How to: Install A Ground Strap - Chevrolet Colorado & GMC Canyon Forum
Go Back   Chevrolet Colorado & GMC Canyon Forum > 2004-2012 Chevrolet Colorado Forum / GMC Canyon Forum - First Generation Tech Area > How-To/Tutorials/Reviews/Service Bulletins > How-To: Miscellaneous
Old 02-26-2010, 08:10 PM   #1
355 O.G.  Nation Elite  Contributing Member  How-To CM  WCSM 09
SWEEETRUCK's Avatar
The community here at 355nation.net urges you to please use caution and seek professional assistance when performing modifications to your vehicle. Before attempting any modification it is advised that you refer to your Colorado or Canyon service manual or contact a certified mechanic as not all GMT355 trucks are the same. The staff and the associated members are in no way responsible for any damages, injuries or other harm inflicted to your vehicle or yourself which may result in attempting these modifications. The posts and content presented on this site reflect in no way the views of 355nation.net or itís ownership.
SWEEETRUCK
How-to Install a Grounding Strap
Reducing and eliminating static shock by adding a ground strap.
Easy
Year: 2004
Ground lug connector(can be found at local hardware store)
Grounding strap(can be found at local hardware store)
Flathead screwdriver
1 hour or less
$5.00
Why do we get shocked sometimes when exiting our vehicles? Static electricity is the answer! There is a build up of static electricity in your body and when you touch your door you create a complete circuit, which is why you feel a "zap" when touching the door. The static can build up due to something as simple as moving around on the seat. There are sprays that are suppose to remove static, there's the old trick of touching the car/truck key to the door and even rubbing laundry sheets over the seats to prevent getting shocked. By grounding the vehicle there is a complete circuit to the ground and no static will build up. My research has shown that the ground strap should be mounted at the rear of the vehicle against the frame. Since it has to be at the rear of the vehicle it is hard to conceal but one way to make it less noticeable would be to paint the strap black or get a sleeve for it. This mod will only cost a few dollars and will help you feel safer when exiting your vehicle.
ON my truck the spare tire is removed and there are a few pre-existing holes in the frame.
You may want to drill a hole somewhere else if you want to put it in a different spot ! I cleaned up the area to ensure a good connection and screwed it right in.
Make sure that the length of your strap is long enough to touch the ground. I like the end of mine to lay flat on the ground at the end, but when driving it floats in the air.
The time frame that the strap will need to be replaced depends on how often you drive.
It has been two weeks and mine shows signs of wear but it is still doing the job!
http://i57.photobucket.com/albums/g204/dclucas1/tayo.jpg
SWEEETRUCK is offline   Reply With Quote
Old 02-26-2010, 11:43 PM   #2
Quadruple O.G.
355 O.G.  TOTM Winner  Nation Elite  Contributing Member  Nation Advocate  Calendar Spread  355 Celebrity  NESM 08  NESM 09
brewer15650's Avatar
Re: How to: Install A Ground Strap
Silly Tayo in da house.....Thanks for the How To!
MY Album SINSITY KUSTOMZ Steel Rivers 355 yo!
brewer15650 is offline   Reply With Quote
Old 02-26-2010, 11:48 PM   #3
Nation Elite  Contributing Member  How-To CM  Calendar Spread  355 Celebrity  100K  SESM 09
swamp_rat's Avatar
wonder how many people said "hey dumbass you have a wire hanging!" or similar lol. nice write up. if i wouldnt mind stuff hanging id do it.
well......
swamp_rat is offline   Reply With Quote
Old 02-26-2010, 11:59 PM   #4
RIP Forrest
Nation Elite  Contributing Member  355 Celebrity  TXSM 10  TXSM 11  TXSM 14
Undead Rado's Avatar
im shocked there is anyone with this and even more that there is a how-to, i work with 80,000 volts daily, if someone is killed from a static shock from a car i want to see it, and the gas pump crap has pretty much been tossed out already
Undead
Undead Rado is offline   Reply With Quote
Old 02-27-2010, 12:25 AM   #5
Great write-up. This does work!
Old 02-27-2010, 12:38 AM   #6
Military Service  Contributing Member  How-To CM  Public Service
k.jward88's Avatar
People and clothing (wool, tayon, and synthetic materials) accumulate static charges, also. For example, Nylon has been found to generate up to 600 volts potential. Simply walking across a carpet floor can generate up to 7,500 volts potential. These charges can discharge through clothing, skin, tools, and equipment as they come in contact with items in the fuel system.
This came from my CDC's, since i deal with Jet Fuel (JP-8) everyday.
k.jward88 is offline   Reply With Quote
Old 02-27-2010, 12:40 AM   #7
RIP Forrest
just open the gas door and take off the gas cap first, grounds it out and elinimates need for a strap hanging on the ground looking ridiculous
Undead
Old 02-27-2010, 12:41 AM   #8
RIP Forrest
or when u shut ur door push the metal part or really touch and part of the truck
Undead
Old 02-27-2010, 12:43 AM   #9
k.jward88's Avatar
as long as you touch bare metal when filling up, u are already grounded.
Old 02-27-2010, 12:50 AM   #10
RIP Forrest
i just dont see the point, you mine as well wear di-electric overshoes and an insulated tobbagon all the time for fear of lightning strike because the statistics are about the same
Undead
Old 02-27-2010, 12:51 AM   #11
Military Service  Nation Elite  Lifetime Contributing Member  SuperMeet Organizer  Public Service  TXSM 10  TXSM 11  SCSM 2013
DirtyBoy's Avatar
well, this is most commonly used for plant workers that deal with hazardous material everyday... again with truck drivers who transport fuel or other flammable material... but its a nifty way to not get shocked if you dont like it, personally i think static shock is hilarious and funny to shock someone else
DirtyBoy is offline   Reply With Quote
Old 02-27-2010, 12:55 AM   #12
Bones
sooooo if my frame actually touches the ground does that count? hahahahaha
teckn9ne is offline   Reply With Quote
Old 02-27-2010, 12:56 AM   #13
RIP Forrest
nothing in the write up mentions hazmat, just static shock and i have yet to see a hazmat truck with anything similar.
Undead
Old 02-27-2010, 12:57 AM   #14
RIP Forrest
haha ya just drag to a stop to keep from getting a tiny shock
Undead
Old 02-27-2010, 12:58 AM   #15
Bones
Hey im not gonna lie it does drive me crazy, I have electrical tape wrapped around the metal pullstrings on my ceiling fan...
Old 02-27-2010, 01:00 AM   #16
RIP Forrest
well its dry as shit most of the time in tulsa. the humidity here pretty much eliminates it.
Undead
Old 02-27-2010, 01:33 AM   #17
Formerly Metal_EMT
Lifetime Contributing Member  How-To CM  Public Service  Calendar Spread  355Loyalty  200K  NESM 10  NESM 11  MESM 11
HK_Titan's Avatar
One alternative if you have a passenger in the truck. ALWAYS let them get out first. lol.
2004 Colorado LS Ex. Cab Z71
~Dan Formerly Metal_EMT
Originally Posted by Moto
All thanks to a finicky drive by wire system with more PCM's, BCM's and PMS than the fuckin space shuttle.
HK_Titan is offline   Reply With Quote
Old 02-27-2010, 09:57 AM   #18
Quadruple O.G.
No where in the how to does it say this is to prevent a death from static shock, blowing up at the pump or lightning strike's so why are you ranting about this?
The point is...Getting zapped when getting out of your truck is annoying to some people and there wife's and this is a simple fix for it.
Old 02-27-2010, 09:59 AM   #19
gridracer's Avatar
Send a message via AIM to gridracer
In my 21 years of driving I have never gotten a shock while getting out of my vehicle. I agree with undead rado would rather get shock than have some ridiculous looking strap hanging from my truck.
gridracer is offline   Reply With Quote
Old 02-27-2010, 10:14 AM   #20
Quadruple O.G.
Thats fine.....its called your opinion but he doesnt need to be in here trolling. Its actuley a pretty common thing...
Chevy Colorado & GMC Canyon • View topic - Static shock when exiting my Colly..
Chevy Colorado & GMC Canyon • View topic - Static Electricity/Trailing Grounding Strip
Chevy Colorado & GMC Canyon • View topic - The shocker!!!
It happens to me a good bit during summer but it doesnt bother me enough to do. It doesn't look attractive but does it do the job....yes.
ground , ground strap , strap
