Thermostat? how the crap do......... - Chevrolet Colorado & GMC Canyon Forum
LinkBack (5) Thread Tools Search this Thread Display Modes
Old 12-14-2009, 11:43 PM   5 links from elsewhere to this Post. Click to view. #1
Question Thermostat? how the crap do.........
you get to it??? I stopped on the way home and bought one along with the proper amount of coolant (thanks Darek) thinking I would change it tonight because I think it is stuck in the closed position. The reason I think it is stuck in the closed position is the fact that it is not circlating and the top hose is to hot to hold and tight as a ticks ass. The bottom hose has little to no prasure on it and is only warm to the touch........The question here is, has anyone rplaced the thermostat, and if so what all had to be removed to do so.....that bastage is hidden up under the alternator, in fact is hard to see at all from the top or botoom of the truck......HELP
Old 12-14-2009, 11:57 PM   #2
Members Technical !@#!@#!@#!@#!@#
Nation Elite  Contributing Member  How-To CM  Calendar Spread  355 Celebrity  MTS  100K  SESM 09  SESM 10  TXSM 11
Slo86GT's Avatar
Re: Thermostat? how the crap do.........
If I remember correctly, Tribo was sayin that the thermostat is built into the waterneck or something???
- Jody -
Knowledge and finger vomit are easily confused over the internet.
Slo86GT is offline   Reply With Quote
Old 12-14-2009, 11:58 PM   #3
it is, one piece. 40 bux! I need help getting to it.
Old 12-14-2009, 11:59 PM   #4
Military Service  Nation Elite  Lifetime Contributing Member  SuperMeet Organizer  Public Service  TXSM 10  TXSM 11  SCSM 2013
DirtyBoy's Avatar
that is teh ~ghey~
DirtyBoy is offline   Reply With Quote
Old 12-15-2009, 12:00 AM   #5
Originally Posted by DirtyBoy View Post
that is teh ~ghey~
If your not gonna help
Old 12-15-2009, 12:10 AM   #6
got the OEM part number for that part? I'll look it up on MOD.
3307 is offline   Reply With Quote
Old 12-15-2009, 12:12 AM   #7
I fell over the edge
355 O.G.  OG Lifetime Contributing Member  NESM 08  NESM 09  SESM 10  MESM 10
JaysOnTheEDGE's Avatar
Send a message via AIM to JaysOnTheEDGE Send a message via Yahoo to JaysOnTheEDGE
according to the factory service dvd you get to it from the driverside wheel well you have to take the tire and splash guard off i believe then you get easy access to it.
JaysOnTheEDGE is offline   Reply With Quote
Old 12-15-2009, 12:13 AM   #8
You Smell That?!?!
Nation Elite  Contributing Member  How-To CM  SuperMeet Organizer  Skitz Award  100K  SESM 09  SESM 10  TXSM 10
rtmsu_02's Avatar
i'm rading chiltons right now mark, hang on
2004 Silver birch Canyon Z71 SLE 4x4 130,000 miles and counting
rtmsu_02 is offline   Reply With Quote
Old 12-15-2009, 12:14 AM   #9
no OEM part number.
Old 12-15-2009, 12:15 AM   #10
Public Service
GMZ71's Avatar
I changed my thermo in my 04 3.5 and I had to take the drivers side tire off and take the inner fender plastic off and it was right there!! Beware, you will have a lake of sticky-ass dexcool all over the garage floor!! Good Luck!
GMZ71 is offline   Reply With Quote
Old 12-15-2009, 12:17 AM   #11
1 Drain the cooling system.
2 Raise and support the vehicle only high enough to access the thermostat housing through the wheelhouse.
3 Remove the left Wheelhouse liner.
4 Position the J38185 (hose clamp pliers) to the clamp in order to remove the radiator hose from the thermostat housing.
5 remove the thermostat housing bolts.
6 Remove the thermostat housing from the engine block.
7 Clean and inspect the thermostat housing.
8 Clean and inspect the sealing surface of the engine block.
Old 12-15-2009, 12:17 AM   #12
cdk
Nation Elite  Lifetime Contributing Member  Calendar Spread  355Loyalty  TXSM 11  TXSM 2015
Under the alternator? I thought it was just above the powersteering pump? Just pull the hose, a couple bolts and its off? (probably not right??)
cdk is offline   Reply With Quote
Old 12-15-2009, 12:17 AM   #13
bam! thats what I was looking for, was thinking that but was not sure. I did not wanna start on a project from the totaly wrong direction. Thanks GMZ71
Old 12-15-2009, 12:18 AM   #14
You Smell That?!?!
rtmsu_02's Avatar
1) disconnect (-) battery cable
2) remove left front tire and and put vehicle on jackstands
3) follow lower radiator hose to the engine to locate the thermostat housing
4) loosen clamp, and take the hose off
5) remove the bolts and detach housing
6) if it is stuck, tap wit a soft face hammer to remove
7) clean all surfaces of engine and housing
8) make sure o-ring is installed on thermostat housing
9) reverse and install
Old 12-15-2009, 12:18 AM   #15
cdk
mwcky, you should throw together a how-to....
Old 12-15-2009, 12:19 AM   #16
You Smell That?!?!
rtmsu_02's Avatar
im too slow
Old 12-15-2009, 12:19 AM   #17
Thanks brother!
yeah, not there.....other side on the bottom.
Old 12-15-2009, 12:21 AM   #18
Military Service  Nation Elite  Contributing Member  How-To CM  Nation Advocate  Calendar Spread  355 Celebrity  Skitz Award  NESM 09  NESM 10
greg larkins's Avatar
gmpartsdirect.com: Alternate GM Catalog
i hope that link works but i can't tell from the pic where it's located.
black letters > green letters
greg larkins is offline   Reply With Quote
Old 12-15-2009, 12:21 AM   #19
Military Service  Lifetime Contributing Member  100K  WCSM 10  WCSM 2015
1BAD355's Avatar
x2 what he said i was going to do mine a while back becuse i thought it was over heating but the dealer checked it and said it is working and that the truck temp was normal running a bit more than half.
1BAD355 is offline   Reply With Quote
Old 12-15-2009, 12:24 AM   #20
Originally Posted by rtmsu_02 View Post
im too slow
looks like I'm gonna wait tll Thursday to do this, wanna swing by and help, your more than welcome.......LOL
p0128 , thermostat
LinkBack to this Thread: http://www.355nation.net/forum/i4-i5-engine-drivetrain/24655-thermostat-how-crap-do.html
swirlyportal This thread Refback 08-16-2012 12:47 PM
password protected notes This thread Refback 06-28-2012 07:42 PM
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard This thread Refback 06-25-2012 08:35 PM
404 Not Found This thread Refback 06-15-2012 01:19 PM
2005 colorado thermostat oem - Google Search This thread Refback 07-14-2011 05:34 AM
