| Custom Title Garnered | Disclaimer The community here at 355nation.net urges you to please use caution and seek professional assistance when performing modifications to your vehicle. Before attempting any modification it is advised that you refer to your Colorado or Canyon service manual or contact a certified mechanic as not all GMT355 trucks are the same. The staff and the associated members are in no way responsible for any damages, injuries or other harm inflicted to your vehicle or yourself which may result in attempting these modifications. The posts and content presented on this site reflect in no way the views of 355nation.net or it’s ownership. ![]() A 355nation (CCP) presented by 2wenty2 Project Name How To: Install HID Kits Project Description HID lighting is High Intensity Discharge Lighting that requires a seperate ballast for each bulb and is extremely bright and available in many colors. Skill Level Moderate Project Vehicle Make: Chevrolet Model: Colorado Year: 2005 Engine: 3.5L Power windows: Yes Sun Roof: No Tool Needed Tools Needed– 10mm socket for headlamp removal Flat head screwdriver for Grille assembly removal Electrical Tape Tweezers or Dental pick Phillips head screwdriver for back of headlamps Zip ties(supplied with HIDS) for mounting HIDS, Balasts, Wires (purchased) Parts/Materials Needed HID Kits for every one you want to replace. Project Time 1-2 Hours maybe longer depending on skill level. Project Cost My kit was $118/set shipped from Ebay I did not take pics of the grille removal or the headlamp removal due to MOST people knowing how to do it. However, if you need a know-how on the grille removal please look here… Chevy Colorado Grille Removal - Putfile.com For headlamp removal, you have (2) 10mm bolts on the top side of each headlamp that holds them on.. Remove and pull headlamps off. Location of bolts for headlamps… ![]() The first thing we did was to hook up one ballast and check all of the HIDS to make sure that they were all working properly. When we hooked up the highs, as well as the lows, we noticed that the wiring on the HIDS were backwards from the stock plug. (ie: positive was not going to positive) so we had to switch the connector around on the new HID plug using the Dental pick or Tweezers. NOTE: Orange wire is the Positive wire for the Stock Plugs! Below, the red and black wires are those of the HID plug, the Red wire(positive) was going to the Blue wire(on the lows) and the Pink wire(on the highs) before we switched them to be correct (shown below) ![]() After we checked all of the lights to make sure they worked, we started installing by placing the 9006 and 9005 HID Bulbs in the headlamps themselves. ![]() One thing to note.. while trying to place the new HID bulbs in the headlamps, they would not turn and lock into place, we have to loosen the three screws on the back plate in order to get the turned into place. Them once they were securely “locked” we tightened the screws back down. (shown below) ![]() After getting the bulbs installed for the Highs and Lows, we moved onto the Fogs. We removed the stock bulbs from the fog housing and put in the new HID bulbs. NOTE: The HID for the fogs do not come with a plug to replace the stock bulb. The stock plug MUST be used for the new HIDS. Since the Fog HIDS (H11) come only with the “prongs” the stock plug must be used.. all we did was unplug the original connection.. ![]() Then, plug the HID prongs into the existing stock plug for the fogs (Purple wire is Positive) ![]() ![]() Then.. wrap each individual prong separately to give it an extra layer of protection… ![]() Finally, we wrapped the whole plug a number of times for water resistancy… .Once we got both of the HIDS setup for the fogs, it was now time to choose mounting spots for the Ballasts. NOTE: Ballast mounting is owner preference. I can tell you right now it is a pain to find a spot for ALL 3 ballasts on each side to fit next to each other. I chose to separate them and make sure they would be COMPLETELY secure. My choice for mounting these ballasts were here… ![]() One you have the Ballasts mounted, begin hooking up all of the wires. There are 3 main wires that need to be connected. 2 round plugs ( one set coming from the HID bulbs, One set coming from the Ballasts that meet together in the middle.) And 1 “rectangular” plug(1 set coming from the headlamp/foglamp plugs and 1 set coming from the ballasts which meet together in the middle. (example below) From Ballast to Plugs…(rectangle plugs) ![]() From Ballast to HID bulbs…(round plugs) ![]() Finally, Once everything is hooked up and mounted, reattach your grill… Chevy Colorado Grille Removal - Putfile.com and test them out. Some adjusting will need to be made for the height of the headlights. DON’T BLIND PEOPLE!. Also, some adjusting of the fog light might need to be made, however, I do not have a how-to on the because mine were almost perfect. There is a nut on the back of the foglights that you have to turn to adjust them. Here are some pics of the finished product. Low Beam ![]() High Beam ![]() Low Beam ![]() High Beam ![]() Lows/Fogs ![]() Side shot Lows/Fogs ![]() My New HID Kit… ![]() Blakelpd5’s 8000k kit ![]() Side by side… Blake on the right, me on the left.. ![]() ![]() Showing High beam difference.. “stock” highbeam… ![]() HID highbeam… ![]() Visibility on the highway (lowbeams) ![]() Any Questions feel free to ask.. or PM me. Special thanks to Blakelpd5 for helping with the install. |
| New To The Nation Join Date: Jul 2007 Location: Ottawa, CANADA
Rep Power: 0 ![]() | Re: How-To: Install HID kits nice thread man.... i should have more room to mount ballast though, im not doing my highs. But i think the fogs on a non xtreme are actually 9045 bulbs, but you can use 9005s. Xtremes only are H11s i believe. oh and what kit was it that you used anyway?? |
| Nation Citizen | Re: How-To: Install HID kits hhmm that looks familiar.. awesome write.. this helped me out alot when i did my hids
__________________ http://i36.photobucket.com/albums/e4...lo83banner.jpg |
Rep Power: 0 ![]() | Re: How-To: Install HID kits great write up bro, deff adding this to my favorites for when i do mine
__________________ http://www.355nation.net/dump/chops/...res/slam07.png 2007 z85 summit white 20% tints 10" rockford punch 2 3 piece billett grill vent shades zq8 coils 3" blocks custom magnaflow exhaust k&n drop-in HPTuned custom short throw soon: belltech coils overs 4" leafs with 1" blocks 20s corvette seats RKSport Supercharger gutted pre and mid cats new system |
__________________ 05 Canyon EC SLE - I5M Z71 4x4 GT4 11 Nov - 99100 miles LED + HAW Strobes | Fold-A-Cover | Line-X OTR | Goodmark Cowl Hood1.5TB/2.5AAL/1BL/.5Diff Drop | Rancho Shocks | Bubaloo Skidz | BFG 33-12.5-15 AT/KO Manifold Cat Mod | MBRP 409 Turndown | FRAM Boost+RamAir 3 x Lightforce Blitz | eFan | PCMforless <- very unhappy |
| | #6 | |
Rep Power: 0 ![]() | Re: How-To: Install HID kits Quote: has anyone done an OEM retrofit?? A BMW one would look amazing in these trucks, it could be done. | |
| Nation Citizen | Re: How-To: Install HID kits I'm thinking about doing the retrofit now. Get a Bi-Xenon set-up and replace the low beam bulb assembly..... Just gotta find about $300.
Rep Power: 0 ![]() | Re: How-To: Install HID kits so how exactly would that work?? what do you have to do/use?? |
| Nation Citizen | Re: How-To: Install HID kits Cut up the headlight housings and mount up the projectors. You'd need the projects, bulbs, and ballasts from a car that has them OEM.
Rep Power: 0 ![]() | Re: How-To: Install HID kits lol so i should rob them from my neighbor's BMW X5?? he won't mind... the beemer ones are sweet but mounting them up in our healight housing would hard hard no? |
| walking is for the poor Join Date: Nov 2007 Location: Oregon
Rep Power: 0 ![]() | Re: How-To: Install HID kits I know its an old post but I just wanted to say it was a great write up. I ordered my HIDs today so hopefully I won't have to much trouble installing them.
| PDX Grafix | Re: How-To: Install HID kits Its a snap. If you need help hit me up. If you got the kit i sent u the link to you shouldnt have to switch any wires and it comes with plugs for the harness. |
| OFO= out fucking off | Re: How-To: Install HID kits Shit there was the one dude on CF.com that did the retro fit job on his rado. He used the projectors from a Audi A4 if I remember correctly. He did an excellent job too. ROB, who did that. Havent been over there in a while? Jeremy |
Rep Power: 0 ![]() | Re: How-To: Install HID kits Yeah I got the kit you sent me in the link. 2 kits for $140 is a great deal.
| | #15 | |
| The Nation's Mexican!! | Re: How-To: Install HID kits Quote:
![]() the only this is that u might have to reverse the polaritys (sp?) on the ballast for our trucks...i did
__________________ 2005 CrewCab 3.5L ZQ8 15.7@85mph too many mods to list | |
| | #16 | |
| bird is the word!!!!! | Re: How-To: Install HID kits Quote:
__________________ | |
| The Nation's Mexican!! | Re: How-To: Install HID kits sooooo...wher's the how to?? any progress pics?? closer shots of the actual headlight?? looks PIMP!!!!
| bird is the word!!!!! | Re: How-To: Install HID kits i'll make a post about it in the images forum
Rep Power: 0 ![]() | Re: How-To: Install HID kits Just got my Hids and The highs are working but not the lows. does anyone know what the problem could be?
| Tags |
| how to |
| Thread Tools | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| lowering kits. | coronausmc | Lowering | 32 | 11-17-2007 09:59 PM |
| C04Z71 -- Supermodulation Interior & Exterior LED Kits | Canyon08Z71 | Exterior | 15 | 11-08-2007 10:30 AM |
| Any one have a b/j install how to? | echo2302 | Lowering | 7 | 09-24-2007 09:56 PM |
| How-To: Install Electric Fan | rangerbob | How-To/Tutorials/Reviews | 12 | 05-16-2007 03:18 PM |
