| 3'' of glory | How To: Replace your rotors Disclaimer The community here at 355nation.net urges you to please use caution and seek professional assistance when performing modifications to your vehicle. Before attempting any modification it is advised that you refer to your Colorado or Canyon service manual or contact a certified mechanic as not all GMT355 trucks are the same. The staff and the associated members are in no way responsible for any damages, injuries or other harm inflicted to your vehicle or yourself which may result in attempting these modifications. The posts and content presented on this site reflect in no way the views of 355nation.net or it’s ownership. ![]() A 355nation How To presented by draggin_az Project Name Rotor replacement Project Description Replace your worn out rotors Skill Level Moderate Project Vehicle Make: Chevrolet Model: Colorado 2wd Z85 Year: 2006 Engine: 2.8L Power windows: No Sun Roof: No Tools Needed Impact 3/8 ratchet 1/4 ratchet Big screwdriver torque wrench 15mm socket 13/16 socket 11/16 socket swivel/universal 7mm socket Project Time ~ 2 hours Project Cost $80 step 1. jack up your truck and pull your rim off. ![]() step 2. take off bolts circled with a 13/16 socket. I had to brake them loose with a torque wrench. ![]() ![]() step 3. once the bolts are out you will be able to remove your brake calibers. mine didnt exactly come off so i took my big screwdriver and pried it off. ![]() step 4. with a 11/16 take out the 6 bolts. in the pic you will notice 3 are missing. thats because i started taking them out before i took the pic. yours should have all 6 in there. ![]() step 5. with a 15mm socket remove the 4 bolts on the back of the spindle. those 4 bolts hold your your hub and rotor to the spindle. ![]() step 6a. time to disconnect your ABS sensor. unbolt with 7mm ![]() 6b. with a screwdriver unhook whats circled in white. whats circled in red is where the plug is for your ABS connector. i used a screwdriver to push the little things in then pushed them through the hole. ![]() 6c. here is the switch. push in the end and pull. ![]() ![]() step 7. now for the tricky part. this takes 2 sets of hands. person 1 - grab the bottom of the rotor, lift up and pull out at the same time. that way your ABS senor clears the top/back of the spindle. slowly pull the rotor and hub out. person 2 - as person 1 is pulling the rotor and hub you are to feed the sensor cable through the spindle. work as a team. step 8. lay the hub and rotor face down. pull the dust shield off then the rotor off the hub. ![]() ![]() the new and old rotor side by side ![]() step 9. reassemble in reverse order. |
| Quadruple O.G. | Re: How To: Replace your rotors
Nice job inch pincher thanks
| I Build Awards | Re: How To: Replace your rotors
gOOD JOB bLAKE
__________________ -Cowan |
| | #4 | |
| Bagged Bomber | Re: How To: Replace your rotors
hell yea man nice write up!
__________________ Quote:
| NESM5 Planning Bubbas \/ ![]() | Re: How To: Replace your rotors
Very nice Blake!
__________________ NRA Member/MSI Member/US Army Lifer - Unit Armorer and RSO certified “To preserve liberty it is essential that the whole body of the people always possess arms and be taught alike, especially when young, how to use them…” RICHARD HENRY LEE, 1788, Federal Farmer ![]() |
| Nation Elite | Re: How To: Replace your rotors
Nice right up, but for future information, for you or anyone else doing this, you should never let the caliper hang by the brake hose like that. Always tie it up with a wire, string, or zip tie, to keep the weight off of the hose connection. Letting it hang like that by the brake hose can damage the brake hose and cause more problems.
__________________ I'm a responsible adult, whenever anything goes wrong, I'm responsible. Last edited by CUZICAN; 03-19-2011 at 08:41 PM. |
| MTS Crew! | Re: How To: Replace your rotors
Nice Blake this does not seem that hard to do at all
| Another day..... | Re: How To: Replace your rotors
Nice write up. Very easily understood.
| | #9 | |
| 3'' of glory | Re: How To: Replace your rotors
thanks everyone. the hardest part is braking the bolts loose. once your past that your golden Quote:
| New To The Nation Join Date: Mar 2011 Location: Phoenix
Sweet write up! Was a bit concerned with the ABS sensor assy as I have read they are easily damaged on the '06 and before. I just bought new Cross drilled and slotted rotors w/powerstop pads off Epay and got them Friday, did not have time to do them yet so this post was great timing thanks again and good write up!!! |
| Nation Affiliate Join Date: Feb 2011 Location: Niagara Falls, NY
I'll be doing my brakes next month for the first time, thanks for the write up its gonna come in handy.
| Premium Member | Re: How To: Replace your rotors
how much different is this from doing a 4WD? is it just the axle nut that has to come off?
| New To The Nation Join Date: Feb 2009 Location: Shady Dale, Georgia
Question: I'm currently doing mine right now and the 6 nuts that are on the front of the rotor won't come off, but it is hard to get a good turn cause the whole thing spins with it. I'm wondering what is the easiest way to be able to get a good turn on them?
__________________ Michael (aka Lil' Mike) Georgia Southwestern State University Class of '11 |
| | #14 | |
| Nation Affiliate | Re: How To: Replace your rotors Quote:
![]() How To: Remove Hub & Rotor for 2wd Z85 brake change
__________________ Florida Members: Join our chapter and map to help get a few meets going: http://forum.florida355.com/showthread.php?t=1884 | |
| | #15 | |
How To: Front Hub/Wheel Bearing Replacement
| Re: How To: Replace your rotors Thanks buddy! I should have thought of that..
| | #17 | |
| 3'' of glory | Re: How To: Replace your rotors Quote:
| New To The Nation Join Date: Jul 2009 Location: Rochester, NY
Great post. You really helped me out! Just a warning to others that have to replace the rotors: It's a gigantic pain in the a$$ and set your entire day aside if you want accomplish it.
| USDM ??? | Re: How To: Replace your rotors
Im looking into doin brake performance rotors, how much abuse with the hub take if i have to beat them off the truck. I spray the backsides with penetrant any chance i get hoping it helps. But I wanna know would it be worth having extra hubs and sensors just in case or can it be done without breaking shit ?
__________________ ![]() YEA BUDDY! |
| New To The Nation Join Date: Jul 2012 Location: Topeka, Ks
Great write up! I love how Chevy decided to go all Toyota and require you to have to pull half the truck apart to swap rotors...def my least favorite part of this truck thus far
__________________ 2005 Colorado Xtreme Extended Cab: Halo projectors, Truxport cover, 6000k HIDs, Corvette 1-3 Servos, Tinted tails, 2" drop blocks, 20% tint 1989 GMC S15: 5.3LS, 4L60E, Caltracs traction bars and mono-leafs, 3.73's with Auburn Posi, LS6 intake, LS6 heads, comp hardened pushrods, comp dual valve springs, rocker bearing upgrade, custom grind cam |
| Tags |
| replace your rotors, rotor, rotor replacement, rotors |
