| Members Technical Staff | How To Install Suspension Maxx Leveling/Lift/Lowering Kit (4X4 and Z71) Disclaimer The community here at 355nation.net urges you to please use caution and seek professional assistance when performing modifications to your vehicle. Before attempting any modification it is advised that you refer to your Colorado or Canyon service manual or contact a certified mechanic as not all GMT355 trucks are the same. The staff and the associated members are in no way responsible for any damages, injuries or other harm inflicted to your vehicle or yourself which may result in attempting these modifications. The posts and content presented on this site reflect in no way the views of 355nation.net or it’s ownership. ![]() A 355nation How To presented by ssgjurista Project Name How To Install Suspension Maxx Leveling/Lift/Lowering Kit Project Description Owners of Canyons/Colorados with the torsion bar front suspension resort to 'cranking' the torsion bar adjuster bolts to gain front end lift. Lifting more than 2" by this method often leads to a harsher ride. The Suspension Maxx Leveling/Lift Kit allows for lifting up to 3" without totally compromising the factory ride. It enhances the overall ride profile and is an economical alternative to more expensive lift kits. It also allows the vehicle owner to compensate for torsion bar sag and fatigue. This patented kit features 'calibrated' cams and keys and by design the same kit also allows for lowering. Also includes bump stops to prevent the upper control arms from hitting the frame bracket when driving over rough terrain. Lift: .75". 1.5", 2.0", or 3.0" Lower: .5", 1.2", or 2.0" Skill Level Easy to Moderate Project Vehicle Make: Chevrolet Model: Colorado Z71 LS 4x4 Year: 2005 Engine: 3.5L Power windows: No Sun Roof: No Tools Needed 1/2" drive torque wrench 1/2" drive breaker bar 1/2" drive ratchet 1/2" drive universal joint 1/2" drive extension, 9" length 1/2" drive extension, 2" length 27mm socket or 27mm combination wrench (1 & 1/16" socket or 1 &1/16 combination wrench will suffice) 18mm regular depth socket 18mm deepwell socket 18mm combination wrench 15mm or 17mm combination wrench 9/16" combination wrench Hammer Large flat tip screwdriver or prybar Floor jack Jackstands Tape measure Project Time 3-4 Hours Project Cost $200.00 to $220.00 Suspension Maxx Leveling/Lift/Lowering Kit (SMX-MCJRC) Lets take a look at the kit components: The Cam and Key ![]() ![]() Differential Spacers and Upper Control Arm Bumpstops ![]() Shock Hardware ![]() Install Procedures: 1. Measure from the floor to the bottom edge of the front fender on a line through the center of the axle on both sides and record these measurements for later use. In my case, the stock height was 35 & 1/2". ![]() 2. Loosen the wheel nuts on both front wheels 1 - 2 turns. 3. Raise the front of the truck and place jack stands under each frame rail behind the radiator. 4. Remove both tire and wheel assemblies. 5. At this time, install the supplied urethane bumpstops to the frame brackets under each upper control arm. Secure the bumpstop by placing the supplied washer and locknut on the bumpstop bolt and tighten. If needed, use the jack to raise the lower control arm until there is enough room to install the bump stop. 6. Place a floor jack and suitable wooden blocks under the front differential. Raise the jack until it touches the differential. Locate the four bolts securing the differential to the frame. Two bolts are just to the passenger side and the other two are located at the end of the axle tube on the driver's side. With the jack supporting the diff, loosen the two passenger side bolts and remove the two driver's side bolts. Slowly lower the jack until there is enough room on the driver's side to insert the supplied spacers. They go between the top of the mounts and the vehicle frame. Apply Lock Tite to the last inch of bolt threads, install the bolts, and tighten several turns to ensure the bolts are started. Repeat this step for the passenger side bolts. Use the jack to raise the differential to its' original position. Tighten the bolts to 112 lb ft. ![]() ![]() ![]() 7. Locate the factory torsion bar keys and adjusting bolts at the rear of the torsion bars. Left (Driver's) Side ![]() Right (Passenger Side) ![]() Starting with the right side torsion bar, turn the adjuster bolt counter-clockwise. This will 'unload' or remove tension from the torsion bar. Completely remove the bolt. Note: the smaller of the two 'half moons' is on top of the key. Raise the torsion bar with one hand and wiggle the key with the other hand to break it loose. If the key is difficult to remove due to rust/dirt, you may tap it with a hammer. DO NOT, UNDER ANY CIRCUMSTANCES, USE HEAT TO LOOSEN THE KEY! Heat from a torch will have a negative effect on the torsion properties of the bar. Remove the key from the torsion bar. Repeat this step for the left side torsion bar. Right Side key Removed ![]() Right Side Torsion Bar ![]() Note: The torsion bars are coded for each side and are not interchangeable. You can use this code if you ever need to order a new torsion bar. ![]() ![]() The factory key appears bigger than the Suspension Maxx key. But the factory key is cast while the SM key is forged from 4140 chromemoly steel. The Suspension Maxx key also feels heavier. ![]() ![]() 8. Apply a thin film of Anti Seize to the 'gear tooth' areas on each cam. ![]() 9. Look closely at the cam; one side has an 'A' stamped on one of the teeth and the other side has a 'B'. The inside of the key is also hex shaped to match the torsion bar. Now look at the Suspension Maxx key; each gear tooth area is stamped with a number. The amount of lift or lowering is determined by 'calibrating' one of the letters on the cam to a number on the key. For example, if I wanted to lower my truck 2", I would turn the cam so the letter 'A' faced up and insert it into the key so the letter gear matched up with the number '5' gear on the key. In this case I was aiming for the full 3" of lift so I calibrated the cam/key by matching the letter 'A' to the number '1'. ![]() 10. Once you have calibrated both cam/key assemblies, place the supplied 'U' shaped alignment clip over the top of each key. This clip helps keep the cam and key together while you install it. ![]() Photo showing how the adjuster bolts sits in the key. ![]() 11. Starting with the right side, remove any loose dirt or rust from the crossmember. Hold the torsion bar up slightly with one hand. Use your other hand to hold the cam and key assembly. Make sure to place one finger on the clip as it can slide off and fall inside the frame. Slide the cam and key over the end of the torsion bar. For the A1 position, the angle on the top edge of the key will be parallel to the angle of the crossmember. Once the key is fully seated, remove the clip. Place the small half moon on top of the key; with the larger half moon on the bolt, place the bolt through the crossmember and slot in the key and thread the bolt. Make sure both half moons are properly seated and tighten the bolt clockwise until you feel a slight bit of tension. Repeat this step for the left side. ![]() 12. Starting with the passenger side shock absorber, look at the top mounting nut and washer. You will need at least 3/4" of rod sticking up through the nut. (I had previously replaced the factory shocks with Bilsteins, these shocks have a shorter rod. But for install purposes, lets assume I still have the factory shocks). ![]() Remove the upper mounting nut, washer,shock insulator bushing, and center sleeve (if present). Then remove the lower shock mounting bolt. When you remove this bolt, there is very little clearance with the halfshaft, but it will come out. ![]() Remove the shock from the truck. Remove the lower bushing and washer. Install the supplied shock spacer, then reinstall the lower washer followed by the lower insulator bushing. Remount the shock into the truck but don't install the lower bolt. Make sure the nipple on the bushing is properly seated into the hole in the frame mount. Take the upper insulator bushing and place it onto the hex nut/washer assembly include in the kit. It's a tight fit, silicone grease will make it easier. The hex nut/washer assembly included in the kit is designed to allow for the use of the spacer and still be able to thread onto the top of the rod. ![]() Place the nut/washer/insulator on the shock rod and hand tighten. There should be just enough rod sticking up so you can hold it with the proper tool. (Some rods have flats on each side, some have an indent for an Allen wrench, and others are hex shaped). If you don't have enough rod showing you may remove the shock and shorten the shock spacer. Note: Due to info gathered during my install, if a customer orders a kit directly from Suspension Maxx, he/she can request shorter spacers. Tighten the nut until the rubber insulator bushing is expanded to the diameter of the washer. ![]() Don't worry if this last step sounds a bit confusing. The kit includes an instruction sheet with photos showing how to properly install the shock spacer and hardware. Since I couldn't use the spacer with the Bilsteins, I left it out. Here's the thinking behind using a spacer. At the lower limits of suspension travel, the upper control arm will touch the frame bracket. At this point the shock is fully extended. If this happened while driving over extremely rough terrain, it's possible for the upper arm to slam against the frame. This tiny bit of extra travel could over extend the shock and cause damage. Installing the bump stops and spacers eliminates this possibility. ![]() 13. Install the lower shock mounting bolt and tighten to 70 lb ft. 14. Install the tire and wheel assemblies. Snug the wheel nuts but don't torque them yet. 15. Starting with the right side, turn the adjusting bolt on the Suspension Maxx key clockwise until about 1" of threads shows above the key. Do the same on the left side. Remove the jack stands and lower the truck to the ground and bounce both corners of the front bumper a few times. Then just like you did at the beginning of the install, measure both sides. Since my stock height was 35 & 1/2" and I was going for 3" of lift, I needed the measurement to be 38 & 1/2". If it's not high enough, raise the front so the tires are just off the ground and turn the bolts. Lower the truck, bounce the front end, and measure again. Repeat this process until both sides are at the correct height. ![]() If one of your torsion bars has sagged more than the other, you will need more turns on that bolt. (My driver's side torsion bar had sagged a bit more than the passenger side). ![]() ![]() Note: At 3" of lift in front, my truck set level from back to front. So I backed off the front lift to 2 & 3/4" so I have a very slight forward rake. My final measurement ended up being 38 & 1/4". 16. Tighten the wheel nuts to 100 lb ft. Halfshaft angles at 2 & 3/4" and diff spacers installed. ![]() ![]() 17. Go for a short test drive and listen for any unusual noises. Upon your return, double check your measurements. While driving I noticed the ride quality didn't change except when driving over speed bumps or large potholes. Then it felt a bit stiifer but not harsh. I'm happy with the ride quality. Everyone should have a good idea of what stock height looks like, but here are a few 'after' pics: ![]() ![]() ![]() 1.5" lift shackles on the rear.
__________________ 2005 Z71 LS Crew Cab 4X4 L52, 4L60E, GT4, Silver Birch Metallic, Amsoil Synthetics, SFAN4500, SSK Black Chrome Shifter MAXX Shackles: Click Here! MAXX Cam JR Lift Kit for 4X4 & 2WD Z71: Click Here! MAXX Stak Lift Kit for 2WD: Click Here! PerforMAXX Body Lift: Click Here! Last edited by ssgjurista; 12-06-2009 at 11:17 AM. Reason: spelling |
| Quadruple O.G. ![]() | Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit Very Nice. Thanks for the write up! tires and rims next? |
| Members Technical Staff | Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit Yup, tires and rims are on the wish list.
__________________ 2005 Z71 LS Crew Cab 4X4 L52, 4L60E, GT4, Silver Birch Metallic, Amsoil Synthetics, SFAN4500, SSK Black Chrome Shifter MAXX Shackles: Click Here! MAXX Cam JR Lift Kit for 4X4 & 2WD Z71: Click Here! MAXX Stak Lift Kit for 2WD: Click Here! PerforMAXX Body Lift: Click Here! |
| Guest
Posts: n/a
| Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit i guess that is a ok CV joint angle.. nice write up tho |
| Members Technical Staff | Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit Update When doing the install, I used the A1 calibration to get 3" of lift. Keep in mind this is for torsion bars with little or no sag. Since my driver's side TB had sagged, the difference was apparent in how much bolt showed through the top of the key. When I mentioned this to Larry, he suggested using calibration 'A2' on the driver's TB. Here's the results: Driver's side with A1 ![]() Driver's side with A2 ![]() Compared to Passenger side A1 ![]() I'm starting to really like this kit.
| Members Technical Staff | Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit Thats awesome, nice write up. I may think about this.
| Custom Title Garnered | Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit good write up man.
__________________ BBB crew...all day, every day. |
| Nation Elite | Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit As we discussed on CFans, I think the consensus is this: New, non-saggy TBs: don't need the TBKs. Older, saggy TBs: The TBKs will let you keep the same ride height.
__________________ 05 Canyon EC SLE - I5M Z71 4x4 GT4 4 Mar - 111k miles LED + HAW Strobes | Fold-A-Cover | Line-X OTR | Goodmark Cowl Hood | GP Seats1.5TB/2.5AAL/1BL/.5Diff Drop | RS5300/MA764 Shocks | Bubaloo Skidz | BFG 33-12.5-15 AT/KO 1st Cat Delete | MBRP 409 Turndown | FRAM Boost+RamAir | 3 x Lightforce Blitz | eFan | Tune by Gerry <- Awesome!!! |
| Custom Title Garnered | Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit dont they all sag after time tho?
| Nation Elite | Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit Yes. fuckingfivecharacterminimumbitesmyass
| Nation Advocate Join Date: Sep 2008 Location: Somewhere between Reading, and Williamsport, PA
| Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit Did you use the stock bolts for the dif spacers? what size are the spacers? and did you just unbolt you bars or did you use a tool to take tension off after the bolt is out?
__________________ Menn College of Technology, where beer is plenty and women are myths Toyota always said they were moving you forward, they never said anything about needing to stop |
| | #12 | |
| Members Technical Staff | Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit Quote:
No tool needed, just unscrew the adjuster bolts. Before the bolt is completely out all the tension will be off the TB.
__________________ 2005 Z71 LS Crew Cab 4X4 L52, 4L60E, GT4, Silver Birch Metallic, Amsoil Synthetics, SFAN4500, SSK Black Chrome Shifter MAXX Shackles: Click Here! MAXX Cam JR Lift Kit for 4X4 & 2WD Z71: Click Here! MAXX Stak Lift Kit for 2WD: Click Here! PerforMAXX Body Lift: Click Here! | |
| Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit Wow if I'd of known it was that easy these would've been off my bedroom floor sooner haha
| Nation Citizen | Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit I am not going to beat a dead horse, as I agree with Ranger Bob on the spring rate issue. There are reputable companies out there claiming no ride difference or near stock ride. I KNOW people claim anything for a sale. Could somebody do the glass of wine trick on a mattress with a bowling ball like in the TVcommercial for comparison. lol
| | #15 | |
| | #16 | |
It isn't my 'style' to bullshit anyone. Even if I was a paid spokesperson, I don't think I could lie that easy. If somethings good I say its good, if it's bad I'll tell you it's bad, and if it's ugly, well, then it's ugly. lol When I installed the kit, I adjusted to different heights to check on clearance. What I found was once you went higher than 3", the upper arms came danger close to the frame bracket. At 4", they would touch. So for lift amounts greater than 3", you run the risk of having the upper arms hit the frame. Even at lesser amounts of lift, say 2.5", on extremely rough terrain, the suspension travel could allow the upper arm to move and hit the frame. The SM kit includes bump stops that mount to the frame bracket and prevent the arm from making direct contact. So the claim about a factory like ride is partially true. Having a suspension component hit a piece of urethane is less harsh than the same component hitting against metal. Something I found interesting is the bracket under the upper arm is designed so a bump stop can be easily mounted. Almost like GM intended it that way but decided it wasn't necessary.
| Members Technical Staff | Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit Larry said that in the past two weeks, he has sold several of the Maxx Cam JR kits for the 355s. Said he just sold one today to someone from Canada. Wonder if they are a Nation member?
| Nation Advocate | Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit that was my buddy! haha i'm also planning to get some shackles from you guys soon too! hows the pricing/shipping for us canadian members?
__________________ 2009 Colorado Z71 Crew 4x4 HIDs, Exhaust, L.E.D. tails & 3rd, Sound, Tint |
| New To The Nation Join Date: Oct 2009 Location: Virgin Islands
| Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit Nice howto thread. I ordered the shackles, Differential Spacers, and Upper Control Arm Bumpstops. ssgjurista do you have any closeup pictures showing the bumpstops installed. |
| Members Technical Staff | Re: How To Install Suspension Maxx Leveling/Lift/Lowering Kit Do you mean the upper A arm spacers (balljoint spacers) or the bump stop extensions?
