Go Back   Chevrolet Colorado & GMC Canyon Forum > Tech Area > Engines/Performance/Tech Questions
Old 06-04-2010, 04:40 AM   #1
killahj68's Avatar
help b4 i mess things up!!!!!
ohkayy so im going to be changing oil for the first time tomorrow!!! besides doing it on my dirt bike....so i need help! im going to list the order that i think is right so correct me if im wrong?!
1) warm the truck up.
2) jack the truck up.
3) unbolt the drain plug.
4) remove the oil filter while oil is still draining.
5) once all drained put the plug back and put 5 quarts in and screw in a new filter.
6) do the oil reset thing that brewer explains how to do (if someone could find that thread for me please i cant find it)
7) turn the truck on and let idle.
is that correct or did i miss out on any thing? my friends say its super easy a caveman can do it but i gotta make sure b4 i fuck things up!
so thanks!
"ever wondered why A,B,C,D,E,F are used for bra sizes? A: Almost boobs B: Barely there C: Can do D: Damn good E: Enormous and F for Fake!"
killahj68 is offline   Reply With Quote
Old 06-04-2010, 05:07 AM   #2
Contributing Member MESM 10
extcolorado4x404's Avatar
Re: help b4 i mess things up!!!!!
well my truck takes 6 quarts and i wait till the plug is done draing befpre i take the filter off but thats me and i don't jack my truck up
extcolorado4x404 is offline   Reply With Quote
Old 06-04-2010, 05:12 AM   #3
o and the reset thing he prolly told you right but just turn the key to the on postion an push the gas pedal 3 times and start the truck (don't know if u need to start it then but thats when i start it for the idel)
Old 06-04-2010, 05:21 AM   #4
Global Moderator/MTS Crew
355Nation Moderator Military Service Chapter Founder TOTM Winner Nation Elite Lifetime Contributing Member MTS NESM 09
Send a message via Yahoo to 1BADI5
His 2.9 only needs 5 qts!
Oh, it should be more like, bolt in drain plug, add new filter, then add oil! If you try to add oil before you put the new filter in....well I think you can figure that one out!
Join the CAPITAL CHAPTER! PM Chris0nllyn, Downtime Designs or 1BADI5
Notice, Capital Chapter covers VA, DC, MD, DE, southern PA.
Originally Posted by Freewood View Post
My best advise to you Sean is to flip your selector switch to Rock-n-Roll and jam out like Mr. Clean.
http://www.355nation.net/forum/image.php?type=sigpic&userid=462&dateline=12138503  42
1BADI5 is online now   Reply With Quote
Old 06-04-2010, 05:24 AM   #5
killahj68's Avatar
oh yeah i've done that on my dirt bike b4!haha but yeah is all the above correct? and do i still need to warm the truck up b4 i change it?
Old 06-04-2010, 05:27 AM   #6
Its not really needed. The temps in Hawaii are enough!
Old 06-04-2010, 05:30 AM   #7
killahj68's Avatar
haha yeah espeacially now!! so yeah im doing this tomorrow, just getting info now and not suffer later.
Old 06-04-2010, 06:11 AM   #8
Yeah it sounds like you will be alright then!
Old 06-04-2010, 06:42 AM   #9
killahj68's Avatar
wait!! would i need to torque the bolt after?
Old 06-04-2010, 06:43 AM   #10
killahj68's Avatar
oh and will i be fine wid a ratchet and a socket?
Old 06-04-2010, 06:49 AM   #11
Military Service Contributing Member
Aquivarious's Avatar
I am partial to a 6 point box end wrench for the drain-plug. Or a 6 Point socket I guess. That way you are less likely to strip the drain plug. Also, you can add oil before you put the filter on... But if you do it yourself, you are down there anyway so drain, take off old filter, install new filter, tighten drain bolt, then add oil. Start and let idle until the little genie lamp (oil pressure light) goes off. then Done!
Aquivarious is offline   Reply With Quote
Old 06-04-2010, 06:55 AM   #12
Wrench or socket will do!
I have been doing oil changes since I was a kid, so I think you can handle it!
Old 06-04-2010, 10:18 PM   #13
killahj68's Avatar
ohkayy so i changed my oil and i was fully shitting my self! but the outcome came out very great!! i put in 5 quarts and had to take out about 8oz. because it was overfilled, and there was no leaks made a bunch of mess and got scoldings from my mom cause there was oil all over the garage haha!!! but yeah i feel pretty confident now! thanks for the help guys!! very very helpfull site!!
Old 06-04-2010, 10:22 PM   #14
You Smell That?!?!
Nation Elite Contributing Member SuperMeet Organizer 100K SESM 09 TXSM 10
rtmsu_02's Avatar
did u crank it befoer u took out the 8 ounces?
cause that generally fills the filter
2004 Silver birch Canyon Z71 SLE 4x4 120,000 miles and counting
rtmsu_02 is online now   Reply With Quote
Old 06-04-2010, 10:51 PM   #15
Contributing Member Public Service
jrotundo's Avatar
personally i would have filled the filter before i put it on aaaaand put a dab on the o-ring and wiped it around it....probably just preference. but if its ur first oil change then good job!
jrotundo is offline   Reply With Quote
Old 06-04-2010, 10:52 PM   #16
xseler's Avatar
A little overfull won't hurt a thing. A lot overfull is a different story. 8oz is a little overfull.
Yoda always said "Try not. Do or do not. There is no try."
xseler is offline   Reply With Quote
Old 06-05-2010, 12:06 AM   #17
Chapter Founder TOTM Winner Contributing Member SuperMeet Organizer NESM 09 NESM 10
J-Bo's Avatar
This is my ritual as well.
J-Bo is offline   Reply With Quote
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
