Heater not working - Chevrolet Colorado & GMC Canyon Forum
Old 11-06-2010, 07:08 PM   #1
SESM 10  TXSM 10  TXSM 11
pace_blue's Avatar
Heater not working
i dont know if this is in the right place so if not mods please move
alright guys i need your help....
My heater just quit working like nothing i put it up on 4 and it wont even blow paper off the vent i checked the plug that ''burns'' up and it looked fine... i dont have a tester to check the ''fuse'' ... So whats wrong with my heater?
btw motor worked fine no noises or nothing at all.. just up and quit
thanks..... nick
10 years ago we had Steve Jobs, Bob Hope, and Johnny Cash!
Now we have no Jobs, no Hope, and no Cash!
pace_blue is offline   Reply With Quote
Old 11-06-2010, 09:57 PM   #2
Re: Heater not working
so the blower motor does not work? This is not a temperatrue output problem correct.
NickG is offline   Reply With Quote
Old 11-06-2010, 10:45 PM   #3
pace_blue's Avatar
Well it did work just fine but it acts like a fuse has blown!! Idk whats goin on with it
Old 11-07-2010, 01:29 AM   #4
Public Service  NESM 11
retired's Avatar
You gotta start with the basics, check the fuse first then see if your getting power to the blower.
retired is offline   Reply With Quote
Old 11-07-2010, 06:37 PM   #5
pace_blue's Avatar
***UPDATE***
ok so i thought it was the resistor (IGN 3 HVAC Relay 59) in the fuseblock under the hood but i got my tester and checked it...good then i checked the ground on the ps fender... good (if it wasnt it is now but still not working) so i pulled the plug under the dash that "burns" up.. its good so i check to make sure im getting power there...yup have power so the i check the plug goin straight to the fan/blower motor... got power so then im like well hell did my fan/blower motor burn up so i put power straight to it... i comes on... so then i pull my AC/HEATER panel (under radio) out and check to see if im getting power to my switch...got power... so i got back under the dash and check the resistor (white) that is screwed to the botom of the fan/blower motor... its good...... so all i can figure out is the switch (1-4) has to be bad..... RIGHT??? If not man im lost its got me scratching my head...did i still miss somthing??
Old 11-10-2010, 01:00 AM   #6
pace_blue's Avatar
Well got a new switch and still not working guess ill be taking it to a shop and let a "pro" figure it out!!
Old 11-10-2010, 01:54 AM   #7
retired's Avatar
Sounds like your not getting a ground. I don't know where the blower gets it's ground from. Sorry can't help you.
Old 11-10-2010, 02:06 AM   #8
pace_blue's Avatar
naw its cool...thanks tho... its just got me confused its getting power to eveything that needs power (as far as i kno) but still doesnt work!!
Old 12-15-2010, 06:59 PM   #9
2 wks ago my heater quit, so i changed the fuse & it worked fine until today it quit again so i went & got another fuse nothing about an hour or so later it started working does anybody know whats up with that??? its 18 degrees here help
blubaby04 is offline   Reply With Quote
Old 12-15-2010, 07:40 PM   #10
Contributing Member  100K
04coloradols's Avatar
mine will only blow on 4...
04 Colorado Crew Cab LS
99 Honda Civic SI
04coloradols is offline   Reply With Quote
Old 12-15-2010, 09:15 PM   #11
Factory Fresh
Calendar Spread  100K
05 bow tie's Avatar
Send a message via MSN to 05 bow tie
04 urs might be the resistor, thats what i was taught when it only works on high its usually the resistor
05 bow tie is offline   Reply With Quote
Old 12-15-2010, 09:36 PM   #12
How-To CM
Bayer-Z28's Avatar
Yep... From what I've researched here "4" is a full 12v (13.5) and doesn't need the resistor. If it doesn't work at all it may either be the plug, ground or fuse (power supply.)
2004 Z71, 2.8L, Auto.... Ported TB, Tune, MAXX Shackles + Crank, 31" DTs.. HP Tuners
2000 Camaro Z28, 438/412RW.. H/C/I/E/S/Fuel Stuff.
http://www.fquick.com/35057
Bayer-Z28 is offline   Reply With Quote
Old 12-16-2010, 03:26 PM   #13
alright thanks.
99 Honda Civic SI
