09 3.7 gut first cat.. Yes , no.. Should I ? - Chevrolet Colorado & GMC Canyon Forum
Go Back   Chevrolet Colorado & GMC Canyon Forum > Tech Area > Engines/Performance/Tech Questions > I4/I5 Engine & Drivetrain
Old 01-06-2013, 11:26 PM   #1
SECSM2012 How-To CM Purple Heart
rastok's Avatar
Hey guys, on my 2006 2.8 I had gutted my first cat and I only saw improvements, one of the best mod I've done to it
Now I bought a 09 3.7 and I was wondering if I was gonna come with similar result, I've read multiple tread and I can't find good info..
I'm willing to eighter relocate the first o2 sensor down or add a no fouler to the second sensor but I can't decide what option would be the best...
Power loss, power gain.. Again idea are not clear..
Thanks a lot guys. I'm a bit counfse with my new 3.7
I know my english S*** please dont remind me
________________________________
rastok is online now   Reply With Quote
Old 01-07-2013, 10:23 AM   #2
rastok's Avatar
Re: 09 3.7 gut first cat.. Yes , no.. Should I ?
Bump
Old 01-07-2013, 10:41 AM   #3
Joe canyon's Avatar
Yes you should it will make the truck pull alot better . Is the truck rc,gt4,g80,m30 optioned.
Joe canyon is offline   Reply With Quote
Old 01-07-2013, 05:38 PM   #4
rastok's Avatar
G80 3.73
Old 01-07-2013, 06:35 PM   #5
rastok's Avatar
Makes andifferance?
Old 01-07-2013, 06:50 PM   #6
Joe canyon's Avatar
My advice would be to buy a 3.5 manifold port and gut it and put that on. That worked better on mine. Yes it will make a little diffence.
Old 01-07-2013, 07:22 PM   #7
Calendar Spread USASM2012 Lifetime Contributing Member
dbizzle's Avatar
Yes, gutting the cat will always show a better performance than leaving it stock due to the restriction
Sent from my iPhone using AutoGuide.com App
dbizzle is offline   Reply With Quote
Old 01-07-2013, 10:11 PM   #8
rastok's Avatar
I'm trying to avoid spending 200$ on a 3.5 manifold that I'm gonna gut... At this point I would buy headers...
I was more Loking for info and outcomes from ppl that gutted their primary cat on their 3.7 manifold.
And I believe that the o2 sensor on the 3.5 is not at the same position and that its throwing a cel...
Old 01-07-2013, 10:22 PM   #9
collyman07's Avatar
Send a message via AIM to collyman07
if you take off the second cat you wont get a code.. im not sure about the first i left that one alone more expensive to replace if you gut it might as well buy some headers..
collyman07 is offline   Reply With Quote
Old 01-07-2013, 11:52 PM   #10
Joe canyon's Avatar
[QUOTE=rastok;1812663]I'm trying to avoid spending 200$ on a 3.5 manifold that I'm gonna gut... At this point I would buy headers...
And I believe that the o2 sensor on the 3.5 is not at the same position and that its throwing a cel...[/Q.
I'll say it again you will get a small gain .
Old 01-08-2013, 06:33 AM   #11
rastok's Avatar
Any idea on what's the best way to fix the o2'sensor to get no code ?
Old 01-08-2013, 07:37 AM   #12
USASM2012 How-To CM Contributing Member
07_ZQ8's Avatar
The 3.7's have an 02 right in front of the first CAT and then one right after the CAT. you WILL have to move the second 02 to behind the 2nd CAT or you will get codes, fouler will not fix this. on the 3.7's the second 02 is still referenced not just for checking the efficiency of the Converter, but also used for checking/ correcting fuel trims in a small way, so if you put a non fouler in, it wouldnt CEL immediately, but after a day or so it would... I personally did not like the sound of my 3.7 CAT gutted, very rattly and pingy, some others like this. I really wish I would have just waited and bought my OTTP header first before gutting my factory CAT. :-)
Victory Red ExCab 2007 Canyon ZQ8
http://i41.photobucket.com/albums/e285/r_cracer65/signew_zps54bdc035.jpg
07_ZQ8 is offline   Reply With Quote
Old 01-08-2013, 01:01 PM   #13
Joe canyon's Avatar
The non fouler worked on my 2008 for over a year and a half. Never moved the downstream o2 sensor either . Also the sensor bungs on 3.5 and 3.7 are very close if not exactly in the same locations.
Old 01-13-2013, 02:47 PM   #14
rastok's Avatar
The 3.7 has 2 o2 sensors on the manifold while the 3.5 has only one bro... Not exactly the same...
Old 01-13-2013, 02:54 PM   #15
Moderator
355Nation Moderator Nation Elite MTS How-To CM Contributing Member NESM 11 Calendar Spread NESM 09 NESM 10
comdrop9073's Avatar
I ran mine gutted with non-foulers for about 6 months, I had no problems.
-Dave
comdrop9073 is online now   Reply With Quote
Old 01-13-2013, 06:23 PM   #16
rastok's Avatar
Simply gutted it..
Old 01-13-2013, 08:03 PM   #17
Moderator
I bought it already gutted from Canyon08Z71, but nothing else was modified. I used two non foulers, just the first one drilled out 1/2"
-Dave
Old 01-13-2013, 08:07 PM   #18
5cylinder and Tire slayer
Calendar Spread How-To CM 355Loyalty MESM 11 SESM 10 100K TOTM Winner Nation Advocate MESM 10 Contributing Member NESM 09 Nation Elite
WTRacing's Avatar
yeah you just get a plug for the other one and all set.. very simple
-Tribo
RIP SC
RIP Skitz
"Only the Good die young"
1997 S10 ZQ8 /2.2 5-Speed
2004 Colorado ZQ8 /3.5/3.7/3.5 Auto (Totaled 10-6-2011...RIPieces)
2004 Colorado ZQ8 /LSX/T56
WTRacing is offline   Reply With Quote
Old 01-13-2013, 11:22 PM   #19
07_ZQ8's Avatar
the 3.5's have one in front of the manifold cat and then a second one after the second cat. 3.7's have on in front of the mani cat and one right after the mani cat. i relocated mine to after second cat because it was easy and didnt want to throw any codes. now it doesnt matter since I have HPT and no cats anyways.
Old 01-14-2013, 10:42 PM   #20
rastok's Avatar
What you mean by a plug? To close the opening that its gonna do when I move the second sensor down after the second cat?
