How To: Install HID kits - Page 5 - Chevrolet Colorado & GMC Canyon Forum
Go Back   Chevrolet Colorado & GMC Canyon Forum > 2004-2012 Chevrolet Colorado Forum / GMC Canyon Forum - First Generation Tech Area > How-To/Tutorials/Reviews/Service Bulletins > How-To: Lighting & Electrical
LinkBack (6) Thread Tools Search this Thread Display Modes
Old 02-10-2011, 02:47 AM   #81
Formerly Metal_EMT
Lifetime Contributing Member  How-To CM  Public Service  Calendar Spread  355Loyalty  200K  NESM 10  NESM 11  MESM 11
HK_Titan's Avatar
Re: How To: Install HID kits
They do have mounting brackets now, that would have been helpful when I installed mine. $4 isn't bad either.
2004 Colorado LS Ex. Cab Z71
~Dan Formerly Metal_EMT
Originally Posted by Moto
All thanks to a finicky drive by wire system with more PCM's, BCM's and PMS than the fuckin space shuttle.
HK_Titan is offline   Reply With Quote
Old 02-10-2011, 02:53 AM   #82
NESM 09  NESM 10  NESM 11
dandy36's Avatar
i just received and installed a set of replacement HID bulbs from ddm tuning. i ordered bulbs for my lows and fog lights. 9006 for the lows and 9005/9045 for the fogs. ddm is now shipping a hybrid 9005/06 bulb fits in both the fogs and lows. if i encounter any problems with the install, i'll be sure to post up.
dandy36 is offline   Reply With Quote
Old 02-10-2011, 01:08 PM   #83
SCSM2012
ced_56's Avatar
They had plenty of the slim ballast when I went into the store and picked them up. I would suggest calling them to confirm. I had ordered the Raptor kit for pickup originally and when I got done there they told me the raptor kit was backordered. Even though the site and my order confirmation said nothing about it being back ordered.
09 CrewCab 2.9l, K&N Intake, Debadged, Silverado tailgate bowtie, blacked out dash (using all factory black pieces), magnaflow, SMaxx spacers, Shackles, 31s on stock 09 Z85 rims, tune
Originally Posted by Aquivarious View Post
If there's a will, there's a sawzall.
ced_56 is offline   Reply With Quote
Old 02-10-2011, 09:56 PM   #84
bwienke's Avatar
Ok thanks that helped a lot. It'll probably be a few weeks before I order mine anyway.
Would you recommend getting the mounting brackets?
Brayden Wienke
2006 Colorado, Silver Birch, z85, Crew Cab, added fog lights, HIDs to lows and fogs, tonneau cover, custom tow hooks, AEM CAI, 2.5inch Add a Leaf, cranked tbs 2 inchs, hopefully more to come.
bwienke is offline   Reply With Quote
Old 02-11-2011, 05:33 AM   #85
355Loyalty  100K
JakeF150's Avatar
I used industrial velcro from Lowes. 2x4 inch. Clean area with Simple Green. Apply to ballast, while together, then remove film on back and press to metal. Not sure the glue will not come off before the velcro will give so removing after install might be fun, lol.
Shop VELCRO Black Industrial Strength Strips at Lowes.com
But then again, the brackets are $4, so why not.
2009 Colorado Ext 3LT Sport 2WD 5.3L V8, Black Granite Metallic
home.comcast.net/~JakeF150/album/sig_bug.gif
JakeF150 is offline   Reply With Quote
Old 02-12-2011, 03:20 AM   #86
Formerly Metal_EMT
HK_Titan's Avatar
I got those bulbs to use in the lows and highs. I thought I got 2 9005 kits. Spoke with them to confirm and they work as both. They worked fine.
I personally used a good number of zipties on mine, mounting brackets would have been cleaner. (not that the rest of my under hood is mud free or anything.)
Old 02-28-2011, 07:42 PM   #87
tylergrgg's Avatar
im just kinda hoping in here but i just went to my local light guy got two kits for 40 bucks total plus some jdm as fuck bulbs for my hellas and just threw it all in the same way i did on the si and the z with out taking anything apart, no cutting, and not unscrewing anything. oh and the ballasts i just threw on the battery cover and my intakes heat sheild with some double stick tape
tylergrgg is offline   Reply With Quote
Old 05-16-2011, 11:26 PM   #88
Contributing Member  How-To CM  SuperMeet Organizer  USASM2012  USASM14
07_ZQ8's Avatar
I put 9005's in my non extreme fog housings and the bulbs are a little loose in the socket, I need to find a way to shim them up or make them a little more snug fitting in the housing cause it makes them all out of adjustment since they can move just a little bit. also, my 9006 low beams look like they move around sometimes when Im parked when they are on lol
Victory Red ExCab 2007 Canyon ZQ8
http://i41.photobucket.com/albums/e285/r_cracer65/signew_zps54bdc035.jpg
07_ZQ8 is offline   Reply With Quote
Old 08-04-2011, 09:51 PM   #89
Well, I new here but I've got some hints on the high beams...
How often do you actually use them? With HID's, both stock and non stock in my last 4 cars I've never bothered with high beams.
My mini cooper S had OEM HIDs, if you switched to high beams they were just a halogen bulb, and hardly worth using.
My Silverado had a 6000K aftermarket HID kit and I dont even know if it had high beams bulbs, but the truck was lifted 13", so I could never tell.
My wifes Nitro has an aftermarket HID kit (12000K) she chose the color, but its not as horrible as I said it would be. But that kit came with a tiny bulb attached to the back of the HID thats kinda sad, but it does light up when you hit the high beams..
I guess the point is, high beams take awhile to warm up, and most of the time by the time they do warm up its time to turn them back off.
79cutlas is offline   Reply With Quote
Old 08-05-2011, 04:41 PM   #90
Military Service  Contributing Member
barman84's Avatar
Pop off the adapter on the back part of the bulb it should just unsnap and get some plastic solo cups cut the bottom to fit the adapater nice and tight then put a cutout for the bulb and wires to poke through in the middle. Take your bulb with the cup bottom inserted and insert your bulb snap your backing plate aka adapter plate back onto the housing I gaurantee you it will be tight as all getout. Plus you get a little more water protection
barman84 is offline   Reply With Quote
Old 08-05-2011, 11:47 PM   #91
SESM 11  SESM 2013  SESM 2014  SESM 2015  SESM 16  CFSM 2016
bryanks's Avatar
I installed my ddm hid kit this morning, man what a difference. Like night and day. I got the 35w 5000k for the lows. I test drove it a little while ago, and everyone thought I had my brights on, till I flashed them. You can see what seem like forever straight out, so powerful, so bright. This is the best mod I ever done, to any of my trucks. Money very well spent. Im already looking at the highs, then fogs.
bryanks is offline   Reply With Quote
Old 08-06-2011, 12:32 AM   #92
MotorCityRado's Avatar
the highs are pretty much useless after the brightness of the lows and fogs IMO, but also make sure you adjust them correctly. my adjusment was off a little and I corrected it tonight and even that made a hell of a difference.
MotorCityRado is offline   Reply With Quote
Old 08-06-2011, 10:21 AM   #93
Formerly Metal_EMT
HK_Titan's Avatar
highs are pretty much useless unless there is NO traffic for a long time. By me, if there's no cars and i hit the highs, then by the time the highs are charged up, there's a car and I have to shut them off again. I do have the high/low mod done so I dont lose my lows when I switch and have everything go dark on me.
Old 09-02-2011, 12:22 AM   #94
OzzMang149's Avatar
I installed my DDM Hids a couple days ago. I Love them except when im using the high beams I keep blowing fuses. they will run for an hour or so then fuses blow. Ive done the high low beam mod, I thought it might be that so reinstalled the halogen high beam lights and no problems with blowing fuses. Anyone have an ideas?
OzzMang149 is offline   Reply With Quote
Old 12-29-2011, 12:07 PM   #95
BKlat's Avatar
Where does everyone get their HID kit from? Want to get the same that everyone is using and don't have problems with. Thanks in advance.
BKlat is offline   Reply With Quote
Old 12-29-2011, 12:18 PM   #96
Ddmtuning is where the majority of people got theirs but ddm has become slow lately so people are starting to get kits from ebay
http://i246.photobucket.com/albums/gg111/myslowv6/SDC10657-1-1-1.jpg
Lil Black Truck is offline   Reply With Quote
Old 12-29-2011, 12:21 PM   #97
BKlat's Avatar
Thanks. I've seen some on eBay but wasn't sure how good they actually were. And if they just crapped out in 6 months. I'll have to call them and see what time timeline is to getting them to my door. If not. Any idea what kind from eBay or member selling them?
Old 12-29-2011, 12:30 PM   #98
Use the search feature and look up hid kits and find one talking about kits from eBay. I'm not sure what companies are good but there has been some possitive reviews from people who got kits off eBay on here in the past week or so
Old 01-19-2012, 07:17 PM   #99
Nation Elite  Contributing Member  How-To CM  Calendar Spread
Buddy's Avatar
Ok so I just recieved my 8k hids for hi/low. Do I still have to do the reverse polarity?
Buddy is offline   Reply With Quote
Old 01-19-2012, 08:16 PM   #100
Contributing Member  How-To CM  Public Service  355Loyalty
jrotundo's Avatar
yeah you still have to reverse it
jrotundo is offline   Reply With Quote
chevrolet colorado , gmc canyon , hids , high intensity display , how to
LinkBack to this Thread: http://www.355nation.net/forum/how-lighting-electrical/73-how-install-hid-kits.html
Chevy Colorado & GMC Canyon • View topic - DDM Tuning HID kit lowered in price This thread Refback 01-01-2010 02:59 PM
Chevy Colorado & GMC Canyon • View topic - DDM Tuning HID kit lowered in price This thread Refback 07-19-2009 12:36 PM
Chevy Colorado & GMC Canyon • View topic - DDM Tuning HID kit lowered in price This thread Refback 07-17-2009 09:41 AM
Chevy Colorado & GMC Canyon • View topic - DDM Tuning HID kit lowered in price This thread Refback 07-15-2009 10:40 PM
Chevy Colorado & GMC Canyon • View topic - DDM Tuning HID kit lowered in price This thread Refback 07-08-2009 09:11 PM
Chevy Colorado & GMC Canyon • View topic - DDM Tuning HID kit lowered in price This thread Refback 07-08-2009 06:22 PM
Similar Threads
Thread Thread Starter Forum Replies Last Post
How To: Install Electric Fan rangerbob How-To: Performance & Maintenance 30 07-21-2013 12:04 AM
lowering kits. coronausmc Lowering 30 11-17-2007 09:59 PM
C04Z71 -- Supermodulation Interior & Exterior LED Kits Canyon08Z71 Exterior 15 11-08-2007 10:30 AM
Any one have a b/j install how to? echo2302 Lowering 7 09-24-2007 09:56 PM
