Service Bulletin: #07123A Engine Intake Valve Seat/Misfire - Chevrolet Colorado & GMC Canyon Forum
Go Back   Chevrolet Colorado & GMC Canyon Forum > Tech Area > How-To/Tutorials/Reviews/Service Bulletins > Service Bulletins
Old 01-18-2010, 08:25 PM   #1
Ron Lopes
How-To CM 100K Contributing Member
xronx's Avatar
Send a message via ICQ to xronx Send a message via AIM to xronx
The Following is a GM direct letter to owners of the Colorado's and Canyon's listed years 04-06, both 4 cylinder 2.8L and 5 cylinder 3.5L trucks. Breakdown of specific Vin inclusion as follows.
Note: This condition may be diagnosed through several DIY methods.
(1) let the truck sit at idle for about 30min. if equipped with aux. and access. equipment such as A/C, systems, lights ect. Enable all. Observe trucks idle; a rough idle should lead to further diagnosis.
(2) A compression check can be used, though more invasive than a cylinder leak-down test. Either will work. Observe compression/pressurized cylinder for a decline in pressure within, be sure the cylinder is at TDC on the compression stroke as you are testing it.
***WARNING*** If you are not experienced in performing these tests bring you truck to a dealer, leave it to them. It is free as covered in attached Scans of the GM direct Recall, and letter to owner.
LETTER TO OWNER
RECALL INFORMATION
V.I.N. Locations are on various parts of our trucks. the simplest to find is underneath the glass, by the drivers side of the windshield; If difficult to read as it sometimes becomes, another copy of the VIN is on the inside of our drivers side doors. I believe a third is also in the Glove Compartment where our vehicle specific information is held.
xronx is offline   Reply With Quote
Old 01-18-2010, 09:15 PM   #2
How-To CM 355 Celebrity 100K Nation Elite Calendar Spread SESM 09 Contributing Member
swamp_rat's Avatar
Re: Service Bulletin: #07123A Engine Intake Valve Seat/Misfire
mine is starting to tick AGAIN. POS!
355UNDERGROUND-FOR THE MEMBERS, OF THE MEMBERS, BY THE MEMBERS!
STAY TUNED FOR UPDATES!
swamp_rat is offline   Reply With Quote
Old 05-09-2010, 04:21 PM   #3
Southbound Cenla's Avatar
Wut about isuzu!?!?!?
Southbound Cenla is offline   Reply With Quote
Old 12-08-2010, 11:46 AM   #4
I fucking atoadaso!
How-To CM Nation Elite Chapter Founder Calendar Spread Contributing Member
BMFP's Avatar
Old thread but, does anyone know what the repair process is on this? Is it valve replacement or regrind or what?
BMFP is offline   Reply With Quote
Old 12-17-2010, 11:50 AM   #5
On my 2006 Canyon, 4 cyl., they replaced the whole head. I wasn't noticing much in the way of problems so I waited until I had 99,900 miles on it and took it in. They verified that it was affected and took care of it.
John D is offline   Reply With Quote
Old 12-17-2010, 12:33 PM   #6
Howie Felterpuss
Nation Elite How-To CM Lifetime Contributing Member
I've got an 07' 3.7L that had 2 bad valve seats, they swapped the head and it took 3 days.
FixxxerKH202 is online now   Reply With Quote
Old 12-17-2010, 05:20 PM   #7
355 Celebrity
pappawheely's Avatar
I just bought a used '04 engine and the dealer had no record of the repair. I wonder if it's good or not?
"Know when to shoot...And when to Scoot".
http://www.mikesracephoto.com
pappawheely is offline   Reply With Quote
Old 01-16-2011, 04:55 PM   #8
USDM ???
Calendar Spread 100K
05 bow tie's Avatar
Send a message via MSN to 05 bow tie
i have about 82,xxx on mine and it worries me cause mines an 05 so its 6 years old no way i can afford it if it doesnt happen before hand any one know if there is a way to get ahold of gm to talk to someone
YEA BUDDY!
05 bow tie is offline   Reply With Quote
Old 01-17-2011, 08:04 PM   #9
SECSM2012 How-To CM Purple Heart
rastok's Avatar
do you guys know it they could refuse to do the job if my first cat is gutted ??
rastok is offline   Reply With Quote
Old 01-18-2011, 06:40 PM   #10
Ron Lopes
xronx's Avatar
i dont see any way they would know, and thats post valvetrain... dont say anything, if they question you, deny any knowledge of it...
also to know if you have the issue, they will perform and cylinder LEAK DOWN test, it's a fairly simple, not so invasive procedure, however they will charge diag time. if the issue is not present.
Old 01-18-2011, 07:28 PM   #11
rastok's Avatar
ok.. im 99% positive i have a bad head.. i have a jumping iddle every so ofen, a cel that go on and off, it's leaking oil from all over the head... im just scared to take it in and they dont find nothing and after im stuck with all my problem... i would like to make sure they will change everything before a take it in... question for you.. do i have to take it in while ther cel is on or it dosent mattter...
Old 01-18-2011, 08:22 PM   #12
Ron Lopes
xronx's Avatar
Doesn't matter if the cel is illuminated, if there was a cel there will be a memory (history) code.... also if its intermitten a possible Pending code... they will find the code if it is there, the leaking around the head could be multiple things... also if you have the "lobby" rough idle, take it in, at the worst it costs you a lil. bit of money. If you wait til you pass your warranty, you'll be kicking yourself.
I personally haven't looked into the issue on my own vehicle... i work on cars all day long, if it starts and drives, i could care less... for someone who isn't willing to spring out the full cost for repair out of pocket, or do it in their driveway... just take it in.
Old 01-19-2011, 06:54 PM   #13
rastok's Avatar
Ok, good info thanks alot, for info i have a 2006 with 67000 km on it and im not thé original owner of it. Seriously, im f***** scared. LOL
Old 01-19-2011, 07:00 PM   #14
USDM ???
05 bow tie's Avatar
mines gonna be cutting it close if it doesnt happen soon, but my question i bought mine used will they still do it and how can i get ahold of gm to work somethin out if somethin happens after the time limit
YEA BUDDY!
Old 01-19-2011, 08:42 PM   #15
brady's Avatar
I'm pretty sure that this is the problem I'm having...how do i take advantage of this recall...what do i say when i call the dealership?
Mods:
2" Shackle/ TB, Custom Intake, Upper Ball Joint Flip, Baja Lights Behind Grille, GM Bed Rail/Cap Protectors, GM Nerf Bars, Dual Hi/Lo Headlights, MBRP Exhaust, Maglite, 5000k H.I.D.'s in HI/LO, Transmission Cooler
brady is offline   Reply With Quote
Old 01-19-2011, 10:33 PM   #16
Ron Lopes
xronx's Avatar
This is simple. Whether you are first second or third owner, the warranty covers the vehicle, not the owner. Also if you are over the limit by even a mile, they can reject your claim for warranty work, hoever if you are in good standing and a regular customer, they do have some swing with GM, beyond that your looking at getting the service departments DIRECT number to GM to inquire upon after warranty work performed for warranty labor.
If you call up your local dealer, just explain to them you became aware of a TSB for intake valves on xxxx through xxxx year colorado's and they will ask for your vin, also they will tell you to schedule it in so they can perform the cylinder leak down test. Also they should tell you if no issue is present you will be charged the labor/diagnostic charges.
Old 01-19-2011, 10:42 PM   #17
SECSM2012 MESM 10 MESM 11 Lifetime Contributing Member Contributing Member NESM 09 NESM 08
parkerb's Avatar
I have a question for anyone that has had this done. I was going to bring mine in and have it done, already talked to my service advisor and he said he would check it out. The one thing I was worried about though is if they reflash the computer after replacing the head. I have a tune and don't want it wiped out.
parkerb is offline   Reply With Quote
Old 01-20-2011, 10:31 PM   #18
Ron Lopes
xronx's Avatar
I doubt they will, unless the vehicle calls for an update already, which is doubtful.. most likely they will reset the KAM so the sensors can relearn their values and strategies accordingly to adapt to the correcting factors, such as air flow, volume... ect.
Old 02-03-2011, 05:00 PM   #19
Military Service Contributing Member
barman84's Avatar
Do you think they will void this claim if you have oversized tires?
barman84 is offline   Reply With Quote
Old 02-03-2011, 08:35 PM   #20
rastok's Avatar
how do the leak down test is done.. also could they say something is i have a gutted cat '' manifold '' and a flowmaster serie 44
