MAP sensor issues - Chevrolet Colorado & GMC Canyon Forum
Old 08-05-2010, 04:34 PM   #1
Exclamation MAP sensor issues
Ok so about two weeks ago my check engine light came on for something with my MAP sensor. My mechanic checked the vacuum and then replaced the sensor. Now, about 300 miles later, the light is back on with error code P0106. Ive been blaming the K&N intake because ive been having a lot of issues with sensors and the intake, but honestly dont know what the cause of the problem is. I called k&N and they were doubtful it had anything to do with their intake, so now im looking for some other possible causes. I just checked vacuum again with some starter fluid, and it has no leaks.
nightwolf is offline   Reply With Quote
Old 08-05-2010, 04:41 PM   #2
Mr. Under Construction
Military Service  Contributing Member
xxlowradoxx's Avatar
Send a message via AIM to xxlowradoxx Send a message via Yahoo to xxlowradoxx
Re: MAP sensor issues
Same exact thing happened to me. I had the CEL light up, got a new sensor, light went out. About 250-300 miles after that got a CEL went and had it checked and guess what...MAP sensor...Since that, I havent changed it and the only noticeable change is a slightly low idle and a glaring bright orange motor outline telling me that I am stupid...Hope you find A solution cuz I havent.
xxlowradoxx is offline   Reply With Quote
Old 08-05-2010, 04:46 PM   #3
Harry...
Nation Elite  Contributing Member  Calendar Spread  Skitz Award  100K  NESM 09  NESM 10  NESM 2013  SESM 10
Chris0nllyn's Avatar
I'd clean your grounds under the hood.
Chris0nllyn is offline   Reply With Quote
Old 08-05-2010, 05:05 PM   #4
355Nation Moderator  Military Service  Chapter Founder  TOTY  TOTM Winner  Nation Elite  OG Lifetime Contributing Member  How-To CM  SuperMeet Organizer  Nation Advocate  Calendar Spread  355 Celebrity  MTS  Skitz Award  355Loyalty  100K  NESM 09  NESM 2013
First I have heard of issues with the MAP, normally the issues are with a dirty MAF.
Old 08-05-2010, 05:06 PM   #5
wowowow...YES. When i let off brake in drive my idle drops straight down. do you have an intake?
Old 08-05-2010, 05:08 PM   #6
been there with the dirty maf. only difference is when i was cleaning it my dog got a hold and cleaned it with his teeth
Old 08-05-2010, 05:08 PM   #7
Military Service  Public Service  100K  SESM 10
amplify249's Avatar
my truck was doing that the other day, i cleaned the MAF and Throttle body, problem was solved for me *for the time being* idle issue fixed itself, and check engine lights went off.
amplify249 is offline   Reply With Quote
Old 08-05-2010, 05:09 PM   #8
Exactly...what year did you say yours is? I have a 2005 I5...I have heard that there could be probklems with the head...maybe that is a contributing factor...oh and yes I do have an intake...K&N matter of fact...and my symptoms are just like yours...
Old 08-05-2010, 05:10 PM   #9
mine is an 04 3.5
Old 08-05-2010, 05:15 PM   #10
amplify249's Avatar
mine is as well, start with cleaning your maf and throttle body, then move to bigger things if problem continues. trust me i heard all this hype about "clean your throttle body it will cure aids" shit and i was like there is no way its gonna fix my problem....until i actually cleaned it and it fixed it.
maf sensor spray-$6
throttle body cleaner- $4
parts and labor....$10 its worth a try.
Old 08-05-2010, 05:19 PM   #11
maf sensor spray-$6
I'll give it a try broseph!
Old 08-05-2010, 05:31 PM   #12
No thats shitty!
Old 08-05-2010, 05:32 PM   #13
i'll have to try it too when i get a chance. if you beat me too it, let me know how it works!
Old 08-06-2010, 06:54 PM   #14
Talking Re: MAP sensor issues
Did it last night and so far so good...CEL has been on since I was a sperm, and it has gone off now. Cleaned both MAF Sensor, and TB...worked like a charm...I think I might get rid of my filter and go with a dry filter. I had a whole bunch of gunk all in my TB...more than likely red death juice from my filter!!! Do the cleaning and see what happens
Old 08-06-2010, 08:22 PM   #15
The LED Dude
Nation Elite  Lifetime Contributing Member  How-To CM  355 Celebrity  MTS  Skitz Award  355Loyalty
captainrab's Avatar
Send a message via ICQ to captainrab
It's not the filter. It's just funked tbs. Does it with dry filters to. Clean tb every 20k and you will be surprised what you find. Btw chemtrol b12 works great to clean em. Looks new with little effort.
CUSTOM LEDs LIVE HERE
http://www.355nation.net/forum/limit...ol-airbag.html
captainrab is offline   Reply With Quote
Old 08-07-2010, 12:29 AM   #16
got to mine today. i unplugged battery as a precaustion when i was undoing the wires, so of course the light went off. So far though ive noticed a much higher idle at startup ~1k and then it slows to about 650. no more idle drop though! time will tell. my fingers are crossed.
Old 08-07-2010, 12:37 AM   #17
Nation Elite  Contributing Member  TXSM 10
La Colorado's Avatar
Send a message via MSN to La Colorado
i think mine is bad cause 2 MAF sensors later at 80K total miles on the truck total and it still throws a code :/
| |.:R.I.P Skitz 06/20/1984-06/27/2011:.||
La Colorado is offline   Reply With Quote
Old 08-07-2010, 04:11 AM   #18
This is MAP sensor # 2 and I have put about 25 miles on it since I cleaned everything and I havent got the code yet...may the force be with me
