| Quadruple O.G. ![]() | How To: Shorten your stock antenna. Disclaimer The community here at 355nation.net urges you to please use caution and seek professional assistance when performing modifications to your vehicle. Before attempting any modification it is advised that you refer to your Colorado or Canyon service manual or contact a certified mechanic as not all GMT355 trucks are the same. The staff and the associated members are in no way responsible for any damages, injuries or other harm inflicted to your vehicle or yourself which may result in attempting these modifications. The posts and content presented on this site reflect in no way the views of 355nation.net or it’s ownership. ![]() A 355nation How To presented by brewer15650 Project Name How To: Shorten your stock antenna. Project Description Shortening your factory antenna to a reasonable size while retaining the factory ball and factory look. Skill Level Easy/Noob Project Vehicle Make: Chevrolet Model: Colorado Year: 2004 Engine: 3.5L Power windows: Yes Sun Roof: No Tools Needed Vise Grips, Utility Knife, 8mm Wrench, Hack Saw, Sand Paper, Black Spray Paint and Epoxy or Super Glue. Project Time 1 hour or less Project Cost Effort **Warning** Your stock antenna could be seized and or rusted together at the base and possibly could break off when removing. First remove your stock antenna via an 8mm wrench. ![]() ![]() ![]() Using a razor blade knife cut through the coating below the antenna ball. Make sure you go all the way around the ball. ![]() Take your vise grips and lock them on to the ball....just tight enough to get the job done. The blue painters tape is on the jaws to keep any marks down to a minimum that the vise grips might leave. ![]() Use the 8mm wrench on the end of the antenna to hold it while you twist the ball off the end using the vise grips. ![]() The ball should just twist right off. ![]() ![]() Measure how much you would like to remove and make your cut using a hack saw. Please take note that the shorter you make the antenna the worse your radio reception will be. I usually cut just enough off the top of the antenna to be level with the roof of the truck. ![]() ![]() Now you will have to taper the end of the freshly cut antenna so the ball will press back on. The top one is the Factory end and the freshly tapered end is the one on the bottom. ![]() Epoxy or Super Glue the antenna ball back on. You can use the vise grips to hold the ball and twist it back down on the end of the cut antenna. ![]() Ball glued on and excess epoxy wipe off. ![]() Sand out the vise grips marks and then mask off a few inch's of the antenna. ![]() Shoot 2 light coats of gloss black paint on it and leave it dry for 5-10 mins and then remove the tape and dust on another coat of paint over lapping the masking line. ![]() After it drys....that's it. You just made your stock whip antenna into a factory looking shorty antenna. ![]() Last edited by brewer15650; 02-01-2010 at 10:49 AM. |
| The Wise OWL......... ![]() | How To: Shorten your stock antenna
__________________ 355NATION DONATIONS I North East Chapter of 355Nation - NEC355 ![]() ![]() Supermodulation Ported Throttle Body Exchange Service. MAKE HISTORY, BE THERE. 2012 USA SUPERMEET. Click Here to join! Last edited by brewer15650; 10-11-2009 at 09:12 PM. |
| Quadruple O.G. ![]() | Re: How To: Shorten your stock antenna. Thanks man, Yep wack it and cap it is faster. I learned how to to do this back when I had my 92 s10 and I prefer the factory look over the cap look. We just installed the one from the how to on covered'n' ink truck yesterday and it looked perfect. |
| Kentucky 295 Canada 205 | Re: How To: Shorten your stock antenna. Nice, just lost my rubber ap from NESM meet "free mod" from James, it stayed a good while but the carwash finaly got it this weekend. Gona do this soon. Good write up!
__________________ -Cowan Order DRL covers here > http://www.355nation.net/forum/class...rl-covers.html |
| Custom Title Garnered | Re: How To: Shorten your stock antenna. yeah mines still done from NESM.. I cut it there and when I got home I re did it and put the factory ball back on it nice write up! I need to do this to my S10
__________________ -Tribo |
| Nation Elite | Re: How To: Shorten your stock antenna. did you notice any difference in radio reception?
| Global Moderator ![]() | Re: How To: Shorten your stock antenna. nice write up.. i just took my antenna off never listen to the radio anyways
| Nation Elite | Re: How To: Shorten your stock antenna. nice . i remember when i cut down a cb antenna to use as a shorty antenna on my s10. easy as pie. |
| Custom Title Garnered | Re: How To: Shorten your stock antenna. Just did it to my S10's in like 10min ![]()
| Nation Affiliate | Re: How To: Shorten your stock antenna. i wud think a shorty wud be like 4-14"?
__________________ officially layd rails. |
| Custom Title Garnered | Re: How To: Shorten your stock antenna. shorty is anything shorter than it was stock
| Formerly JHartColorado Join Date: Sep 2008 Location: In the sticks
| Re: How To: Shorten your stock antenna. I did this to my antenna prob 2 years ago, i used the stock ball and cut it to 6". reception sucks ass but idc never listen to it anyway. Something i did that i thought looked better was take that wire wrapped around it off, it leaves a little indention where it wrapped around the antenna so i sanded it down to the metal and sprayed a few coats of black paint on it and it looks pretty good. just a thought for anyone who doesn't like the wire wrapping around the antenna.
__________________ JHART RIP Shane "SC" Christenson, you'll always be remembered. |
| | #13 | |
| Nation Affiliate Join Date: May 2008 Location: Kansas City
| Re: How To: Shorten your stock antenna. Quote:
Off topic, but Brewer, do you work for Smart Parts or something? Or possibly formerly worked at SP, as I understand they had a huge layoff... | |
| | #14 | |
| Quadruple O.G. ![]() | Re: How To: Shorten your stock antenna. Quote:
Yes I did....I was just laid off. | |
| Nation Affiliate | Re: How To: Shorten your stock antenna. |
| Custom Title Garnered | Re: How To: Shorten your stock antenna. Fuuuuuuuuuuck man! sorry to hear!
| Kentucky 295 Canada 205 | Re: How To: Shorten your stock antenna. finished mine today, Thanks Brewer ![]()
| Nation Affiliate | Re: How To: Shorten your stock antenna. how did yall taper the end again? j.w |
| Kentucky 295 Canada 205 | Re: How To: Shorten your stock antenna. I used a 1" table top belt sander. it dosn't need alot tho.
| Nation Advocate | Re: How To: Shorten your stock antenna. Cool, i got the XM thing going anyway, I'll hack a lil off the top to flush it with the roof line. People who have no idea will have no idea, but those who know... well they know bra! And they see that shit. |
