Cruise Control Not Working - Chevrolet Colorado & GMC Canyon Forum
Old 09-29-2010, 02:17 PM   1 links from elsewhere to this Post. Click to view. #1
Jim
NESM 2015
Jim's Avatar
My 2009's cruise doesn't work and the 10A fuse is good. I thought it could be in the PCM and disconnected the battery to "reboot" it, but no change. Any ideas? Anyone have this problem before?
It is under warranty but before I bring it to the dealer I better undo the low/high beam mod, fog light on high mod, RAP power mod, etc. so they won't tell me my warranty is void.
Thanks, Jim
2009 Colorado Z71 4x4 Extended Cab 3.7L
Truxedo Truxport Soft Tonneau Cover, Dynolock Electric Tailgate Lock,
OEM Nerf Bars & Mud Flaps, Lund Bug Deflector, Window Vent Shades,
Dual High/Low Beam mod, Fog Light on High Beam mod, 4500k HID Low Beams & Fog Lights
Air springs and 2" lowering blocks so it always rides level
Jim is offline   Reply With Quote
Old 09-29-2010, 02:18 PM   #2
Captain Obvious
Nation Elite  Contributing Member  100K  SESM 09  SESM 10  MESM 10
trueblue's Avatar
Re: Cruise Control Not Working
have you check your brake lights? it won't work if one burns out.
Originally Posted by unicknn View Post
your weiner is pretty small man
Originally Posted by rcogan86 View Post
yea, it happens..
trueblue is offline   Reply With Quote
Old 09-29-2010, 02:21 PM   #3
355 O.G.  Contributing Member  How-To CM  Nation Advocate  Public Service  NESM 09
rangerbob's Avatar
Send a message via AIM to rangerbob
Got search? Brake light bulb out is the most likely cause.
05 Canyon EC SLE - I5M Z71 4x4 GT4 25 Aug - 126k miles
LED + HAW Strobes | Fold-A-Cover | Line-X OTR | Goodmark Cowl Hood | GP Seats
1.5TB/2.5AAL/1BL/.5Diff Drop | RS5300/MA764 Shocks | Bubaloo Skidz | BFG 33-12.5-15 AT/KO
1st Cat Delete | MBRP 409 Turndown | FRAM Boost+RamAir | 3 x Lightforce Blitz | eFan | Tune by Gerry <- Awesome!!!
rangerbob is offline   Reply With Quote
Old 09-29-2010, 02:21 PM   #4
Jim
NESM 2015
Jim's Avatar
No, but I will - have you seen that before? I thought the CC only uses the brake light switch at the pedal, not actually sensing the lights.
Old 09-29-2010, 02:23 PM   #5
Jim
NESM 2015
Jim's Avatar
I tried searching first - nothing came up.
Thanks to both for the resonses.
Old 09-29-2010, 02:31 PM   #6
Purple Heart  Military Service
awp101's Avatar
Location: The nurturing biosphere of the Mothership aka TX
I bet you have no brake lights either. When the switch goes out, you lose the brake lights AND the cruise. Happened on my old 05 CC and found out there was a recall for that.
Make yourself an honest man, and then you may be sure that there is one less scoundrel in the world. - Thomas Carlyle
Sometimes when I'm bored, I like to text "I hid the body, now what?" to a random phone number...
Nothing so needs reforming as other people's habits. - Mark Twain
Spell Check: It's your friend
When I dance with wolves, it's usually the Tango
awp101 is offline   Reply With Quote
Old 09-29-2010, 02:35 PM   #7
Members Technical Staff
TOTM Winner  Nation Elite  Calendar Spread  MTS  Skitz Award  SESM 09  SESM 10  SESM 11
LowRadoNLa's Avatar
there is a 2nd recall on brake light switches....also did you install an ebay LED third brake light? that has caused some issues as well
UNDERGROUND....IT'S A LIFESTYLE
JOIN THE REVOLUTION
LowRadoNLa is offline   Reply With Quote
Old 09-29-2010, 02:43 PM   #8
Jim
NESM 2015
Jim's Avatar
I just went outside to check & you are right - no brake lights. You would have thought that they would have corrected the problem by now in my 2009 but I guess not.
Thanks guys - that saved me a lot of trouble-shooting time!
Old 09-29-2010, 02:47 PM   #9
awp101's Avatar
Makes you break out in a cold sweat when you think about that last trip around town, doesn't it?
Get a hold of a/the dealer and get it corrected for free (IF the recall is still underway).
Old 09-29-2010, 04:59 PM   #10
Jim
NESM 2015
Jim's Avatar
Right - not knowing they are out can be dangerous.
I pulled the switch, p/n 25796381 (I think it will be superceded by p/n 20913529). It is a NC switch (when brake pedal is depressed) but this switch was closed regardless. I took it apart & re-assembled it & now it works, but who knows for how long.
I ordered 2 switches from RockAuto for $6.50 each + $3.16 S&H.
Last edited by Jim; 10-01-2010 at 12:06 PM. Reason: Not necessarily a recall issue.
Old 10-01-2010, 12:20 PM   #11
Jim
NESM 2015
Jim's Avatar
I re-installed the now-working brake light switch and still no brake lights. I found the 20A fuse was blown in addition to the switch contacts fused closed. I think I know the reason: A couple of weeks ago I hooked up my boat trailer lights but one of the sealed tail light assemblies was half full of water & probably shorted out the lights.
So now the brake lights work fine, but cruise control is still not working. The 2nd switch at the brake pedal is the cruise / TCC release (opens when the pedal is depressed) and it is working fine. Any ideas? I'm afraid the PCM was damaged and will have the dealer look at it once I replace the relays for the fog & high/low mods listed in my sig above & return to stock so the dealer doesn't try to say my warranty is void. Those mods are unrelated to this problem.
Old 10-04-2010, 07:56 AM   #12
Jim
NESM 2015
Jim's Avatar
Two days after fixing the brake lights the cruise started working again. The PCM must require a certian number of cycles to reset itself.
Old 10-04-2010, 08:34 AM   #13
Texas Yoda!!!!
Nation Elite  Contributing Member  SuperMeet Organizer  Calendar Spread  Skitz Award  100K  USASM2012  SESM 10  SESM 11  TXSM 10  TXSM 11  TXSM 14  TXSM 2015
edvocho's Avatar
Glad they are working now!
||.:R.I.P Skitz 06/20/1984-06/27/2011:.||
Facebook 355Nation's Facebook Group
edvocho is offline   Reply With Quote
brake light switch , cruise control
LinkBack to this Thread: http://www.355nation.net/forum/i4-i5-engine-drivetrain/36437-cruise-control-not-working.html
Untitled document This thread Refback 06-10-2015 03:51 PM
