Manual Transmission Fluid - Chevrolet Colorado & GMC Canyon Forum
Old 04-18-2009, 01:24 AM   #1
I fell over the edge
355 O.G.  OG Lifetime Contributing Member  NESM 08  NESM 09  SESM 10  MESM 10
JaysOnTheEDGE's Avatar
Send a message via AIM to JaysOnTheEDGE Send a message via Yahoo to JaysOnTheEDGE
Manual Transmission Fluid Spec?
Does anyone know if 75w-90 GL-4 gear oil will work in our manual transmissions. I found 3 quarts of this stuff sitting out in my garage from when i had my Volkswagen never used. I looked in my owners manual but it doesn't list a spec under the manual transmission fluid it just states "GM Manual Transmission Fluid 89021906"
JaysOnTheEDGE is offline   Reply With Quote
Old 04-18-2009, 01:36 AM   #2
Re: Manual Transmission Fluid
Rangerbob should know.
Old 04-18-2009, 01:53 AM   #3
I'm just wondering since the gearboxes ship with dino oil if its safe to use a synthetic in them any long term effects on seal and bushing swelling causing leaks.
When i used the Amsoil site that's what the recommended fluid to use came up for the transmission. i just want to use it since i already have it may as well put it to use.
The differential spec's this stuff
Old 04-18-2009, 07:45 AM   #4
2009&10 SESM Coordinator
Contributing Member  How-To CM  SuperMeet Organizer  Calendar Spread  SESM 09  SESM 10
jackedupcanyon's Avatar
When I checked the application guide it showed up as the fluid to use. AMS has seal conditioners and other additives for seal conditioning. Yes, use the severe gear in the differentials.
AMSoil Vehicle Application Guide
Steve, 2007 GMC Canyon Z71-4x4 Crew Cab | 3.7 I5 - Auto | 4" Skyjacker suspension lift | 3" Performance Accessories body lift | 33x11.5x17 tires (going 35x12.5x17) | 3.73 gears | Custom blurred grille | 57 K&N | BPi VS | AMS EaAU 6081 | SSK MAF Adapter | NGK AFX w/ NTK WBO2 | HP Tuner Pro wideband tuned by ME! | AMSoil fluids FTW!
jackedupcanyon is offline   Reply With Quote
Old 04-18-2009, 07:58 AM   #5
WCSM 10
joseln135's Avatar
im curious and may seem dumb...i need to add more transmission fluid to my truck and dont know where to add it....i have a 5spd 2004 canyon? someone help?
joseln135 is offline   Reply With Quote
Old 04-18-2009, 08:28 AM   #6
Should be a drain plug at the bottom on the side and a fill plug higher up on the tranny
Old 04-18-2009, 09:37 AM   #7
tinja nurtles
Nation Elite  Contributing Member  SuperMeet Organizer  TXSM 10
05_quick4door's Avatar
gear oil seems kinda thick for a transmision doesnt it?
-Cory-
05 Colorado - Turbachargers! Shenanigans
PM for PCM tuning services
05_quick4door is offline   Reply With Quote
Old 04-18-2009, 10:14 AM   #8
Manual tranny fluid for the transmission and severe gear lube for the differentials.
Old 04-18-2009, 10:29 AM   #9
355 O.G.  Contributing Member  How-To CM  Nation Advocate  Public Service  NESM 09
rangerbob's Avatar
Send a message via AIM to rangerbob
My most recent AMSOIL Order:
05 Canyon EC SLE - I5M Z71 4x4 GT4 25 Aug - 126k miles
LED + HAW Strobes | Fold-A-Cover | Line-X OTR | Goodmark Cowl Hood | GP Seats
1.5TB/2.5AAL/1BL/.5Diff Drop | RS5300/MA764 Shocks | Bubaloo Skidz | BFG 33-12.5-15 AT/KO
1st Cat Delete | MBRP 409 Turndown | FRAM Boost+RamAir | 3 x Lightforce Blitz | eFan | Tune by Gerry <- Awesome!!!
rangerbob is offline   Reply With Quote
Old 04-18-2009, 11:38 AM   #10
The syncromesh is for your transfer case correct?
Old 04-18-2009, 12:05 PM   #11
Yes. Did you check out the AMSoil Vehicle Application Guide???
Old 04-18-2009, 04:25 PM   #12
Members Technical !@#!@#!@#!@#!@#
Nation Elite  Contributing Member  How-To CM  Calendar Spread  355 Celebrity  MTS  100K  SESM 09  SESM 10  TXSM 11
Slo86GT's Avatar
75-90 gear oil in the trans should be correct. The stock stuff is thick as all hell. As soon as I get some cash, I'm going to drain and refill the trans and diff with Royal Purple 75-90 synthetic. Got s'more dino oil to swap in the crank case, one more oil change and I may try out synthetic there too.
- Jody -
Knowledge and finger vomit are easily confused over the internet.
Slo86GT is offline   Reply With Quote
Old 04-18-2009, 06:09 PM   #13
5cylinder and Tire slayer
TOTM Winner  Nation Elite  Contributing Member  How-To CM  Nation Advocate  Calendar Spread  355Loyalty  100K  NESM 09  SESM 10  MESM 10  MESM 11
WTRacing's Avatar
i used valvoline sycromesh for my S10. . they say that and the GM stuff is the best
-Tribo
RIP SC
RIP Skitz
"Only the Good die young"
1997 S10 ZQ8 /2.2 5-Speed
2004 Colorado ZQ8 /3.5/3.7/3.5 Auto (Totaled 10-6-2011...RIPieces)
2004 Colorado ZQ8 /LSX/T56
2006 SRT8 300C
WTRacing is offline   Reply With Quote
Old 04-18-2009, 06:52 PM   #14
i am changing mine right now and the man trans fluid came out like water
Old 04-18-2009, 09:44 PM   #15
Slo86GT's Avatar
That's odd. did a stealership or quick change place "flush" it for you sometime since the factory?
- Jody -
Old 04-18-2009, 09:55 PM   #16
No i'm the Original owner and its never been to the dealershit or a quicklube place for anything. The AMSoil is good stuff though it shifts just like a brand new truck again and its really quiet now too.
Old 04-18-2009, 10:08 PM   #17
Glad to hear it!
Old 05-02-2009, 07:15 AM   #18
Lifetime Contributing Member  How-To CM  355 Celebrity  355Loyalty  100K
rfross's Avatar
A few weeks back I swapped out my factory fill with Redline MT-90 synthetic and did notice an improvement in shift quality, especially when cold and when short shifting at lower revs. It's definitely not as smooth a transmission as the one in a 1996 Tacoma that I once owned but it is better now with the change in gear lubes.
2007 GMC Canyon regular cab 2WD. 2.9, 5 speed manual, G80 locker, Wait4Me tune, GM touring exhaust, Supermodulation Ported Throttle Body, Lakeland Voyager fiberglass cap, Bilstein struts/shocks, 225/75x15 Firestone Destination LE2's. Bonneville Land Speed Racing competitor in 2011.
rfross is offline   Reply With Quote
Old 05-13-2009, 11:43 AM   #19
Naiton Adovcate
Military Service  Chapter Founder  Contributing Member  355Loyalty
savannahcoly's Avatar
Send a message via AIM to savannahcoly Send a message via Yahoo to savannahcoly
I used the Royal Purple 75W-90 in my MA5 and its been running great since.
2.8 with cams and ported head
Soon to add snail power!
savannahcoly is offline   Reply With Quote
Old 05-13-2009, 11:52 AM   #20
CHEEZEDOODLE
355 O.G.  Chapter Founder  TOTM Winner  Nation Elite  Lifetime Contributing Member  How-To CM  SuperMeet Organizer  Calendar Spread  355 Celebrity  Skitz Award  355Loyalty  USASM2012  NESM 09  SESM 09  SESM 10  SESM 11  SESM 2013  MESM 10  MESM 11  MESM 15
kerad11's Avatar
is there a write up on changing the manual trans fluid?
im fucking retarted about transmissions and i understand its not easy to get all the old fluid out(like the doughnut thing)
sorry im so ignorant yall....
kerad11 is offline   Reply With Quote
