Wheel/Rim and Lug Nut Specs - Chevrolet Colorado & GMC Canyon Forum
LinkBack (9) Thread Tools Search this Thread Display Modes
Old 11-06-2008, 05:12 PM   9 links from elsewhere to this Post. Click to view. #1
Quadruple O.G.
355 O.G.  TOTM Winner  Nation Elite  Contributing Member  Nation Advocate  Calendar Spread  355 Celebrity  NESM 08  NESM 09
brewer15650's Avatar
Bolt Pattern and Bore Size
  • (all) - 6x139.7 or 6x5.5 and the Hub Bore Size is 100.3
Factory Wheel Specs
  • 2004-08 Z85 Steel Wheels 15 x 6 Offset ?
  • 2009+ Z85 Steel Wheels 16 x 6 Offset +23mm
  • 2004-08 Z85 Alum Wheels 15 x 6.5 Offset +23mm
  • 2009+ Z85 Alum Wheels 16 x ? Offset = ?
  • 2004-08 Z71 Alum Wheels 15 x 7 Offset +33mm
  • 2009+ Z71 17 x 7 Offset +33mm
  • ZQ8 "Sport" Alum Wheels 17 x 8 Offset +28mm
  • Xtreme(zq8) Alum Wheels 18 x 8 Offset +28mm
  • Hummer H3 Wheels 16 x 7.5 Offset +38mm
  • In 2009 Gm went to a larger caliper/rotor and inturn you can not run anything smaller than a 16" wheel in the front.
Lug Nut Specs
  • 12mm x 1.5
  • 3/4 hex or 13/16
  • Bulge Cone Seat
  • 60 Degree Taper
Web Site's
MY Album SINSITY KUSTOMZ Steel Rivers 355 yo!
brewer15650 is offline   Reply With Quote
Old 11-06-2008, 05:20 PM   #2
355 O.G.  Chapter Founder  TOTM Winner  Nation Elite  OG Lifetime Contributing Member  How-To CM
dlucas's Avatar
Re: Wheel/Rim and Lug Nut Specs
You are TEH MAN!!!!!
Contributing members get more!! Special forum, Green Name, Free Signature Banner....
i hate people that cant leav thier truck alone.
dlucas is offline   Reply With Quote
Old 11-06-2008, 05:38 PM   #3
355 O.G.  Chapter Founder  TOTM Winner  Nation Elite  How-To CM  Calendar Spread  355 Celebrity  WCSM 09  WCSM 10
rrcn's Avatar
PERFECT TIMING!
Just yesterday I was trying to find the lug specs for these things.
Thanks Brewer!!
My Cardomain -- SoCal355.com
rrcn is offline   Reply With Quote
Old 11-07-2008, 07:22 AM   #4
weez's Avatar
Just thought i'd add this info for you. The offset on the z85 alum. wheel is 23mm. It's stamped right under the center cap on my wheel and i believe the zq8 wheel offset is 27mm.
weez is offline   Reply With Quote
Old 11-07-2008, 09:04 AM   #5
Quadruple O.G.
Cool thanks...Im going to check my steel z85 wheels and the zq8's this weekend. So that leaves the z71, xtreme and h3 wheel offsets that we need
Old 11-07-2008, 10:48 AM   #6
Military Service  Public Service
05VictoryZQ8's Avatar
I think the midge said the H3s are +38
05VictoryZQ8 is offline   Reply With Quote
Old 11-07-2008, 11:34 AM   #7
\_(ツ)_/
355 O.G.  Nation Elite  OG Lifetime Contributing Member  Nation Advocate
brakenit's Avatar
H3's are 16x7.5 +38
ZQ8's are 17x8 +28
I think there are two different offsets for the Z85 wheels, one for 2wd and one for 4wd. Hub bore for all wheels is 100.3mm.
If money is your hope for independance you will never have it. The only real security that a man will have in this world is a reserve of knowledge, experience, and ability. - Henry Ford
brakenit is offline   Reply With Quote
Old 11-07-2008, 11:37 AM   #8
355 O.G.  Contributing Member  How-To CM  Nation Advocate  Public Service  NESM 09
rangerbob's Avatar
Send a message via AIM to rangerbob
Z71 wheel is +33mm offset. The Z71 are also 15x7 not 15x6.5
05 Canyon EC SLE - I5M Z71 4x4 GT4 25 Aug - 126k miles
LED + HAW Strobes | Fold-A-Cover | Line-X OTR | Goodmark Cowl Hood | GP Seats
1.5TB/2.5AAL/1BL/.5Diff Drop | RS5300/MA764 Shocks | Bubaloo Skidz | BFG 33-12.5-15 AT/KO
1st Cat Delete | MBRP 409 Turndown | FRAM Boost+RamAir | 3 x Lightforce Blitz | eFan | Tune by Gerry <- Awesome!!!
rangerbob is offline   Reply With Quote
Old 11-07-2008, 11:52 AM   #9
Quadruple O.G.
Updated thanks guys. Ill get the steel wheel offset tonight
Old 11-07-2008, 11:55 AM   #10
Ok I went out to the garage and looked at my spare Xtreme wheel.
18x8 +28 offset
Jeremy
Old 11-07-2008, 12:01 PM   #11
Quadruple O.G.
Thanks Jeremy you da man!
Old 11-07-2008, 12:05 PM   #12
rangerbob's Avatar
Are you looking for just stock wheel specs?
Old 11-07-2008, 12:11 PM   #13
Quadruple O.G.
pretty much. I dont want to go into the aftermarket stuff at all.
Old 11-07-2008, 12:58 PM   #14
firme021's Avatar
thanks brewer! this helps alot!
04 Colorado Crew Cab Z85
firme021 is offline   Reply With Quote
Old 12-30-2008, 07:15 PM   #15
shawnboy's Avatar
Send a message via AIM to shawnboy
what about a 8.5inch rim with a +20 offset?? will that work?
shawnboy is offline   Reply With Quote
Old 12-30-2008, 07:45 PM   #16
5cylinder and Tire slayer
TOTM Winner  Nation Elite  Contributing Member  How-To CM  Nation Advocate  Calendar Spread  355Loyalty  100K  NESM 09  SESM 10  MESM 10  MESM 11
WTRacing's Avatar
PM norcalSS..
he is Gooooooood with wheel and tire set ups
-Tribo
RIP SC
RIP Skitz
"Only the Good die young"
1997 S10 ZQ8 /2.2 5-Speed
2004 Colorado ZQ8 /3.5/3.7/3.5 Auto (Totaled 10-6-2011...RIPieces)
2004 Colorado ZQ8 /LSX/T56
2006 SRT8 300C
WTRacing is offline   Reply With Quote
Old 12-30-2008, 10:10 PM   #17
justintime_3's Avatar
Okay Stupid question. What is the BACKSPACING on the stock Z85 and the H3 wheels then?
04 Colly CC 4x4 Z85 4 inch Skyjacker lift with 20 inch Liquid Metal wheels and 32 inch Cooper Zeon LTZ
justintime_3 is offline   Reply With Quote
Old 12-30-2008, 10:23 PM   #18
rabblerouser's Avatar
Send a message via AIM to rabblerouser
on the z85 alum wheels back spacing is 4.15"
h3 wheels are 5.24"
That is IF my math is correct, and the +mm means it moves towards the outer edge of the rim like i think it means.
How i found those. (z85 as example)
6.5" wide. 6.5/2= dead center of rim in inches (3.25) 3.25x25.4=convert to mm (82.55) 82.55+23= offset (to outside?)(105.55) 105.55/25.4=convert back to inches (4.15)
rabblerouser is offline   Reply With Quote
Old 02-06-2009, 01:03 PM   #19
Make7upyours728's Avatar
what about stock tire sizes for z85's and z71's
Make7upyours728 is offline   Reply With Quote
Old 02-06-2009, 01:08 PM   #20
Thanks man, holy old thread.
Tires sizes to be added:
Xtreme factory tires- 235/50/18 Goodyear Eagle RS-A
ZQ8 Sport model tires- 235/50/17 Continetals, model?
chevrolet colorado , extreme , gmc canyon , oem wheel specs , z71 , z85 , zq8
LinkBack to this Thread: http://www.355nation.net/forum/wheels-tires/12889-wheel-rim-lug-nut-specs.html
Steel wheels to Z71 wheels - Chevy Colorado & GMC Canyon This thread Refback 02-03-2016 03:53 PM
lug nut - Chevy Colorado & GMC Canyon This thread Refback 12-23-2015 06:41 PM
18" Colorado Xtreme Wheels for sale on ebay - Chevy Colorado & GMC Canyon This thread Refback 10-09-2015 03:10 PM
Gmc Envoy Lug Nut Torque This thread Refback 08-22-2015 04:07 PM
Steel wheels to Z71 wheels - Chevy Colorado & GMC Canyon This thread Refback 09-06-2014 07:18 PM
lug nut - Chevy Colorado & GMC Canyon This thread Refback 01-12-2012 06:51 PM
Wheel/Rim and Lug Nut Specs - Chevrolet Colorado & GMC Canyon Forum This thread Refback 03-19-2011 02:09 PM
Chevy Colorado & GMC Canyon &bull; View topic - lug nut This thread Refback 03-10-2010 05:08 PM
Chevy Colorado & GMC Canyon &bull; View topic - lug nut This thread Refback 06-24-2009 06:23 PM
