How to: Replace your alternator - Chevrolet Colorado & GMC Canyon Forum
Go Back   Chevrolet Colorado & GMC Canyon Forum > 2004-2012 Chevrolet Colorado Forum / GMC Canyon Forum - First Generation Tech Area > How-To/Tutorials/Reviews/Service Bulletins > How-To: Lighting & Electrical
Old 10-03-2010, 03:36 AM   #1
Really Colorado Obsessed!
TOTM Winner  Lifetime Contributing Member  How-To CM  Calendar Spread
Zeuce's Avatar
Zeuce
How To replace your alternator
Moderate
Make: Chev
Year: 2006
Engine: 3.5L w/AC
Power windows: yes
10mm, 13mm, 15mm sockets, 3/8 rachet, screwdrivers, dielectric grease
1 hour or less
$300 ish or so for a new Alt and some sweat
Step one and this is the most important step, Disconnect your Battery. Remove the serpentine belt. You will see a hole for a 3/8 rachet in the tensioner body. It helps to take note of the belt routing too
Then remove your drivers front inner fender plastic. You will gain access to the lower mounting bolt and connections. Itll look like this:
Disconnect the power wire and the harness connector.
Remove the lower alternator mounting bolt.
And then move to the engine bay and remove the two top alt. mounting bolts.
Now position the alternator away from the block so you can gain access to the engine support bracket bolt located just in front and below of the fuel line.
with the rear bolt removed, remove the two bolts and the hold down for the AC pipe and unclip the wire harness retainer from the bracket. Remove the bracket.
For those of you that have the stock fan setup you will have to unbolt the AC compressor from the block (do not disconnect the refridgerant lines) and move it just enough to take the alternator out the back and through the fender. For those of you that have an Efan like me its a little simpler!
rotate the alternator as shown and with a little wiggling of the AC pipe, it comes right out the front
Make sure your replacement alternator has a pully with the same number of grooves, then just do the reverse to install your new Alt. I suggest a dab of dielectric grease on the harness connector on reinstall. The part number for the part I happened to use is in this pic.
LOL do you think the mud had anything to do with it!!!! LMAO only 48000 kms
Join the fun north of the border!______www.canada355.ca_____________CLICK IT!
4" skyjacker 3" BL 33x1250R18 way too many mods to list!
Zeuce is offline   Reply With Quote
Old 10-03-2010, 01:56 PM   #2
Quadruple O.G.
355 O.G.  TOTM Winner  Nation Elite  Contributing Member  Nation Advocate  Calendar Spread  355 Celebrity  NESM 08  NESM 09
brewer15650's Avatar
Re: How to: Replace your alternator
Very useful How To....Thanks alot man!
MY Album SINSITY KUSTOMZ Steel Rivers 355 yo!
brewer15650 is offline   Reply With Quote
Old 10-03-2010, 02:23 PM   #3
Hybrid
TOTM Winner  Nation Elite  OG Lifetime Contributing Member  How-To CM  Calendar Spread  355 Celebrity  355Loyalty  100K  USASM2012  WCSM 10  WCSM 2014
dents-n-dings's Avatar
Nicely Done!!
Originally Posted by royrjs View Post
Bitches love gear swaps.
.................................................. .............................BBB crew...all day, every day.
dents-n-dings is offline   Reply With Quote
Old 10-03-2010, 02:49 PM   #4
355Nation Moderator  Military Service  Chapter Founder  TOTY  TOTM Winner  Nation Elite  OG Lifetime Contributing Member  How-To CM  SuperMeet Organizer  Nation Advocate  Calendar Spread  355 Celebrity  MTS  Skitz Award  355Loyalty  100K  NESM 09  NESM 2013
Excellent job!
Thanks for the addition!
Old 10-03-2010, 02:50 PM   #5
cdk
Nation Elite  Lifetime Contributing Member  Calendar Spread  355Loyalty  TXSM 11  TXSM 2015
Good writeup. I found that pulling off the battery gave plenty of room with my I4 to pull the alternator out the side there. I already had the battery box out and a redtop Optima in its place, so it was quick.
cdk is offline   Reply With Quote
Old 10-03-2010, 04:12 PM   #6
Zeuce's Avatar
good point regal89cdk. thanx guyz! I didnt see a write up on this so I ported it from C355
Old 10-03-2010, 05:01 PM   #7
Members Technical !@#!@#!@#!@#!@#
Nation Elite  Contributing Member  How-To CM  Calendar Spread  355 Celebrity  MTS  100K  SESM 09  SESM 10  TXSM 11
Slo86GT's Avatar
Nice write up. I had to do this on my truck at 35k miles. The DIC was showing CHECK VOLT or something like that. Turns out one of the fingers in the alternator was cracked and at high RPM's would short to the case, making a squeeling noise over 4500 rpm, and voltage would bypass the regulator. I'm lucky the 20+ volts I saw on my meter didn't kill a lot of stuff on the truck. The dealer refused to warranty it, called my driving "abusive" and said bring it back when you have problem driving like a normal person. WTF right?
I did not go through the fenderwell, but this method does have some easily noticeable advantages. I pulled the upper fan shroud (was able to put the alternator between the blades to pull it out), the factory engine lift bracket, and alternator without having to remove the AC compressor or anything else really.
Nice work!
- Jody -
Knowledge and finger vomit are easily confused over the internet.
Slo86GT is offline   Reply With Quote
Old 10-03-2010, 05:03 PM   #8
I would go nuts working on a motor that dirty though
Old 10-03-2010, 05:56 PM   #9
Did this twice with the oem fan and was a PITA. Good job on the How-to!
Old 10-03-2010, 06:50 PM   #10
Zeuce's Avatar
I hear you there. my last 355 was a spit n polish show truck (see avatar), this one however.......lol
Old 10-03-2010, 07:00 PM   #11
2009 3LT ZQ8 5.3L V8
rshadd's Avatar
Down here in the states we have this cool stuff called soap and water. Wash that thing before to take any more pics. j/k Good write-up and thanks for your contribution.
rshadd is offline   Reply With Quote
Old 10-03-2010, 07:09 PM   #12
Military Service  Chapter Founder  Lifetime Contributing Member  Public Service  355Loyalty  NESM 16
xscott71x's Avatar
If/when my alternator goes out ::salt over shoulder:: which brand/amperage output would be a good upgrade for an '05 I5 with a +/- 700W stereo amp and a planned eFan upgrade?
VA355, PNW355, FL355, Capitol Chapter
xscott71x is offline   Reply With Quote
Old 10-03-2010, 07:33 PM   #13
I fucking atoadaso!
Chapter Founder  Nation Elite  Contributing Member  How-To CM  Calendar Spread
BMFP's Avatar
Thanks for the write up man, if the alternator is running $300 bucks im hopping i dont have to do tis for a while though
BMFP is offline   Reply With Quote
Old 10-03-2010, 09:05 PM   #14
Military Service  Contributing Member  Public Service
Dirigo355's Avatar
Nice job on the pics and write up!
Dirigo355 is offline   Reply With Quote
Old 10-03-2010, 09:20 PM   #15
Damn, me and yellowrad were just talking about this just yesterday! I didnt realize it was so intensive! Oh well, hope I dont have to do this for awhile!
Old 10-04-2010, 12:28 PM   #16
Zeuce's Avatar
LOL please esplain dis soap thing! yeah Im gonna take the toothbrush to her one day. just my way of showin you guyz she aint no pavement princess I guess hahaha!
Old 10-04-2010, 12:30 PM   #17
Zeuce's Avatar
PM kaelshort. just after I posted this on C355 he put a larger output on his. Im still waiting on info and pics from him then I was gonna update the info
I think our oem alt can handle quite a bit I run alot of lights, stereo and toys in the cab and an efan with no probs. I also run a red top too. I think the hood deep muddin Ive been doing is what killed it tho LOL
Old 11-27-2010, 02:40 AM   #18
truck built on Saturday..
Nation Elite  Contributing Member  100K
iDomin07's Avatar
FACKIN A!!! sweet deal this will help me tomorrow! Thanks!!
---------------------------CAROLINA CHAPTER ---------------------------
Originally Posted by mwcky2204 View Post
All the pavement scrapers are out killing manhole covers and rail road crossings, they will help you out soon....hang in there.
From // 5/6 \\ to 3/4 drop. SO COMFY!!!
From 235-55-18 to 245-45-18= NO RUB NO SCRUB
.....peace and quiet.....
No more flowmaster = Peaceful ride!!!!!
iDomin07 is offline   Reply With Quote
Old 11-13-2011, 04:10 AM   #19
great how-to! thanks a lot!
buzik19 is offline   Reply With Quote
Old 06-22-2012, 11:27 PM   #20
I just finish doing the alternator, all can be done from the top did it in about 1 hr. not a hard job at all.
cubican is offline   Reply With Quote
alternator , chevrolet colorado , gmc canyon , howto , replace
