No heat!!!! - Chevrolet Colorado & GMC Canyon Forum
Old 11-27-2011, 12:01 AM   #1
Next Venture Motorsports
Contributing Member  How-To CM  Calendar Spread  355Loyalty  100K  USASM2012
Cherry's Avatar
No heat!!!!
Ok I need some help my A/C works great but my heater won't work at all I need some help. I don't really know where to start. Thanks for the help
Cherry is offline   Reply With Quote
Old 11-27-2011, 12:04 AM   #2
I fucking atoadaso!
Chapter Founder  Nation Elite  Contributing Member  How-To CM  Calendar Spread
BMFP's Avatar
Re: No heat!!!!
Does it blow and its just not hot or will it not blow at all when the heater is on?
BMFP is offline   Reply With Quote
Old 11-27-2011, 12:04 AM   #3
The LED Dude
Nation Elite  Lifetime Contributing Member  How-To CM  355 Celebrity  MTS  Skitz Award  355Loyalty
captainrab's Avatar
Send a message via ICQ to captainrab
Re: No heat!!!!
Check the cable and the valve at the heater core
CUSTOM LEDs LIVE HERE
http://www.355nation.net/forum/limit...ol-airbag.html
captainrab is offline   Reply With Quote
Old 11-27-2011, 12:07 PM   #4
Cherry's Avatar
Re: No heat!!!!
I blows air but does not blow out heated air. I don't exactly know where the heater core is do you have a picture of the heater core?
Old 11-27-2011, 12:34 PM   #5
Military Service  Contributing Member  How-To CM  SuperMeet Organizer  Calendar Spread  355Loyalty  100K  SESM 11  SESM 2013  SESM 2014  SESM 2015  SESM 16  CFSM 2016
DigEm's Avatar
Re: No heat!!!!
Behind the dash passenger side, there are two hoses running through the firewall on the passenger side under the hood, those are the heater core hoses, coming from the radiator, the two hoses at the center top of the picture below. The heater core is inside behind the dash right there.
DIG EM
2005 Colorado Z71 2WD
DigEm is offline   Reply With Quote
Old 11-27-2011, 12:39 PM   #6
Re: No heat!!!!
Hey man I just had a thread about no heat too. It was the cable for the baffle like captainrab said. Not saying this is it but it was simple and is easy to overlook. The cable has a plastic portion that clips to a metal holder on the dash. If it isn't clipped in it won't control the baffle. The cable will move but it really isn't doing anything. I have pics but dunno how to upload them from my phone...good luck
TexasZ71 is offline   Reply With Quote
Old 11-27-2011, 02:10 PM   #7
Re: No heat!!!!
Let start with the basics. Is the radiator full of coolant? Is the overflow bottle full of coolant to the full line? IF they are, then feel the hoses into and out of the heater core. Are they hot? If not, then you have a coolant flow problem to the heater. It is common to plug up a heater cores if you are using "Deathcool" antifreeze and air gets into the system. Have you had to add an appreciable amount of coolant in the past?
When you removed the radiator cap to check the level did you find any redish brown residue (either gooy or crystals) around the cap? If so then you have the Dexcool problem and it will need to be thoroughly chemically flushed.
If both heater hoses are hot, then coolant flow to the heater core is OK and you have an air flow problem across the heater core. At this point I would be checking the cable referred to in the previous postings.
Good luck.
n9cv is offline   Reply With Quote
Old 11-27-2011, 03:36 PM   #8
Est. 1992
Colorado Kowalski's Avatar
Re: No heat!!!!
Remove your HVAC controls by popping off radio bezel and removing two small bolts, make sure both cables running parallel to the back of the HVAC control and crossing eachother are connected to the back of the turn nobs on the heat selecor, I had this problem and thats all it was
2004 Chevy Colorado z71 4x4 - SOLD
Colorado Kowalski is offline   Reply With Quote
Old 11-27-2011, 11:40 PM   #9
Cherry's Avatar
Re: No heat!!!!
Ok that sounds like it is the problem because my Heating and cooling knob has always be hard to turn and sounds like it is about to snap some times. I really don't use the heater until mid November because I live in AZ. So this problem seemed recent although it could be an old problem croping up now, instead of earlier. Thanks for all the input I really apreciate the help I will let you all know if that was the problem and if it soved it. And by the way TexasZ71 I did read your thread but scince you also had A/C problems i didn't read the entier thread lol. so I just posted this one for myself that my little brain could understand
Old 11-28-2011, 10:59 AM   #10
Re: No heat!!!!
yah..i did think i had a/c problems but really it was just stuck half way between heat and cold so i wan't getting that much cooling. here is a pic of it unclipped. clips in pretty easy.
Old 12-07-2011, 01:56 PM   #11
Cherry's Avatar
Re: No heat!!!!
Hey thanks everyone for all of the input. It was the heater controls and no its really warm in my truck. like said above it was that my cables behind the heating controls became loose and were binding up.
