ABS Traction Fault - Chevrolet Colorado & GMC Canyon Forum
Old 08-09-2010, 05:20 PM   #1
ABS Traction Fault
Hey Nation
I've been having this fault pop up intermittently for the past month, reads on the dash display as ABS Traction Fault. Will come on just randomly driving down the highway, or will decide to engage the ABS braking while trying to come to a stop with light/med braking.
Any idea what causes this issue? Or where abouts I should start looking for a problem??
I did a search on here but didn't come up with much. Am new to the Canyon/Colly family.
Thanks in advance for any info.
2007 GMC Canyon Crewcab ZQ8
Mods: K&N Intake kit, Magnaflow muffler w/ custom cat back
ghost6_9 is offline   Reply With Quote
Old 08-09-2010, 05:41 PM   #2
Wat r u sinking about?
Nation Elite  Contributing Member  Calendar Spread  Skitz Award  SESM 10  SESM 11  MESM 10
canyonbrian's Avatar
Send a message via Yahoo to canyonbrian
Re: ABS Traction Fault
Mine did the same thing once, along with the phantom wiper. Had the bcm flashed and nothing since then.
Originally Posted by bradtw191 View Post
haha i dont think its so much the fact of looking at the tits, she just has a nice computer and would murder me if it got infected.....as mine did when i watched pudding farts with no antivirus.
canyonbrian is offline   Reply With Quote
Old 08-09-2010, 05:53 PM   #3
check your ABS sensor on your front hubs to make sure the wire isn't pinched or cut anywhere, if that checks out then clean out the sensor itself which is a small metal ring pressed on the back of the wheel hub. The ABS sensors are a big issue on these trucks and are very sensitive and dirt or debris and it will throw a code or if the metal ring is slightly bent it could also throw an intermittent code.
Old 08-09-2010, 07:12 PM   #4
Andersonn's Avatar
Welcome to the club. Mines been on for a while, replaced both sensors, and the ABS unit it self. Nothin has worked. Finally sad F'it and pulled the fuses, deal with the no ABS and the flashin lights on the dash.
~SOLD~ 04 Z71 2wd crew cab.
40 series Flowmaster. Kenwood HU. Alpine M-850 and 12" Alpine Type - R.
Now daily driving a 2006 reg cab 2wd z85 Colorado.
Andersonn is offline   Reply With Quote
Old 08-10-2010, 12:44 AM   #5
Ron Lopes
Contributing Member  How-To CM  100K
xronx's Avatar
Send a message via ICQ to xronx Send a message via AIM to xronx
yeah sounds like the wheel speed sensors are picking up different readdings... check them toner rings on the CV axles, make sure the sensor is clear...its magnetic so it can pick up debris from rotors
xronx is offline   Reply With Quote
Old 08-10-2010, 02:46 PM   #6
Awesome thanks for the info. I'll probably tear into the truck this weekend and see how the sensors look.
Old 08-10-2011, 03:20 PM   #7
The abs/traction fault has started to come on in my '05 Canyon when I am driving on the highway. Also it seems that the traction control will activate at some times when the wheels are not slipping. I have replaced both front hubs already. Does anyone know what the problem could be?
canyonchik_15 is offline   Reply With Quote
Old 08-11-2011, 08:05 AM   #8
I disabled my abs because of the fact of it working when it wasn't supposed to. Been much happier that way and now I don't replace abs parts all the damn time
Old 08-11-2011, 04:46 PM   #9
Formerly Metal_EMT
Lifetime Contributing Member  How-To CM  Public Service  Calendar Spread  355Loyalty  200K  NESM 10  NESM 11  MESM 11
HK_Titan's Avatar
Is there wa way to disable the abs other than pulling the fuse? When I did that, both the abs light and the brake warning light came on. (the brake warning willl tell you about low fluid and such also I think)
2004 Colorado LS Ex. Cab Z71
~Dan Formerly Metal_EMT
Originally Posted by Moto
All thanks to a finicky drive by wire system with more PCM's, BCM's and PMS than the fuckin space shuttle.
HK_Titan is offline   Reply With Quote
Old 08-11-2011, 05:39 PM   #10
XJDesertFox's Avatar
Send a message via AIM to XJDesertFox
Let me ask you this, since no one has yet.
Do you have a plug and play HID kit in your truck?
I hate when I wake up in the morning and barack obama is president.
XJDesertFox is offline   Reply With Quote
Old 08-11-2011, 09:44 PM   #11
Remove the leds in the dash lol. Maybe a tech II can shut it down idk
Old 08-14-2011, 07:21 PM   #12
My abs is now coming on when i am lightly braking and sometimes it will make a clunking noise and i am afraid that something is wrong with my brakes themselves. What is the best way to actually fix this rather than taking out the fuse? I am thinking that it is a rear wheel sensor?
Old 08-14-2011, 07:31 PM   #13
There's only 3 sensors in your abs system for wheel speed. Your front hubs abs rings and the vehicle speed sensor on the rear of the transmission. Its more than likely a tone ring damaged but I just disabled it cause abs just made braking in my truck worse
Old 08-24-2011, 07:50 PM   #14
The sensor is damaged on the front drivers and the bearing is also faulty as well. Since I have changed both hubs previously is chevy doing some sort of recall for this problem? I find it hard to believe that i need to be replacing hubs every 90K
Old 08-24-2011, 07:58 PM   #15
Consider yourself lucky. I have changed both hubs already and have only 80k on the truck atm but hubs were changed at 50k roughly
