| Members Technical Staff | Suspension Maxx has enough parts in stock for 3 complete 2WD strut spacer kits. The kit will include a strut spacer, two shims for additional height, ball joint spacers, bump stop extensions, and hardware. The part number on the website: SMX-10185 is just for the spacer and shims. If you want the complete kit, call Larry at 1-888-MAXX-CAM. He owes me an email in the next day or two with a price on the complete kit.
__________________ 2005 Z71 LS Crew Cab 4X4 L52, 4L60E, GT4, Silver Birch Metallic, Amsoil Synthetics, SFAN4500, SSK Black Chrome Shifter MAXX Shackles: Click Here! MAXX Cam JR Lift Kit for 4X4 & 2WD Z71: Click Here! MAXX Stak Lift Kit for 2WD: Click Here! PerforMAXX Body Lift: Click Here! Last edited by ssgjurista; 02-18-2010 at 10:48 PM. |
| Nation Citizen | Re: 2WD Strut Spacer Kit nice ive still gotta call him bout the ball joint shims |
| Members Technical Staff | Re: 2WD Strut Spacer Kit 1-888-MAXX-CAM. lol
__________________ 2005 Z71 LS Crew Cab 4X4 L52, 4L60E, GT4, Silver Birch Metallic, Amsoil Synthetics, SFAN4500, SSK Black Chrome Shifter MAXX Shackles: Click Here! MAXX Cam JR Lift Kit for 4X4 & 2WD Z71: Click Here! MAXX Stak Lift Kit for 2WD: Click Here! PerforMAXX Body Lift: Click Here! |
| Nation Elite | Re: 2WD Strut Spacer Kit whats the lift??? |
| Members Technical Staff | Re: 2WD Strut Spacer Kit Update: Just wanted to pass along some info from Larry. The aluminum spacer by itself will give you 1.75" of lift. If you add 1 shim to it you will get a bit over 2"; adding both shims to the spacer gives you close to 2.5". When Larry did the test fit on WhoaShutItDowns truck, he did some experimenting. Initially, he used just the aluminum spacer. Once it is fastened to the top of the strut, you have to spin the strut before you reinstall it. The bottom spring seat has an alignment nipple sticking out that would hit on the bump stop. Larry carefully ground off the nipple and got the strut assembly to pass the bump stop. So if a customer decides that 1.75" of lift is enough, all he/she would need to do is grind off the nipple. No grinding on the bump stop mount is necessary. Grinding the bumpstop would only be required if one or both shims were used with the spacer. He still owes me a 'members only' price. Should have a dollar figure in the next few days.
| Members Technical Staff | 2WD Strut Spacer Kit (Updated 22 Aug) New Part Numbers The part number for the spacer kit hasn't changed. Larry added new part numbers for the ball joint spacers and bump stop extensions.
__________________ 2005 Z71 LS Crew Cab 4X4 L52, 4L60E, GT4, Silver Birch Metallic, Amsoil Synthetics, SFAN4500, SSK Black Chrome Shifter MAXX Shackles: Click Here! MAXX Cam JR Lift Kit for 4X4 & 2WD Z71: Click Here! MAXX Stak Lift Kit for 2WD: Click Here! PerforMAXX Body Lift: Click Here! Last edited by ssgjurista; 08-22-2009 at 11:38 AM. |
| MTS | Re: 2WD Strut Spacer Kit (Updated 22 Aug) New Part Numbers Those look exactly like adamB's and the SSR designs Last edited by captainrab; 08-22-2009 at 02:50 PM. |
| Members Technical Staff | Re: 2WD Strut Spacer Kit (Updated 22 Aug) New Part Numbers That's because AdamB was kind enough to give Larry design specs and photos.
| MTS | Re: 2WD Strut Spacer Kit (Updated 22 Aug) New Part Numbers |
| Members Technical Staff | Re: 2WD Strut Spacer Kit (Updated 22 Aug) New Part Numbers AdamB's help saved a lot of time in getting the kit to market.
| Nation Affiliate Join Date: May 2009 Location: Greens Fork, IN
| Re: 2WD Strut Spacer Kit (Updated 22 Aug) New Part Numbers Looks good Scott. I'm glad I could help. |
| Nation Affiliate Join Date: Jul 2009 Location: Wichita Falls, TX
| Re: 2WD Strut Spacer Kit (Updated 22 Aug) New Part Numbers is there a how to on this? |
| Nation Elite | Re: Welcome to Suspension Maxx pics after the install ![]() ![]() ![]() ![]() 2.5" with shims. |
| Members Technical Staff | Re: 2WD Strut Spacer Kit with Part Numbers Thanks for the pics. Now you need to lift the rear.
| Nation Elite | Re: 2WD Strut Spacer Kit with Part Numbers oh i can do that !! i also still need to order the balljoint spacers .. LOL i forgot to order them . been soo busy with working this week. i dont have much time! but i can raise it when i go to the gasstation and get free air :P (airshocks ftw) also yes i need AAL but i dont want the rake. |
| | #17 | |
| Members Technical Staff | Re: 2WD Strut Spacer Kit with Part Numbers Quote:
![]() BTW: When you get a chance, go to the SM website and submit a photo of your truck to the photo gallery. Let me know if you do so I can make sure it gets uploaded.
__________________ 2005 Z71 LS Crew Cab 4X4 L52, 4L60E, GT4, Silver Birch Metallic, Amsoil Synthetics, SFAN4500, SSK Black Chrome Shifter MAXX Shackles: Click Here! MAXX Cam JR Lift Kit for 4X4 & 2WD Z71: Click Here! MAXX Stak Lift Kit for 2WD: Click Here! PerforMAXX Body Lift: Click Here! | |
| Nation Elite | Re: 2WD Strut Spacer Kit with Part Numbers alright i will do !! i think if its nice out thursday i might go to the park and take some new pictures with my camera. |
| Re: 2WD Strut Spacer Kit with Part Numbers how long did it take you to install the spacers? and how hard was it? hopefully i can get them in and shackles with time left to get tires put on this friday as long as my SMAXX package arrives |
| Nation Elite | Re: 2WD Strut Spacer Kit with Part Numbers Well first time 2hours then a day later i wanted to go more and put the shims in, cutting took like 15 mins and id say 4 hours max . |
