How-To:Install Corvette Servos and Billet Overdrive Servo - Page 2 - Chevrolet Colorado & GMC Canyon Forum
Go Back   Chevrolet Colorado & GMC Canyon Forum > 2004-2012 Chevrolet Colorado Forum / GMC Canyon Forum - First Generation Tech Area > How-To/Tutorials/Reviews/Service Bulletins > How-To: Performance & Maintenance
Old 09-02-2010, 01:51 AM   #21
Contributing Member  How-To CM  Calendar Spread  355Loyalty  100K  SESM 10  SESM 11  SESM 2013  SESM 2014  SESM 2015  SESM 16
Matt Shadow's Avatar
Send a message via MSN to Matt Shadow
Re: How-To:Install Corvette Servos and Billet Overdrive Servo
The purpose of the vette servo mod is to allow the transmission to shift more quickly and efficiently from first to second gear. From the factory, the truck 4L60e's have a smaller servo. The servo is used to apply the 2-4 band in the transmission. Upgrading to the vette servo gives the trans more "holding" power and thus yields a quicker/firmer shift. Adding a vette servo has also seemed to cause some folks 1-2 slipping to cease.
found this explanation on a full size forum...it pretty much sums it up.
Matt Shadow is offline   Reply With Quote
Old 09-02-2010, 01:54 AM   #22
nice how-to btw matt
Lil Black Truck is offline   Reply With Quote
Old 09-02-2010, 01:54 AM   #23
yeah slipping is bad to a point, but a nessary evil to ensure the correct operation when it comes to shifting. Plus it helps the fluid last longer since it doesnt get as hot from the slipping. But just barely. main thing is less slipping means less wear on the bands.
Old 09-02-2010, 01:56 AM   #24
thank you
Old 09-02-2010, 02:01 AM   #25
Public Service  Calendar Spread  100K  USASM2012  TXSM 10
olds88's Avatar
ya but i waited to long it slips if i put my foot in it its ok ill rebuild it to better specs
Originally Posted by ced_56 View Post
Was nice meeting everyone. Even Mr. Ass
go have a can of man the Fuck up.
Rip forrest
olds88 is offline   Reply With Quote
Old 09-02-2010, 02:06 AM   #26
that aint the tourqe converter?
Old 09-02-2010, 02:06 AM   #27
Chapter Founder  Nation Elite  Contributing Member  How-To CM  Calendar Spread  355Loyalty  100K  USASM2012  USASM14  SESM 11  TXSM 11
blueradoxtreme's Avatar
Cool write up. Thanks
blueradoxtreme is offline   Reply With Quote
Old 09-02-2010, 03:36 AM   #28
Military Service  Contributing Member  Public Service
Dirigo355's Avatar
Nice job on the write up.
Dirigo355 is offline   Reply With Quote
Old 09-02-2010, 11:58 PM   #29
brady's Avatar
where did you buy the 1-2-3 and the OD servos?
brady is offline   Reply With Quote
Old 09-03-2010, 01:26 AM   #30
Ebay. cheapest place to get them that I could find. Just look for servos for a 4L60e transmission.
Old 09-03-2010, 01:46 AM   #31
I looked and the cheapest I could find the 4th gear servo was like 70 dollars
Old 09-03-2010, 07:15 PM   #32
brady's Avatar
you wouldnt happen to have a link would you?
Old 09-03-2010, 09:10 PM   #33
2009 3LT ZQ8 5.3L V8
rshadd's Avatar
4L60E 700R4 4L80E 4R100 E4OD 2004R C6 TH350 TH400 Transmission Parts: SUPERIOR 700R4/4L60E BILLET 2ND GEAR SUPER SERVO
4L60E 700R4 4L80E 4R100 E4OD 2004R C6 TH350 TH400 Transmission Parts: SUPERIOR 700R4/4L60E BILLET SUPER SERVO 4TH APPLY PISTON AND COVER
4L60-E Super Servo Instructions
4th Apply Piston & Cover Instructions
rshadd is offline   Reply With Quote
Old 09-05-2010, 02:42 AM   #34
As someone who has done this mod already, this How To is vague in certain critical areas.
For example, once you remove the stock servos and pin, some dissasembly/assembly is required. If you are only replacing one servo instead of both, the procedures are slightly different. There are also factory springs that get replaced.
Members who aren't knowledgeable might incorrectly assume this is a simple plug and play mod. If you can change your sparkplugs, you can change your servos, provided you pay attention to detail.
Both the Superior and JET brand servos come with detailed instructions and pics.
In addition, Superior has you check the free play movement of the servo pin once everything is back together. If there is too much play, you install the pin extender included in the kit. if there isn't enough free play, you grind the end of the pin.
This mod certainly isn't rocket science, but if the servo assemblies are not put together correctly you will have serious shifting issues.
My advice: order the servos, read the install instructions several times before starting, take your time, and enjoy the results.
All the part numbers and servo websites are listed here: http://www.355nation.net/forum/engin...rade-info.html
Old 09-05-2010, 04:41 AM   #35
Military Service  Nation Elite  Contributing Member  How-To CM  355Loyalty  100K
Freewood's Avatar
Send a message via Yahoo to Freewood
How did you go about compressing the back of the 2nd piston to pull the big snap/c-clip out to switch the cover and big spring to the new piston?
_._._.._____
.. _____|___\_____
. |_(O)_|____/_(O)|
Freewood is offline   Reply With Quote
Old 09-05-2010, 07:28 AM   #36
C-Clamp.
Old 09-05-2010, 10:42 AM   #37
Freewood's Avatar
I didn't think of that. I used a big socket and the table vise
_._._.._____
.. _____|___\_____
. |_(O)_|____/_(O)|
Old 09-05-2010, 10:45 AM   #38
rshadd's Avatar
What does a transmission shop to charge for the installation?
Old 09-05-2010, 10:49 AM   #39
I have seen $100+ or over charge for a simple job to say the least!
Old 09-12-2010, 11:00 AM   #40
rshadd's Avatar
I'm having my servos installed this week. The installation quote was in the $150-180 range. While I think that's on the high side, this transmission shop comes highly recomended from someone I trust. I'll post up a review once they're installed and I've had a chance to play.
