Will 265/75 16 fit on stock 2wd z85? - Chevrolet Colorado & GMC Canyon Forum
Old 06-13-2010, 04:23 PM   #1
Found a set of hummer h3 rims and have a stock z85 2wd and wanted to know if a 265/75 16 will fit with no rubbing.
deminitrucker is offline   Reply With Quote
Old 06-13-2010, 04:31 PM   #2
KC 350's Avatar
Re: Will 265/75 16 fit on stock 2wd z85?
They will fit but the tires will most likely rub when turning full lock on the frame and swaybar.
Heres a couple of pics of my truck with that tire size. I'm pretty sure these wheels have the same offset as h3 wheels.
KC 350 is offline   Reply With Quote
Old 06-13-2010, 04:33 PM   #3
Is your truck a stock z85 with no suspension mods, and what kind of mpg are you getting
Old 06-13-2010, 04:38 PM   #4
KC 350's Avatar
Yeah its a z85 and in those pics the suspension was completely stock. I'm not really sure how many mpg i got when i had those wheels on. I just put them on there for a couple weeks to see how they fit. But there definitely wasn't a huge difference that i noticed
Old 06-13-2010, 04:44 PM   #5
How was the ride and stuff, anything you didnt like about them and about how much higher did your turck sit. Thanks
Old 06-13-2010, 04:55 PM   #6
KC 350's Avatar
Well since those wheels were off a silverado(the green one beside it), the center bore wasn't big enough to fit around the hub.
If I was going to keep those wheels on there, i would have bored out the center to fit.
The ride was kinda bumpy because the wheels weren't bolted completey flat to the hub.
But with the h3 wheels, you should be good.
i had about 2 more inches of ground clearance. the bigger tires were 32" and my stock tires are only 28"
Old 06-13-2010, 04:59 PM   #7
Thanks, the rims I found are $150 for 5 with center caps and tmps, i dont konw if i want to run that tire size might step it down to like a 245/75 or 235/75
Old 06-13-2010, 09:22 PM   #8
Anyone else have any insite on this?
Old 06-13-2010, 09:31 PM   #9
355 O.G.  Nation Elite  Contributing Member  How-To CM  355Loyalty  NESM 11
lkout4trucks's Avatar
they are prob gonna rub some. your 2wd so just pick up some tacoma spacers and do shackles or aals out back? also what gears do you have? if they are 3.42s prepare to loose some serious city mpgs. highway wont be bad though.
05 Chevy Canyon (no I'm not stating the name wrong) - Traded In, apparently never to be seen again...
08 Trailblazer SS awd - the new hawtness.
Northeast members be sure to check out our local site: www.NEC355.net
lkout4trucks is offline   Reply With Quote
Old 06-13-2010, 09:37 PM   #10
um i know i have the g80 locker
Old 06-13-2010, 10:02 PM   #11
Purple Heart  Military Service
awp101's Avatar
Location: The nurturing biosphere of the Mothership aka TX
Question Re: Will 265/75 16 fit on stock 2wd z85?
Why Tacoma spacers?
Make yourself an honest man, and then you may be sure that there is one less scoundrel in the world. - Thomas Carlyle
Sometimes when I'm bored, I like to text "I hid the body, now what?" to a random phone number...
Nothing so needs reforming as other people's habits. - Mark Twain
Spell Check: It's your friend
When I dance with wolves, it's usually the Tango
awp101 is offline   Reply With Quote
Old 06-14-2010, 01:40 AM   #12
355Loyalty  SCSM 2013
peanutbuttersports's Avatar
i have 24/70R16 on my truck with AR Rims not sure the mesure emnts
but its pretty tight
i have a Z85 stock
TOTALED AND JUNKED: '06 Canyon 2WD Z85 3.5L Crew Cab
Front: CST 5" Spindles FOA Coil-overs w/ reservoir, Eibach Coils Sick and Dirty Stage 3 Kit Plus Coil-over Mounts
Rear: Skyjacker 4" Packs with Rancho Shocks on Stock Shackles
Rim/Tire: Summit D Window 285-75-16 BFG AT TKO
Stored : Stock Spindles, Stock Coils, American Racing 629's, 2 inch shackles, , bump stop spacers
peanutbuttersports is offline   Reply With Quote
Old 06-14-2010, 12:40 PM   #13
Originally Posted by awp101 View Post
Why Tacoma spacers?
maybe you prefer lift springs? LOL spacers are an easy way to get a lift that maintains decent ride quality.
Old 06-14-2010, 01:20 PM   #14
awp101's Avatar
Let me rephrase...why spacers for Tacomas? Are they better/cheaper than ones for Colorados?
Old 06-17-2010, 03:32 PM   #15
Military Service  Contributing Member
bradtw191's Avatar
i am the perfect person for this question. i have H3's with a 2.5" lift on a 2wd Z85 and 245/75/16's. i rub on the sway bar and fram but it doesnt bother me. the downside to H3s is the backspacing, thats why we rub with them
bradtw191 is offline   Reply With Quote
Old 06-17-2010, 03:34 PM   #16
bradtw191's Avatar
its all the same people just call them tacoma spacers cause thats where the original idea came from
