| New To The Nation Join Date: Jan 2010 Location: Houston, Texas, USA, Earth, Orion Arm, Milky Way
| Tire size for H3 wheels... I did a search and couldn't find what I was looking for. What size tire are y'all with H3 rims running? I have a '04 Z71 w/ no lift (for now) on stock 15" and 31/10.5/15 (265/75 comparable size) and just scored a set of H3's 16"ers off CraigsList. According to my favorite tire/wheel calculator, 265/70/16 are close enough to stock size (-.02%) as to not have to re-calibrate the speedometer. I could also fit a 265/75, but re-calibrate would (for me) be required. A minor pain but not a deal killer. 285/75 are also available on the H3, but I'm not sure of clearance. Also, with the H3's .05mm more backspacing, does anyone have any rubbing issues? Thanks in advance. Jim
__________________ 1994 Правительство моторы конструкторское бюро Camaro B4C driveway sculpture 2004 Правительство моторы конструкторское бюро Colorado Z71 Crew Cab I love my carbon footprint |
| Custom Title Garnered | Re: Tire size for H3 wheels... the H3 wheels look sweet on these trucks. id like to have a CC z71 v8 with some in the future. the wheel and tires you want will fit good with no rubbing.
| Nation Elite | Re: Tire size for H3 wheels... i put 265/70r17 same as the 265/75r16 and my speedometer wasn't of more than 1 mpg ever
__________________ Suspension Maxx keys, 17" MB Gunner 6 wrapped in 285/70r17 Remington Mud Brute, Brute force intake, Jensen touchscreen flip out, MA audio components, 10" RE SX. |
| Nation Affiliate | Re: Tire size for H3 wheels... I use 265/75/16 tires. You will fit, but be prepared for them to just slightly rub on the sway bar at full lock. The rubbing is very minor and just takes the black paint off the sway bar. To fit the 285s you would have to be lifted and/or a body lift to clear. FMRJPR has/had 285s on H3s a while back.
__________________ Adam 2006 Canyon Crew Cab "Off-Road" 2000 Mazda Protege ES 1.8 - Daily Beater "Slotege" |
| | #5 | |
| Re: Tire size for H3 wheels... Quote:
That was the info I needed. Thanks. J
__________________ 1994 Правительство моторы конструкторское бюро Camaro B4C driveway sculpture 2004 Правительство моторы конструкторское бюро Colorado Z71 Crew Cab I love my carbon footprint Last edited by FS-320; 03-20-2010 at 03:51 PM. | |
| Nation Affiliate | Re: Tire size for H3 wheels... Vt canyon are you lifted at all |
| Nation Affiliate | Re: Tire size for H3 wheels... i am, 2" tb crank & shackle lift
