GM 15295272 Catalytic Converter vs. Walker 54480 - Chevrolet Colorado & GMC Canyon Forum
Old 03-22-2011, 12:41 PM   #1
Ok, so the catalytic converter on my 04 Colorado I5 ZQ8 has been rattling like mad at an idle and driving me nuts. Completely goes away with a little RPM's, but sitting at a stop light, or ideling through a parking lot it is loud and obnoxious. All indications are that an internal baffle has broken loose. Looking at bolt in replacement options, I'm coming up with the OEM GM replacement (part number 15295272) to the tune of about $450 at a discount, or the Walker direct fit replacement 54480 for half that price. Has anyone used the Walker replacements? Are they high flow like the OEM? Good, bad, indifferent? Thanks for sharing your experience.
paoutdoorsman is offline   Reply With Quote
Old 03-22-2011, 01:09 PM   #2
Andersonn's Avatar
Re: GM 15295272 Catalytic Converter vs. Walker 54480
If your under 80K it should be covered under the emissions warranty.
~SOLD~ 04 Z71 2wd crew cab.
40 series Flowmaster. Kenwood HU. Alpine M-850 and 12" Alpine Type - R.
Now daily driving a 2006 reg cab 2wd z85 Colorado.
Andersonn is offline   Reply With Quote
Old 03-22-2011, 01:16 PM   #3
First off welcome to the nation!
Now, first thing you need to do is get under there and MAKE SURE its the cat. You could very well be rattleing on the cross member. Or against the frame. Who knows...
get under there when its cold..start her up and get under it quickly and with a glove press against things trying to figure out where the noise is coming from. Once you find out where you can go from there. IF it is the cat, and your out of warranty..you can replace with ANY aftermarket cat at a much cheaper rate bro. Don't waste money on a stock cat. Ask nicely and someone may even give you one they removed. I dunno with todays metal prices though! LOL
But get under there first and see what ya think..wear gloves. Oh, and the reason I think this is the case..when you give it just a bit of gas the engine twist just a bit. When it does the exhaust moves also of course. If its laying on the CM or frame whatever, and you can see it twist away and stopp rattleing, then you have found your problem AND its a free fix. Loosen the brakets and turn the exhaust up. When you do that you tighten the bolts back down and your done.
Old 03-22-2011, 01:40 PM   #4
MTS Crew!
Military Service  Nation Elite  Contributing Member  How-To CM  MTS  Skitz Award  100K  USASM2012  NESM 11  NESM 2013  SESM 10  SESM 11  SECSM2012  Skunkwerx Super Mod Meet 2015
thethein11's Avatar
It sounds like you are pretty sure where it is coming from but just in case here are some other places to look: How To: Diagnose & Repair Exhaust Rattle(s)
- Billy
thethein11 is offline   Reply With Quote
Old 03-22-2011, 01:51 PM   #5
Well I can say I went with the Walker replacement and 2 years later everything is fine.
The dealer wanted over $1600 to replace both....F that. I gutted the primary and replaced the secondary for under $240
Old 03-22-2011, 03:11 PM   #6
If jeremy says its a good replacement, then i would go with that...I guess if we HAD too we could all trust him... Not like the guy fights for our freedom or anything crazy like that! I mean, you know since no one else is saying dont use it..
Old 03-22-2011, 03:16 PM   #7
Banned
Military Service  Contributing Member  How-To CM  Public Service
He dosnt fight for freedom he organizes secret squirrel shit and makes people's heads explode from laser beams from space ahahhahaha little spoon
scoober is offline   Reply With Quote
Old 03-22-2011, 03:21 PM   #8
Oh my bad, I was mis informed then!
Old 03-22-2011, 04:00 PM   #9
Yeah..........but I still go out with the door kickers....sitting on the FOB blows donkey nutts!
I got my Walker cat/mid pipe from Advance Auto for $238. It was a drama free direct bolt in dealio
Old 03-22-2011, 05:53 PM   #10
Thanks for the welcome and the replies guys. I checked it out rather thouroughly by removing the right front wheel liner, unbolting the exhaust behind the cat and running it while crawling all over it. I really wanted it to be a heat shield or an alignment issue, but unfortunately after my time under the truck last night I am certain it is inside the cat. So anyone have a good one they want to part with? Anyone know how/why the ZQ8 cat is different?
If I don't find a good used one here, I'll go for the Walker on 1BADI5's recommendation. Also considered removing it and cutting an access panel in the top to see if I could have the baffle welded back into place, but no idea if that would damage the catalyst or not.
Old 03-22-2011, 05:55 PM   #11
Unfortunately I am at 102K...
Old 03-24-2011, 11:11 AM   #12
I think I'm going to order the Walker. Do you remember if you needed the gasket for the connection between the manifold and secondary cat?
Thanks!
Old 03-31-2011, 02:20 PM   #13
walker makes our stock exhaust. look at your stock muffler it says walker on it
Old 03-31-2011, 02:49 PM   #14
MotorCityRado's Avatar
magnaflow has a high flow cat on ebay for $60 its JUST the cat and would need to be welded in. seems like a steal on the price tho compared to hundreds... anyone know if the magnaflow cat is any good?
MotorCityRado is offline   Reply With Quote
Old 03-31-2011, 02:57 PM   #15
its all gm mark up. walker makes it gm buys it and sells it for more. save the middle man and get it from walker
Old 03-31-2011, 03:00 PM   #16
^^ anyone use this before?
Old 03-31-2011, 03:03 PM   #17
blknrd04's Avatar
ill see what my dad has at his shop maybe i can sell you one for like $20 plus shipping
blknrd04 is offline   Reply With Quote
Old 03-31-2011, 05:33 PM   #18
Yeah but not everyone has access to a welder or the skills.
The Walker replacement, buy it, remove the old and install the new......done in under an hour.
Old 03-31-2011, 11:35 PM   #19
blknrd04's Avatar
yeah true i figured he could clamp it on just an offer trying to help someone out
Old 04-01-2011, 12:11 AM   #20
if you can get one for $20 ill buy one but i need 3" in/out for my midpipe to go with ottp LT header
