Cyclinder #'s - Chevrolet Colorado & GMC Canyon Forum
LinkBack (3) Thread Tools Search this Thread Display Modes
Old 04-30-2010, 10:19 AM   3 links from elsewhere to this Post. Click to view. #1
tbirdnny's Avatar
Send a message via AIM to tbirdnny
Cyclinder #'s
How are the cyclinders numbered on the I-5 ? I got a P0301 code after I changed my spark plugs.
-= tbirrd =-
tbirdnny is offline   Reply With Quote
Old 04-30-2010, 11:42 AM   #2
Military Service  Nation Elite  Lifetime Contributing Member  SuperMeet Organizer  Public Service  TXSM 10  TXSM 11  SCSM 2013
DirtyBoy's Avatar
Re: Cyclinder #'s
12345
idk, look at your owners manual
DirtyBoy is offline   Reply With Quote
Old 04-30-2010, 01:38 PM   #3
Re: Cyclinder #'s
Firing order 1-3-5-4-2.
Tighten the spark plugs to 18 N.m (13 lb ft) .
FYI
Bulletin No.: 07-06-01-011A
Date: August 07, 2007
INFORMATION
Subject:
Diagnostic Tips for DTC P0300 Engine Misfire Detected and Cylinder Leakage Testing
Models:
2004-2006 Chevrolet Colorado
2004-2006 GMC Canyon
2006 HUMMER H3
with Vortec(TM) 2.8L I-4 or 3.5L I-5 Engine (VINs 8, 6 - RPOs LK5, L52)
Supercede:
This bulletin is being revised to include 2.8L LK5 engine. Please discard Corporate Bulletin Number 07-06-01-011 (Section 06 - Engine/Propulsion System).
The purpose of this bulletin is to provide technicians with diagnostic tips for DTC P0300 and cylinder leakage testing.
If DTC P0300 sets, follow DTC P0300 diagnostics in SI. The following tips may also be helpful:
Isolate the cylinder or cylinders responsible for the P0300 misfire code and determine if the misfire can be moved to another cylinder by swapping components such as spark plugs, ignition coils and fuel injectors.
If misfire is random, diagnose for possible mechanical noise that may be misinterpreted as a misfire.
If diagnostics lead to suspect cylinder head valve seats, conduct a cylinder leakage test utilizing a cylinder leakage tester following the manufacturer instructions and Cylinder Leakage Test procedure in SI.
Diagnostic Tips for Cylinder Leakage Test
When performing a cylinder leakage test, the following tips may be helpful:
Carefully follow the manufacturer's instructions for J 35667-A Cylinder Head Leakdown Tester (or equivalent automotive cylinder leakage tester) and Cylinder Leakage Test procedure in SI.
The cylinder must be at TDC on the compression stroke when testing to ensure that all the valves are fully closed.
If holding the crankshaft balancer bolt with a wrench, regulate shop air to the J 35667-A to 345-414 kPa (50-60 psi) to reduce torque on the crankshaft balancer bolt when air is applied. For other equivalent cylinder head leakdown testers, refer to the manufacturers instructions.
An alternative to holding the crankshaft balancer bolt with a wrench would be to use the EN-46547 Flywheel Holding Tool. A breaker bar with socket is another alternative.
If intake valve seat leakage (rare) is suspected, verify by listening for air leakage inside the intake runner.
If excessive cylinder leakage is NOT observed, the cause of the misfire condition is NOT engine mechanical related. Misfire diagnosis should focus on fuel and electrical for cases where excessive leakage is not observed.
The majority of vehicles will not experience an intake valve seat erosion condition. Expect a variation between cylinders if valve seat erosion has occurred.
Use the labor code and time provided in the Warranty Information section of this bulletin to receive credit for performing cylinder leakage diagnostics.
Old 04-30-2010, 03:47 PM   #4
355 O.G.  Chapter Founder  Nation Elite  OG Lifetime Contributing Member  How-To CM  Nation Vendor  SuperMeet Organizer  Nation Advocate  355Loyalty  100K  NESM 08  NESM 09  NESM 11  SESM 11
Re: Cyclinder #'s
Make sure you have cylinder #1 ignition coil properly seated... It is difficult because the harness in its way. Careful with the bolts, they do not require much force.
Cylinder #1 is the one closest to the radiator (front of engine). 1,2,3,4,5 in that order.
Canyon08Z71 is offline   Reply With Quote
Old 05-01-2010, 08:34 AM   #5
DirtyBoy's Avatar
Re: Cyclinder #'s
ok so i was right... GO ME!
again, check your owners manual before posting every question up here...
LinkBack to this Thread: http://www.355nation.net/forum/i4-i5-engine-drivetrain/30248-cyclinder-s.html
chevrolet spark firing order - forum about car parts and car advices This thread Refback 06-26-2016 11:18 PM
chevrolet spark seat - forum about car parts and car advices This thread Refback 05-17-2016 11:56 AM
chevrolet spark cylinder head - forum about car parts and car advices This thread Refback 11-02-2014 09:31 PM
