4wd not working - Chevrolet Colorado & GMC Canyon Forum
Old 01-11-2011, 11:12 AM   #1
355 O.G.  Chapter Founder  Contributing Member  Nation Advocate  Public Service  NESM 08  NESM 09
rsquires67's Avatar
4wd not working
I searched and cannot find a real answer to my question. I had to replace the battery last week and ever since the 4wd hi or low will not engage. I have removed the battery for 30 plus minutes which got the windows and door locks working again.
I have checked fuses and relays all fine. Actuator and TCCM are getting power. So I am leaning toward the BCM program. No codes but my shop has a Tech II scanner and it is showing both 4hi and low as disabled. Everything else is showing fine on the scanner. They are researching it more. But how do you enable the 4hi and low with the tech 2??? Do we need just to reload the program to the BCM??? If that doesn't work then I guess maybe time to replace some parts... My guy is pretty cool and has listen to me so far....
Anyone know anything about removing the fuse to a minute then turn the key to run and then to off 5 times?????
Thanks!!!!
From New England area? Check out the local chapter out WWW.NEC355.net
rsquires67 is offline   Reply With Quote
Old 01-11-2011, 04:33 PM   #2
Re: 4wd not working
IDK if this will work on yours or not but, remove the center bezzel and unplug the harness for the 4x4....wait 5 min......plug it back in. I reset mine once like this a few years ago and have not had any issues sence mine is an 04 and will engage the 4x4 high when pluged back up and will work fine. just a thought, not a promise.
Mark
Old 01-11-2011, 05:34 PM   #3
rsquires67's Avatar
Re: 4wd not working
I will give it a try. Had it unplugged for a minute but will try if for 5. At this point will try anything. When I had it unplugged for the minute I got the service 4wd show up on the DIC display.
Old 01-11-2011, 07:53 PM   #4
Lifetime Contributing Member  100K
Send a message via AIM to amoore117
Re: 4wd not working
once you unplug the selector it will always show with the service 4WD, atleast in my 06 it always has
amoore117 is offline   Reply With Quote
