| | LinkBack (1) | Thread Tools | Search this Thread | Display Modes |
| | #421 |
| I'm a practical person Join Date: Feb 2009 Location: Dallas-Tx
Mentioned: 1 Post(s) Tagged: 0 Thread(s) | Re: Emaxxer's turbo build.
Stop making highway pulls and save the gas money to at least get the pumps in so you don't knock a piston out of it from a lean fit
__________________ -Cory- 05 Colorado - racecar 09 Pontiac G8 GT - not so racecar 94 Trans Am - racecar |
| | #422 |
| Spoolin Jr. Survivor Join Date: Mar 2008 Location: St. Peters, MO
Mentioned: 0 Post(s) Tagged: 0 Thread(s) | Re: Emaxxer's turbo build.
And I still need some more materials and buy another stock pump that I can modify with the high flow pumps so I can pull the old pump out and drop in the modified pump.
__________________ ![]() Mike B's 08 Colorado LT Z85 regular cab 3.7L auto 3.73 G80 e85 + 61mm |
| | #423 | |
| Nation Affiliate Join Date: Jun 2012 Location: Orlando
Mentioned: 0 Post(s) Tagged: 0 Thread(s) | Emaxxer's turbo build. Quote:
Anybody?Sent from my iPhone using AutoGuide.com Free App
__________________ 08 Canyon Z71 2wd CC- mostly stock for now... | |
| | #424 |
I ordered a used fuel pump and should be receiving it on Thursday and Cory is sending me his fuel rail so I can quickly modify it to run my regulator and be that much closer to having the fuel system finished. Sent from AutoGuide.com App
| | #425 |
| Nation Affiliate Join Date: Sep 2010 Location: Illinois
Are the stock fuel lines going to bottle neck those 2 hd pumps even with the regulator and how about upgrading the wiring for the extra amps they use?
| | #426 | |
__________________ ![]() Mike B's 08 Colorado LT Z85 regular cab 3.7L auto 3.73 G80 e85 + 61mm | |
| | #427 |
I'm not going to be using the stock fuel lines when I swap out the pump. A -6 feed will be used which is a tad larger than the stock hard line. It's plenty for 700-800 hp. I'll be running a -8 return as well so there will be no restriction issues.
| | #428 |
You sure it is? Isnt the stock line 3/8?
| | #429 |
Also alittle confused why you would run a larger return than feed
| | #430 |
Mentioned: 0 Post(s) Tagged: 0 Thread(s) | Re: Emaxxer's turbo build. The -6 line that I looked at had a larger I.D. Than the stock hard line.
| | #431 |
Mentioned: 0 Post(s) Tagged: 0 Thread(s) | Re: Emaxxer's turbo build. Just like with a turbo, you don't want restriction on the return. The fuel pressure regulator is most accurate when the return line doesn't create a restriction. You only want pressure on one side of the diaphragm.
| | #432 |
Broke a vibrant v-band clamp bolt... Pure junk! Luckily my buddy has one that's much better quality that I'm going to buy from him today so exhaust vids are a possibility today. Sent from AutoGuide.com App
| | #433 |
just updated with more pics. I just have the exhaust turned down before the axle for now until I get more aluminum tubing. I also added pics of a modified '04-'05 fuel rail to run -6 AN lines. The twin fuel pumps are ready to be plumbed and wired.
| | #434 |
| Nation Elite Join Date: Nov 2009 Location: La Porte TX
good to hear mike what else you got planed for the truck after this ?
| | #435 |
finish the fuel system with AN lines, finish the exhaust tail pipe, tune, and tires.
| | #436 |
or i should say after all that i mean
| | #437 |
Mentioned: 0 Post(s) Tagged: 0 Thread(s) | Re: Emaxxer's turbo build. I don't plan long term with this truck because I might change my mind.
| | #438 |
| Premium Member Join Date: Jun 2010 Location: Manhattan, Ks
how are things coming along?
__________________ Victory Red ExCab 2007 Canyon ZQ8 Current Boost Project: http://www.355nation.net/forum/force...wer-maker.html Original Build http://www.355nation.net/forum/proje...cab-daily.html ![]() |
| | #439 |
Mentioned: 0 Post(s) Tagged: 0 Thread(s) | Re: Emaxxer's turbo build. Waiting on my tax return so I can get tires and finish the fuel system.
| | #440 | |
| Nation Advocate Join Date: Nov 2011 Location: Cameron Mo
Mentioned: 0 Post(s) Tagged: 0 Thread(s) | Re: Re: Emaxxer's turbo build. Quote:
ET streets?
__________________ it's slow | |
LinkBack to this Thread: http://www.355nation.net/forum/forced-induction/57558-emaxxers-turbo-build.html | ||||
| Posted By | For | Type | Date | |
| turbo/super charger? - Chevy Colorado & GMC Canyon | This thread | Refback | 10-15-2012 03:43 PM | |
