Noob question and fixed my ignition switch - Chevrolet Colorado & GMC Canyon Forum
Go Back   Chevrolet Colorado & GMC Canyon Forum > Intros, TOTM, 355Nation News and Information > New Member Introductions
Old 04-21-2017, 02:17 AM   #1
Hey guys finally fixed my issue!
it was my ignition switch(replaced) and passlock(reset)
So I have a new issue, however where do I go to post my questions in the forum>?
currently dealing with my door lock fuse popping and it's making my power windows not work. I have to replace the fuse every time. Has this happened to anyone>?
Noob question and fixed my ignition switch-chevrolet-colorado-mk1-fuse-box.jpg
Noob question and fixed my ignition switch-20140923_103905.jpg   Noob question and fixed my ignition switch-20160912_192223.jpg
LsColorado04 is offline   Reply With Quote
Old 04-21-2017, 05:45 AM   #2
Re: Noob question and fixed my ignition switch
to the Nation.
Is there any pattern to when the fuse blows or does it just do it randomly? Does the fuse blow when you are trying to operate the switches for the windows or doors? How long have you had the truck?
cart7881 is offline   Reply With Quote
Old 04-24-2017, 03:11 AM   #3
The fuse usually pops when the driver side Doorlock button is pressed or just randomly pop. it's very tricky
Old 04-24-2017, 06:37 AM   #4
Lifetime Member
TOTM Winner  Contributing Member  Lifetime Contributing Member  How-To CM  Calendar Spread  355 Celebrity  355Loyalty  100K
Iarado's Avatar
Welcome to the Nation . . .
Iarado is offline   Reply With Quote
Old 04-24-2017, 07:41 AM   #5
How-To CM  Calendar Spread  355Loyalty  100K  SESM 2013  SESM 2014  SESM 2015  SESM 16  MESM 15
Tweek's Avatar
Welcome to the "Nation" !!!
Electronic issues are the worst... Good luck with the fix !!!
"Diamond"
2015 Chevrolet Colorado LT Ext. Cab 3.6 / V-6 / 6 Speed Auto. / 4x2
Silver "Ice" Metallic / 17" Blade Silver Metallic Wheels
Jet Black Cloth Int. / 3:42 Gearing / Tow Package
GM Performance Exhaust
GM Performance Air Induction Intake
"Spidey"
2005 "Chevrolet" Canyon Z-88 4x4 REG. Cab 2.8 / I-4 / 5 Speed
Z-71 Wheels 3:73 Gears
Victory Red / Superior Blue Metallic / Gun Metal Metallic
Webbed And Spiderman 3-D Logos
Tweek is offline   Reply With Quote
Old 04-24-2017, 12:21 PM   #6
Power for the door lock circuit goes to the logic board in the driver's door switch module. There is no circuit diagram in the Service Manual for the logic board, so it is unclear how the door lock circuit power affects the window circuit. The symptoms do seem to point to a defect in the driver's door switch module. Does the fuse blow if the door lock switch on the passenger door is pressed?
Old 04-25-2017, 11:50 PM   #7
I just unplugged the passenger door switch all together. Plus that window does not work for nothing. Yeah, it's pretty bizarre every-time it pop's my driver side windows will not work. For a while the passenger window would only go down but not up.
Its only when I put a new fuse in the doorlock spot the driver side will work for about 3-4 days and go out again.
I have replaced the master window switch and nothing has changed.
Old 04-26-2017, 05:53 AM   #8
Well, something is causing an intermittent short. A couple of guys have had problems with the wiring breaking in the door harness in the hinge area. Might be a possibility in your situation. To check the wiring you will need to remove the door, which for these trucks is simple. Just remove the two 10mm bolts and the retainers and the door just lifts off the hinge at the pivot. No removing hinges or adjustments required after reinstall.
