Lock Remote Control Inside.
MODULE,BODY CONT(02.560)(ACDelco #25816709). Required: 01
MODULE,BODY CONT(ACDelco #25816709). Required: 01
For: ST1 (2007-2008) (2007 - 2008).
Part Number: 25816709
$207.02
http://www.wholesalegmpartsonline.co...roduct=3034410
rshadd is offline   Reply With Quote
Old 04-10-2017, 05:22 PM   #6
https://www.amazon.com/dp/B0016I4CRC...23860_70668520
Old 04-10-2017, 07:03 PM   #7
Did You fix your problem?
https://www.amazon.com/dp/B0016I4CRC...I2N3KURQURJCVT
Old 04-25-2017, 07:39 PM   #8
Keys and Pass Lock
HOUSING ASM-IGN & START
KEY DR LK & IGN LK
Please help me!!! I need the part number of these items.
Chevrolet Colorado 2007 Lt 3.7 automatic
