How To: Install Fuel Pressure Regulator - Chevrolet Colorado & GMC Canyon Forum
Go Back   Chevrolet Colorado & GMC Canyon Forum > 2004-2012 Chevrolet Colorado Forum / GMC Canyon Forum - First Generation Tech Area > How-To/Tutorials/Reviews/Service Bulletins > How-To: Performance & Maintenance
Old 12-27-2011, 07:51 PM   #1
TOTM Winner  Contributing Member  How-To CM  SuperMeet Organizer  Calendar Spread  355 Celebrity  355Loyalty  100K  WCSM 2015  SCSM2012  SCSM 2013  SCSM 2014  SCSM 2015
slicksteveo13's Avatar
slicksteveo13
How to Install Fuel Pressure Regulator
Removing and replacing stock fuel pressure regulator
Easy
Make: GMC
Model: Canyon
Year: 2005
Socket Wrench
Socket Extension
T30 torque socket
Rag
30 Minutes or less
$50-$80 Fuel Pressure Regulator
GM Part #: 88984221 or ACDelco #217-1564
The Fuel Pressure Regulator is located on the front drivers side of the engine. The easiest way to find it is to follow the small vacuum hose from the intake to the top of the regulator (see the picture below). The part circled is the fuel pressure regulator found on '04 and '05 trucks. Starting in '06, GM started using a returnless fuel system and newer engines don't have this part.
I had been smelling gas in the cab in the morning on cold days and throughout the day depending on the temperature. I drove it one day and could really smell gas in the cab of the truck so I stopped and opened the hood and the fuel pressure regulator was cover in fuel.
This is what mine looked like (didn't get a picture of it covered in gas):
or like this (with credits from xkmacx86)
A way to test the fuel pressure regulator is to remove the hose from the top of the regulator that connects to the intake and start the truck and see if fuel is coming out of the top of the regulator. When you remove the hose and there is fuel in the hose the regulator is bad as well.
I bought a new regulator at NAPA for about $60.
Warning: Remove the fuel tank cap and relieve the fuel system pressure before servicing the fuel system in order to reduce the risk of personal injury. After you relieve the fuel system pressure, a small amount of fuel may be released when servicing the fuel lines, the fuel injection pump, or the connections. In order to reduce the risk of personal injury, cover the fuel system components with a shop towel before disconnection. This will catch any fuel that may leak out. Place the towel in an approved container when the disconnection is complete.
Then I used a T30 Torque bit to remove the two bolts holding the regulator in.
Remove the lower hose (the one with the bracket, first) watch when you disconnect the hose as gas will leak out.
Then pull the regulator out, watch out for gas coming out on this one as there is pressure behind the regulator. You can put a rag around the regulator so the gas does not spray every where.
Caution: Clean all of the following areas before performing any disconnections in order to avoid possible contamination in the system:
• The fuel pipe connections
• The hose connections
• The areas surrounding the connections
To install the new fuel pressure regulator the reverse of removal.
Torque Specs: Fuel Pressure Regulator Screw: 71 lb in
This fixed my issue with lack of power. When I step on the gas the truck gets up and goes again as well as no more gas smell in the morning
355NATION April 2012, December 2013, & May 2016 TOTM Winner
Slick and Dirty Motorsports Build Updates
slicksteveo13 is offline   Reply With Quote
Old 01-03-2012, 04:16 PM   #2
2009 3LT ZQ8 5.3L V8
rshadd's Avatar
Re: How To: Install Fuel Pressure Regulator
Nicely done Steven!
rshadd is offline   Reply With Quote
Old 01-03-2012, 04:17 PM   #3
MTS Crew!
Military Service  Nation Elite  Contributing Member  How-To CM  MTS  Skitz Award  100K  USASM2012  NESM 11  NESM 2013  SESM 10  SESM 11  SECSM2012  Skunkwerx Super Mod Meet 2015
thethein11's Avatar
Good to know thanks for the how to Steveo
- Billy
thethein11 is offline   Reply With Quote
Old 01-03-2012, 04:19 PM   #4
Thanks for the great how-to!
Old 01-03-2012, 04:50 PM   #5
The LED Dude
Nation Elite  Lifetime Contributing Member  How-To CM  355 Celebrity  MTS  Skitz Award  355Loyalty
captainrab's Avatar
Send a message via ICQ to captainrab
Great job and timely corrections!
CUSTOM LEDs LIVE HERE
http://www.355nation.net/forum/limit...ol-airbag.html
captainrab is offline   Reply With Quote
Old 01-03-2012, 05:08 PM   #6
thanks for the help captainrab, supermodulation, and rshadd in getting the post corrected and put up!
Old 01-03-2012, 10:22 PM   #7
Would this solve the error code 0446 evap purge system??
guido67922 is offline   Reply With Quote
Old 01-03-2012, 10:54 PM   #8
i dont know, my truck didnt have any codes when i replaced it
Old 01-08-2012, 09:52 PM   #9
That evap is a different issue.
Old 10-06-2013, 01:50 PM   #10
im trying this one!!! thanks!!
mark44883 is offline   Reply With Quote
Old 10-28-2013, 06:58 AM   #11
Calendar Spread  100K  TXSM 11
atxcoloradofan's Avatar
I think this might be my issue.
Atxcoloradofan's Truck!
atxcoloradofan is offline   Reply With Quote
Old 11-15-2014, 07:29 PM   #12
This was helpful.
I just did mine. Replaced with brand by GP Sorensen from Autozone.
Super easy.
Thanks slicksteveo13 !
g8rface is offline   Reply With Quote
Old 01-22-2015, 04:21 PM   #13
Thanks for the how to! I just replaced mine lets hope the gas smell goes away I was able to grab a picture while it was still wet covered in gasoline
How To: Install Fuel Pressure Regulator-img_1890.jpg
zkoolcraig is offline   Reply With Quote
Old 09-18-2016, 04:48 PM   #14
How do you get the first torx screw out (the one facing the hood)? Even with my smallest ratchet the plastic part above doesn't leave enough room. I can get at it with a torx screwdriver, but it's at an angle and I think it might strip the screw.
Doofy is offline   Reply With Quote
Old 09-18-2016, 09:14 PM   #15
Military Service  Lifetime Contributing Member  355Loyalty  200K  NESM 2014  NESM 2015  NESM 16  Skunkwerx Super Mod Meet 2015  CFSM 2016
RickD's Avatar
I moved the wire loom trough up and out of the way just a little as if I wa changing 1st spark plug. Easy after that.
Second time I had help from @Supermodulation and he was able to work a trorx bit in and didn't move the wire trough.
Original Owner: 2004 Z71 4X4 Extended Cab in Black. Line-X bed liner and hard bed cover, Kenwood Excelon HU w/Kicker 6.5" Coaxial Speakers, SiriusXM Adapter, K&N Intake, PTB, SuperSparx, SuperMod Tune, Supermod E-Fan
RickD is online now   Reply With Quote
