p0017 CEL code - Chevrolet Colorado & GMC Canyon Forum
LinkBack (7) Thread Tools Search this Thread Display Modes
Old 04-14-2011, 12:23 AM   7 links from elsewhere to this Post. Click to view. #1
Martin_the_great's Avatar
p0017 CEL code
Anyone have any ideas what it may be? I have changed the Camshaft sensor and the actuator valve right next to it... is it calling for a crank sensor? If so where on the engine is it located?
Martin_the_great is offline   Reply With Quote
Old 04-14-2011, 12:41 AM   #2
Contributing Member  How-To CM  Public Service  355Loyalty
jrotundo's Avatar
Re: p0017 CEL code
http://www.355nation.net/forum/engin...am-sensor.html
from the posts in that thread, it can only be either the cam sensor or cam actuator someone else will chime in im sure.
jrotundo is offline   Reply With Quote
Old 04-14-2011, 01:02 AM   #3
Re: p0017 CEL code
Ya well both are changed... so I am at a loss
Old 04-14-2011, 01:09 AM   #4
jrotundo's Avatar
Re: p0017 CEL code
reset the code and maybe leave the battery disconnected for 20 min...?
Old 04-14-2011, 04:24 PM   #5
Re: p0017 CEL code
I have erased the code with the reader and have done the battery thing. Nothing.
Any chance its the crankshaft sensor?
Old 04-17-2011, 02:12 PM   #6
Re: p0017 CEL code
I'm haveing the same code issue. 2006 3.5 Is it possible the oil passeges at the end of the cam actuator is plugged?
bgchlln is offline   Reply With Quote
Old 04-17-2011, 02:26 PM   #7
Chapter Founder  Nation Elite  100K  USASM2012  MESM 10  MESM 11
07ColoradoBLK's Avatar
Re: p0017 CEL code
im having the same thing bro.. it'll come on every once in a while and then it'll turn itself off .and be off for months on end then randomly come back .
ive changed both sensors, and reset battery 8 times.. cleared code 5 with code reader. its a never ending battle
2007 2.9L
facebook
http://www.355nation.net/forum/stl355/
R.I.P Skitz 6/20/84-6/27/11
STL355
07ColoradoBLK is offline   Reply With Quote
Old 04-17-2011, 05:40 PM   #8
Re: p0017 CEL code
From what we have been reading, its just the actuator valve that everyone has been changing. But if we have done that and its still coming back... what else could it be? Could it be the camshaft actuator itself? One of the mechanics at the dealership said to maybe run some engine flush or some seafoam engine treatment through.
Old 04-18-2011, 03:43 PM   #9
Re: p0017 CEL code
i had the same problem with it coming and going even after i replaced the exhaust camshaft position thingie. the first one was from rock auto and it was a POS after that i bought one from the dealership now the truck runs perfect.
Ive had a hot one in my mouth and i loved it.
Every inch of it.
pcream is offline   Reply With Quote
Old 04-18-2011, 06:11 PM   #10
Re: p0017 CEL code
I bought the sensors from a dealership. The Actuator valve solenoid was from a wrecker... maybe that one is messed up too?
Old 04-18-2011, 06:28 PM   #11
Re: p0017 CEL code
when i bought mine the guy at the parts desk said they keep 10 instock b/c they fuck up so much. it wouldnt hurt to pull it out and look at the screens since its just one bolt and a plug to remove it.
Every inch of it.
Old 04-21-2011, 02:05 PM   #12
Re: p0017 CEL code
Do I need a tech2 tool to relearn on the sensors?
Old 04-27-2011, 04:19 PM   #13
355 O.G.
longbow986's Avatar
Re: p0017 CEL code
That my friends is the Camshaft actuator solenoid valve, which is on the passenger side of the engine, its right underneath the engine harness wire and just behind the oil filler cap! remove the screw and metal holder and check to see if its missing any of the screens, if so, replace it! it should be like 70 bucks or something, someone will chime in with a price hopefully.
ALSO WHILE WE'RE ON THIS SUBJECT.
Will the failure of this device cause the engine to run without VVT? and instead operate as a normal non-VVT engine? if anyone knows what the heck i mean by that.
http://i48.photobucket.com/albums/f212/LongBow986/MS14Gelgoogsig.jpg
It's idiot season
Let the hunting begin
longbow986 is offline   Reply With Quote
Old 04-27-2011, 10:45 PM   #14
Re: p0017 CEL code
Yes the engine will run in a non VVT mode, but you will usually (not always) get a trouble code if it fails.
Old 04-29-2011, 02:34 AM   #15
Re: p0017 CEL code
All screens are there.
Old 04-29-2011, 03:03 AM   #16
Re: p0017 CEL code
I just sold that sensor off my old 3.5 for like next to nothing..if I still had it I would have sent it to ya man, sorry.
Now as for your issue.
When you say crank sensor I am guessing you mean the crank shaft sensor. i do still have that one. It's located down on the driver's side at the bottome. Near teh back of the block. It will be the ONLY one near the back of the block on teh driver's side. You remove one bolt and a decently long sensor will come right out. make sure before you replace it that the wire's are not cut or something like that, otherwise replaceing it would be pointless.
let me know if you want it, i can ship asap now and will be dirt cheap.
Old 04-29-2011, 03:08 AM   #17
xkmacx86
TOTM Winner  Nation Elite  OG Lifetime Contributing Member  How-To CM  SuperMeet Organizer  Calendar Spread  Skitz Award  100K  USASM2012  WCSM 10  WCSM 2014  WCSM 2015
BADLANDER's Avatar
Re: p0017 CEL code
sometimes if the screens are clogged, even thought all are present, the actuator can fail.
this seems to be a common issue recently. i just wish i had these threads a while back when i was having problems.
BADLANDER is offline   Reply With Quote
Old 04-29-2011, 06:15 PM   #18
355 O.G.
longbow986's Avatar
Re: p0017 CEL code
Thanks for keying in on that SSGJurista i knew it wouldnt affect TOO much, but i do know that without that particular system functioning, you lose a hair of power and gas mileage.
Good to get it replaced. damned expensive tho, even tho its a QUICK AS HELL fix, if i get another one, i might make a how to on replacement
It's idiot season
Old 04-30-2011, 01:09 PM   #19
Re: p0017 CEL code
I actually took the sensor apart and cleaned it. There is an allan head screw at the end of the shaft. It unscrews a cap, then a ball and spring come out too. I cleaned it in the varsol tank at work and still nothing May try a crank sensor next.
Old 05-03-2011, 07:51 PM   #20
Re: p0017 CEL code
My truck is running good but it just is running warm and has a check engine light for P0017 as well. It does not stumble or misfire. I replaced the solenoid assy with a new dealer unit and the truck stumbled and would not run....bad unit from dealer? maybe. got another one, same thing.... put the original one in runs smooth but check engine light came right on. i OHMED checked the old solenoid and it was good.
So I replaced the camshaft position sensor with a new one no change.....
crankshaft position position sensor....no change.
I then removed the valve cover(pain in the butt) and checked the timing....as per mitchell on demand, at top dead center the camshaft position actuator was not lined up. After releasing oil pressure we tried to move the actuator and it seemed to be locked up.....ordered a new item hopefully it will fix this problem. It will not advance and seems to be stuck wide open. I will tell you if it works.
boneheadracer is offline   Reply With Quote
LinkBack to this Thread: http://www.355nation.net/forum/i4-i5-engine-drivetrain/43702-p0017-cel-code.html
codigo p0017 chevrolet colorado This thread Refback 06-20-2016 10:58 PM
p0017 chevy colorado This thread Refback 11-26-2015 08:05 PM
p0017 chevrolet colorado This thread Refback 04-05-2015 11:16 AM
p0017 code chevy colorado This thread Refback 02-22-2015 06:34 PM
What is CODE P0017? This thread Refback 02-14-2014 02:40 AM
08 Colorado P0017 at Askives This thread Refback 12-21-2013 05:46 AM
p0017 CEL code - Chevrolet Colorado & GMC Canyon Forum This thread Refback 11-18-2013 09:54 AM
