How To: Clean Your Mass Air Flow Sensor - Chevrolet Colorado & GMC Canyon Forum
Go Back   Chevrolet Colorado & GMC Canyon Forum > Tech Area > How-To/Tutorials/Reviews/Service Bulletins > How-To: Performance & Maintenance
LinkBack (3) Thread Tools Search this Thread Display Modes
Old 04-02-2007, 01:36 AM   3 links from elsewhere to this Post. Click to view. #1
The Top Gun
How-To CM
Maverick's Avatar
A 355nation (CCP) presented by
Maverick/econobarn
How-To: Clean Your Mass Air Flow Sensor
A mass airflow sensor is used to determine the mass of air entering the engine. The air mass information is necessary to calculate and deliver the correct fuel mass needed by the engine. There are two common types of mass airflow sensors in usage on gasoline engines. They are the vane meter and the hot wire; our trucks have a hot wire sensor.
If the mass air flow sensor becomes dirty it can no longer tell the engine how much air is really getting in. If the engine doesn’t know how much air is coming in it doesn’t know how much fuel to inject into the cylinder. This can cause the engine to idle funny and not get enough fuel which is also called running ‘lean’. Running lean can cause excessive combustion temperatures and lead to engine damage or destruction. Most problems are from "oiled" element air filters such as K&N. More oil is not better on an air filter.
Easy
Model: Colorado Z71
Year: 2005
Engine: 5cly
Tool Needed
CRC Mass Air Flow Sensor Cleaner (DO NOT use carburetor cleaner or brake cleaner, those leave residue and will make the sensor in worse condition)
Ratchet with a 7/32 socket
15min or less
$5.00
The first thing you’ll need to do is locate the sensor. It is located in your intake tube right after the air filter. Your intake may look different.
Now that you have found it it’s time to disconnect it so it can be removed from the intake tube. Completely unplug the electrical connector.
With your ratchet remove the 2 screws from the intake tube.
Once the 2 screws have been removed gently lift the MAF out of the intake tube.
Take your can of CRC Mass Air Flow Sensor Cleaner and attach the red spray tube, this will ensure the liquid only goes where we want it to and not all over your hands and everything else in the area.
Hold the MAF by the top portion of the sensor and spray 10-15 short blasts into all of the openings. Make sure not to touch any of the wires or sensors inside the MAF with your fingers or the plastic spray tube, doing so will result in a broken sensor.
Now that you have soaked the MAF let it sit for 5-10 minutes to dry.
After it is dry simply put the sensor back into the intake tube.
Secure the sensor with the 2 screws you removed and plug the electrical connector back in.
With the sensor secured and plugged it’s now safe to start your truck. If the sensor was dirty prior to cleaning it you should notice a slight improvement in idle and in some cases the performance difference can be quite drastic. Try to clean your MAF with every air filter change or air filter cleaning if you have a cleanable air filter. For the guys who use a K&N filter I would clean it 100-200 miles after you clean your filter, that gives some time for the excess oil to dissipate.
Maverick is offline   Reply With Quote
Old 03-30-2010, 05:50 PM   #2
S.Shultz04's Avatar
Re: How To: Clean Your Mass Air Flow Sensor
Nice post, great directions!
S.Shultz04 is offline   Reply With Quote
Old 03-31-2010, 03:52 PM   #3
Contributing Member How-To CM SESM 11
colorado74's Avatar
nice post
2007 Colorado EC 3.7 Z85 / MBRP Side Cat Back / K&N CAI / Custom Dual Ram Air / Supermod PTB / 4 Door Blazer Overhead Console / Kenwood BT838U Deck / Kicker 5 channel 1000 watt 08ZX7005 / 2 Pairs 6.5 Infinity Kappa Components / 2 JL 10w3 Subs / Large Flares / SSR 2.5" Lift/ Tuff Country AAL / 20" Chrome Granite Alloy GA4.6 Wheels / 275/55/20 Cooper Zeon LTZ
colorado74 is offline   Reply With Quote
Old 03-31-2010, 04:11 PM   #4
Contributing Member 355 Celebrity 100K
Mrbrock21's Avatar
Holy old thread batman!!! This was originally posted in 2007!
http://i55.photobucket.com/albums/g146/mrbrock21/0f5f7671.jpg
2005 Z85 - 5cyl
Mrbrock21 is offline   Reply With Quote
Old 08-27-2010, 11:05 PM   #5
Military Service Contributing Member Public Service
Dirigo355's Avatar
Didn't know anything about this but what a difference it made. Simple too! Thanks for the write up.
Dirigo355 is offline   Reply With Quote
Old 08-27-2010, 11:34 PM   #6
econobarn
Posts: n/a
you're welcome.
Old 09-03-2010, 02:26 PM   #7
MotorCityRado's Avatar
How do you know if the MAF sensor is broken? im gonna clean it soon but I do remember the first time I oiled my K&N I might of over done it which I NOW know is bad and can break the MAF sensor.
MotorCityRado is offline   Reply With Quote
Old 09-13-2010, 06:47 PM   #8
Military Service WCSM 10
craig6970's Avatar
Send a message via AIM to craig6970 Send a message via MSN to craig6970 Send a message via Yahoo to craig6970
Im going to clean mine tonight. I have 64K and never done it. It has been running a little rough. I did clean my throttle body recently
05 Colorado Z85 Summitt White ext cab 2.8L 2wd, power nothing but my arm
W/T model upgraded with Extreme wheels and DJM 4/4 drop and DDM HID's
craig6970 is offline   Reply With Quote
Old 09-13-2010, 06:51 PM   #9
Texas Yoda!!!!
Nation Elite Contributing Member SuperMeet Organizer Calendar Spread Skitz Award USASM2012 SESM 10 SESM 11 TXSM 10 TXSM 11
edvocho's Avatar
didn't even know there was a how to on this
||.:R.I.P Skitz 06/20/1984-06/27/2011:.||
Facebook 355Nation's Facebook Group
edvocho is offline   Reply With Quote
Old 09-13-2010, 07:01 PM   #10
Spoolin Jr. Survivor
Nation Elite 355 Celebrity USASM2012 TXSM 10
emaxxer's Avatar
It wont brake it but it can cause it to read inaccurately so if you just clean it every oil change or every other oil change, you'll be okay.
Mike B's 08 Colorado LT Z85 regular cab 3.7L auto 3.73 G80
e85 + 61mm
emaxxer is offline   Reply With Quote
Old 09-13-2010, 10:15 PM   #11
econobarn
Posts: n/a
I have pretty hands.
Old 05-25-2011, 09:39 PM   #12
STICKER BOMBS
Calendar Spread 100K
05 bow tie's Avatar
Send a message via MSN to 05 bow tie
ive talked to a guy at work about this cause i get a bit of rough idle myself where i feel it in my seat, but he says there is an after burner if u will that is supposed to burn off and clean itself do ares have that cause im gonna get at this this week and see
YEA BUDDY!
05 bow tie is offline   Reply With Quote
Old 05-26-2011, 01:37 PM   #13
Military Service
Korydogg's Avatar
Very good write up....gonna add this to my "to-do" list!
Korydogg is offline   Reply With Quote
Old 10-01-2011, 12:16 PM   #14
RIP-Forrest August(Skitz)
Military Service Nation Elite Lifetime Contributing Member Calendar Spread 355Loyalty
crazyeyez's Avatar
Send a message via AIM to crazyeyez Send a message via MSN to crazyeyez Send a message via Yahoo to crazyeyez
Nice write up. But, side note, my 05 3.5L uses allan key bolts, not socket head bolt to hold maf. not sure if thats a fluke or not.
Nick *CrazyEyeZ* >>> Nick's Build and console<<<.>>>VOTE FOR ME TOTM<<<
*2005 GMC Canyon CC Z71 4x4 3.5L 3.73 SuperMod PTB+SuperSparks K&N FIPK cat-gutted
2" SMAXX shackles, TB crank, Ranco shocks, diffdrop, Lund Tri-Fold, roofrack with 5 7" 24v LED offroad lights
SMaxx BullMaxx opt3, 2 KC DayLighter 130w longrange, 2 KC DayLighter 130w drivinglights, 150amp alt
*1997 Grand Am SE (*see album*) *2009 Harley Davidson Sportster Custom XL883C (few mods)
<CAP CHAP><GEORGIA355><REVIEW-LundTri-Fold><ROOF RACK REVIEW>
crazyeyez is offline   Reply With Quote
Old 10-28-2012, 12:03 AM   #15
Jeff_C's Avatar
Sorry to resurrect this, but as an FYI to newer members who may be searching for this how to, newer trucks have a different style MAF that is secured with two T20 torx screws.
Here are some pics showing the new style MAF:
Note vertical orientation of connector, and the T20 Torx screws:
Side 1:
Side 2:
Side 3:
"Looks like I picked the wrong week to stop sniffing glue."
Jeff_C is offline   Reply With Quote
chevrolet colorado, gmc canyon, how to, maf, mass air flow sensor
LinkBack to this Thread: http://www.355nation.net/forum/how-performance-maintenance/49-how-clean-your-mass-air-flow-sensor.html
Chevy Colorado & GMC Canyon &bull; View topic - Never Ending Check Engine Light Issues! This thread Refback 12-11-2009 07:18 AM
Chevy Colorado & GMC Canyon &bull; View topic - Never Ending Check Engine Light Issues! This thread Refback 11-04-2009 05:58 PM
Chevy Colorado & GMC Canyon &bull; View topic - Never Ending Check Engine Light Issues! This thread Refback 06-23-2009 08:25 AM
Similar Threads
Thread Thread Starter Forum Replies Last Post
How To: Install An O2 Sensor Non Fouler to Eliminate a Check Engine Light with Pics brewer15650 How-To: Performance & Maintenance 80 07-19-2012 06:25 PM
High flow cats EricW835 I4/I5 Engine & Drivetrain 18 10-02-2007 11:23 PM
map sensor.... Skizzo Tuning 21 09-16-2007 03:39 PM
injector flow rate? Carbon08 I4/I5 Engine & Drivetrain 2 09-05-2007 05:37 PM
O2 Sensor went bad..... JosueZQ8 I4/I5 Engine & Drivetrain 6 07-26-2007 11:43 PM
