Low Idle Speed - Chevrolet Colorado & GMC Canyon Forum
Old 12-24-2011, 09:03 PM   #1
Low Idle Speed
I searched and didnt come up with much that worked.
Its the weirdest thing, consistently 50-100 rpms below the commanded idle and it gets grumpy when it gets to the low 500's and gets rough. I'm commanding 650 once warmed up and I even played with the idle in the vcm controls and it stays 50-0rpms below the commanded rpm but will command any rpm I want. What is going on? Its wholly capable of idling at 650 but doesnt when commanded to do so. So far the TB has been cleaned, the maf cleaned and we've rest the computer both by HPT and by disconnecting the battery and it keeps doing it. We also tried disconnecting the exhaust cam thingy that 355 nation said causes this and it did not effect it. My next thing I'm going to try is scan it and see what the exhaust cam is actually doing. If not I'm going to make him replace his 65k old spark plugs.
I've got logs and configs and my tune file. I just did some basic stuff on this one because it doesnt have a wideband on it. Nixed Tq management, put the correct trans tables in, put in real PE values, tweaked the maf and spark a bit. I used the vcm controls to play with it a bit, moved the cam all around and it worked fine, played with the idle speed and some other stuff, pretty inconclusive.
Oh and it also throws the low idle speed code on occasion, its not terrible but its pretty annoying to idle at like 550-600 rpms, no other issues, still goes like a raped date and will smoke the tires off. Its an 05 z71 single cab 3.5 by the way.
Leafy is offline   Reply With Quote
Old 12-24-2011, 09:07 PM   #2
Nation Elite  USASM2012
xseler's Avatar
Re: Low Idle Speed
65k on the plugs?? That's the second thing I would've tried ---- cleaning the TB is the first.
By the way, Denso Iridiums are great plugs.
"Life's a virgin, because a bitch is just too damned easy."
xseler is offline   Reply With Quote
Old 12-25-2011, 06:20 PM   #3
Re: Low Idle Speed
Funny thing is its not misfiring. I think I might try increasing the idle under speed spark advance in that area. It just weird, like its not entering closed loop idle control (it is of course entering closed loop fueling).
