| | #21 | |
| Nation Affiliate | Quote:
Sent from my iPhone using AutoGuide.com Free App | |
| | #22 |
| Premium Member | Re: 3.5L manual trans?
Is not a straight swap dirtyboy. You'd have to both get new output shafts and tailhousings.
| | #23 |
| Nation Affiliate |
Overall I can't see it being that difficult other than seeing how the computer would respond Sent from my iPhone using AutoGuide.com Free App |
| | #24 |
| Nation Affiliate |
Assuming parts are able to be swapped without major modification Sent from my iPhone using AutoGuide.com Free App |
| | #25 | |
| Nation Elite | Re: 3.5L manual trans? Quote:
__________________ -Brian in the market for a V8 truck | |
| | #26 |
| 5cylinder and Tire slayer | Re: 3.5L manual trans?
is was in the H3 wasn't it?
__________________ -Tribo ![]() RIP SC RIP Skitz "Only the Good die young" 1997 S10 ZQ8 /2.2 5-Speed 2004 Colorado ZQ8 /3.5/3.7/3.5 Auto (Totaled 10-6-2011...RIPieces) 2004 Colorado ZQ8 /LSX/T56 |
| | #27 |
| Nation Affiliate Join Date: Dec 2009 Location: Northville, MI
| Re: 3.5L manual trans? Yes it was. A 4x4 cannot be converted to 4x2 without a complete rebuild, and even then I'm not sure. The 4 cyl and 5cyl manuanl trans is identical. However, the flywheel and clutch are different. For going auto to manual or vice-versa, the PCM would have to be reflashed. The AR5 is quite cheap in yards. I've heard of them selling for under $300 in good condition. In fact there are several on car-part.com for that price. <= swapped an AR5 into his supra.
__________________ Lime-Swap.com |
| | #28 | |
__________________ SASed with a dana 44 front/14 bolt sf rear, 4.88 gears with a eaton tru trac, 37" cooper discoverer stt's on dick cepek dc2 17x9 wheels, 47" chevy springs with 4" lift and stock 52" rear chevy leafs, Bilstein 5125 shocks, custom winch bumper with smittybilt x20 10k winch. Soon to come: 4l60e auto swap, a Dana 300, and a little secret for the engine. | |
| | #29 |
| Nation Elite | Re: 3.5L manual trans? yes. good source for a clutch upgrade also
| | #30 | |
I would be interested in hearing from other forum members on this Sent from my iPhone using AutoGuide.com Free App | |
| | #31 |
Your PCM doesn't keep mileage. I believe it's the bcm. Crew cab ext reg its all the same. When you say tranny lines are you talking about to a cooler? I have the v8 radiator so I would use it and get lines for it. Rear end gearing are the same. My PCM is tuned for the 5 speed by emaxxer.
| | #32 | |
__________________ Lime-Swap.com | |
| | #33 |
So it'd probably be easier for me to get another PCM and have someone pretune it to my truck.
| | #34 |
| Re: 3.5L manual trans? Yep, unless you don't mind the downtime.
| | #35 |
| Retired and Sleeping Late | Re: 3.5L manual trans?
Manual trans doesn't use a cooler so lines going to the radiator would be a non-issue.
__________________ Definition of Irony.... The food stamp program, part of the Department of Agriculture, is pleased to be distributing the greatest amount of food stamps ever. Meanwhile, the Park Service, also part of the Department of Agriculture, asks us to "Please Do Not Feed the Animals" because the animals may grow dependent and not learn to take care of themselves. |
| | #36 |
| Nation Affiliate |
Right. I would just have to plug them at the radiator. He would have to run new lines, though Sent from my iPhone using AutoGuide.com Free App |
| | #37 |
I have a v8 radiator that has the cooler in the bottom. Unless you upgraded then you'd just have a normal trans cooler in front of your radiator that you'd have to remove. I'd just cap them off and run it without a cooler for now.
| | #38 |
| Nation Affiliate | |
| | #39 |
I'm trying to find the pieces I need to finally get rid of this 5 speed. Hardest thing is goin to be finding a tranny I believe. I really don't wanna pay $800 or more for one lol. That and the h3 floor shifter.
| | #40 |
