5 Lug conversion... Project pics inside - Page 10 - Chevrolet Colorado & GMC Canyon Forum
Go Back   Chevrolet Colorado & GMC Canyon Forum > Tech Area > Chassis > Wheels & Tires
LinkBack (3) Thread Tools Search this Thread Display Modes
Old 12-02-2012, 10:15 PM   #181
Darth Vader
TOTM Winner Nation Elite Lifetime Contributing Member How-To CM Calendar Spread 100K
BlackZQ8's Avatar
Re: 5 Lug conversion... Project pics inside
I can't wait to see it with the Xtreme kit....
Scott--- Carolina Chapter - -Capital 355
BlackZQ8 is offline   Reply With Quote
Old 12-02-2012, 10:21 PM   #182
5cylinder and Tire slayer
TOTM Winner Nation Elite Contributing Member How-To CM Nation Advocate Calendar Spread 355Loyalty 100K NESM 09 SESM 10 MESM 10 MESM 11
WTRacing's Avatar
cant wait to see how this all turns out when you get your concerns worked out and alignment where you want.. love this thread
-Tribo
RIP SC
RIP Skitz
"Only the Good die young"
1997 S10 ZQ8 /2.2 5-Speed
2004 Colorado ZQ8 /3.5/3.7/3.5 Auto (Totaled 10-6-2011...RIPieces)
2004 Colorado ZQ8 /LSX/T56
WTRacing is offline   Reply With Quote
Old 12-03-2012, 05:01 PM   #183
Thanks for the kind words guys.
Update:
Looks like my ABS issue was a bad wheel speed sensor. I hooked up a tech 2 to the truck and saw that one of the new wheel sensor/hubs is "lazy". At very low speeds it drops out to 0 mph randomly from a 3 to 5 mph roll. Every where else it is fine. I have seen this before... no biggie, just have to replace it.
I am going to swap the hubs from left to right just to make sure that the problem follows the hub.
Then onto the next issue.
Later,
Max
WideOpenThrottle is offline   Reply With Quote
Old 12-11-2012, 12:52 PM   #184
Calendar Spread NESM 10
07NJrado's Avatar
just read the entire thread, impressive work man!!! Can't wait to see get it all squared away. I would love to do this as well, need to win the lottery lol.
Andrew
07NJrado is offline   Reply With Quote
Old 12-11-2012, 08:17 PM   #185
SCSM2012
Originally Posted by WideOpenThrottle View Post
Just a couple of quick pics outside the alignment shop...
I will get hopefully some better pics when the time permits.
Max
Max, is this the final stance your looking at? Just finished mine. Measurement taken front frame rail bottom to ground is 7.5 inches and rear frame rail bottom is 14 inches (with out bed) weight. Rear i used 1.5 aluminum block. All measurements taken at end of frame.
no friends at 200mph is offline   Reply With Quote
Old 12-11-2012, 10:21 PM   #186
Spoolin Jr. Survivor
Nation Elite 355 Celebrity USASM2012 TXSM 10
emaxxer's Avatar
Holy crap! How did I miss this?!!!! My truck is in dire need of a brake upgrade! I could care less about abs if I had stupid powerful brakes! It would be more like a road coarse truck which would be beautiful with a Colorado or canyon!!! Keep up the awesome work!!!
Mike B's 08 Colorado LT Z85 regular cab 3.7L auto 3.73 G80
e85 + 61mm
emaxxer is offline   Reply With Quote
Old 12-17-2012, 11:29 PM   #187
mannysirianni's Avatar
this thread cant die.... it must live onnnnnn
mannysirianni is online now   Reply With Quote
Old 12-18-2012, 12:22 AM   #188
Pretty much the final stance. If I go any lower I think I will just hit everything, plus the suspension geometry is right at that ride height.
I have 2" blocks in the rear along with the 3" drop leafs from Belltech.
It's pretty low.
Old 12-18-2012, 12:34 AM   #189
Replaced wheel hub assembly... It got rid of the 95% of the false ABS issue. Still happens every once in a while. So I am looking into the signal generated by each sensor type and see what the difference is now. The frequency/speed output is the same on both units, so it's probably an amplitude thing.
Redesigned the upper ball joint adapter in CAD and then I just have to make it and install. This will give me the caster that I want and get rid of the tram-lining/darty feeling it has at certain speeds & road conditions.
Sorry for the delays... it's the holidays and I have got tons of family in town for my Daughter's baptism now and have lots of great things planned for the next little bit (none of which involve my truck though). So it may be a a couple of weeks before I make any changes... but I will keep the post updated as I go on.
Getting closer
Old 12-18-2012, 12:38 AM   #190
WTRacing's Avatar
so will the upper ball joint also fix the bumps steer?
-Tribo
RIP SC
RIP Skitz
Old 12-18-2012, 12:48 AM   #191
Darth Vader
BlackZQ8's Avatar
I love updates in this thread
Old 12-18-2012, 10:59 AM   #192
Military Service Nation Elite Contributing Member How-To CM
Freewood's Avatar
Send a message via Yahoo to Freewood
You possess immense talent! This thread is too cool and had me geeking through all 10 pages today.
_._._.._____
.. _____|___\_____
. |_(O)_|____/_(O)|
Freewood is offline   Reply With Quote
Old 12-18-2012, 11:33 AM   #193
No it won't. But from driving it around "seat of the pants" it really feels like it just needs more caster. Just going to change one thing at a time.
A 100% true fix for the bump steer will require moving the rack or custom adapters at the knuckle... to get it 100% right. It's not too far off now... so I really believe caster is my issue at the moment.
Old 01-08-2013, 07:53 PM   #194
Update:
So it was caster... Increased it and the problem went away, well, 95% of it. The rest I think is just the wide tires just following the road. Have to take it for a re-alignment to see how much I actually added, by some crude math I added about 3 to 4 degrees giving me a total of about 8 to 8.5 degrees of caster.
ABS issue, remains. Did some more research on the situation. As it turns out it seems that the 355 uses an active wheel sensor up front. Not 100% sure yet. I do know that the Vette is passive and requires no power. The 355 uses power to the sensor and uses a square current wave to generate the frequency related to speed signal. If anyone has the circuit schematic for this is would be appreciated. I am away on business for 2 weeks and when I get back I plan on hooking up my buddies Colorado to an oscilloscope and take some reading at a few points and see if an educated guess can be made at what the signal is suppose to look like on the output side of the sensor. From there a signal converter has to be made... not fun... but necessary it seems. Maybe someone has some extra info on this? Considering everything, it's amazing it only has issues at low speeds, maybe I am leaving something on the table, which would be ultra impressive considering how well it stops now. Feels like some one drops an anchor out of the bed when I step on the brake pedal now.
Still, have to hook up the E-brake... I will get to that soon, no rush as in it didn't work well before any ways.
Max
Old 01-09-2013, 12:58 AM   #195
WTRacing's Avatar
love these updates and damn you getting surgical on this shit, love it man!!
-Tribo
RIP SC
RIP Skitz
Old 01-10-2013, 10:03 PM   #196
WTRacing's Avatar
In for pics of the Colorado doing this
-Tribo
RIP SC
RIP Skitz
Old 01-10-2013, 11:09 PM   #197
trailkiller91's Avatar
Ive seen an s10 do that before, only thing is though he rear ended a logging truck to do it
trailkiller91 is offline   Reply With Quote
Old 01-11-2013, 01:24 AM   #198
07_codeX's Avatar
WTRacing- when i was going through the thread i notice how you put 285 on the back of your zq8 and 275 on the front and was wondering do you think i would be able to put those sizes on my xtreme? im worried that might rub on the flares and just wondering how tight were they are your truck?
07_codeX is offline   Reply With Quote
Old 01-14-2013, 12:15 PM   #199
LOL. That picture must have come right after a speed bump/ramp that is not in the picture...
Old 01-21-2013, 10:02 PM   #200
I want this setup! Please, please offer the custom parts for us!
2004 Chevrolet Colorado ZQ8 Ext. Cab I5/A4- Belltech 2/2 l Volant l HP Tuners
1991 Pontiac Trans Am L98/T56- SLP l Doug's l Flowmaster l Bassani l Corbeau l Spec l TrueForged l Nitto l Pro 5.0
A CFans convert.
SlowTA is offline   Reply With Quote
LinkBack to this Thread: http://www.355nation.net/forum/wheels-tires/56974-5-lug-conversion-project-pics-inside.html
6 lug swap? This thread Refback 03-26-2013 09:43 PM
6 lug swap? This thread Refback 03-26-2013 01:17 AM
6 lug swap? This thread Refback 03-25-2013 11:20 PM
