Biggest fit tire under stock z71 susp?? - Chevrolet Colorado & GMC Canyon Forum
Go Back   Chevrolet Colorado & GMC Canyon Forum > Tech Area > Chassis > Wheels & Tires
Old 09-18-2012, 01:04 PM   1 links from elsewhere to this Post. Click to view. #1
Public Service
FDlou961's Avatar
Well, the canyon is gonna need tires soon and well I was trying to figure out what size I can fit under stock. I'm was gonna tbar crank the front and shackle the rear to get me 2in but i want to explore both what sizes fit under stock with the 15s and lifted with the 15's.
-Lou
Vol.Firefighter-New Paltz FD(in NY)
2005 Z71 Canyon-SLE trim-107K and counting!
Headlamp Hi/Low mod, Line-X bedliner, BackRack, Toolbox, Custom switchbox, FS Streethawk
R.I.P Skitz 6/20/84-6/27/11
FDlou961 is offline   Reply With Quote
Old 09-18-2012, 03:27 PM   #2
I Vanquish Boredom
CanyonAB's Avatar
Re: Biggest fit tire under stock z71 susp??
If you don't want to rub get some 32x10.5" tires...you might get a tad of rubbing when wheeling on 32x10.5 or 33x10.5, but with the right offset you should clear those on the street without rubbing.
http://www.355nation.net/forum/attachments/contributing-members-only/21930d1284138281-cms-get-your-custom-sigs-here-canyonab-sig-copy.jpg
Daily Driver --> 2005 GMC Canyon Crew Cab 4X4 Z71, LOTS of mods
Weekend Driver --> 1964 Impala Convertible, almost original
Offroad Toy --> 1977 K5 Blazer, mods coming soon
CanyonAB is offline   Reply With Quote
Old 09-18-2012, 06:55 PM   #3
i dunno man i have 31" 10.5 with my 2" tb crank and i rub on my sway bar with stock rims. depends how saggy ur tbs are though, seeing as u have an 05 with 107k+ on it which is around where my truck sits i think you would rub.
i did however have no rubbing before i cranked my TB
Bman11 is online now   Reply With Quote
Old 09-18-2012, 07:22 PM   #4
How-To CM USASM2012
gway's Avatar
You can fit 33x1050's without rubbing too bad. Most you'll probably rub is the sway bar at full lock. I'd say stick with 31x1050's and you'll be good.
SASed with a dana 44 front/14 bolt sf rear, 4.88 gears with a eaton tru trac, 37" cooper discoverer stt's on dick cepek dc2 17x9 wheels, 47" chevy springs with 4" lift and stock 52" rear chevy leafs, Bilstein 5125 shocks, custom winch bumper with smittybilt x20 10k winch. Soon to come: 4l60e auto swap, a Dana 300, and a little secret for the engine.
gway is offline   Reply With Quote
Old 09-18-2012, 07:38 PM   #5
Nipple
Purple Heart Nation Elite Lifetime Contributing Member Calendar Spread 100K USASM2012
wh1pple's Avatar
Send a message via Skype™ to wh1pple
Define fit....
VVV Are You Lifted or Lowered? Haven't Posted Your Data Yet? Do It Now! VVV
>>>Lifted Data<<<
>>>Lowered Data<<<
wh1pple is offline   Reply With Quote
Old 09-18-2012, 07:44 PM   #6
TOTM Winner Lifetime Contributing Member How-To CM Calendar Spread USASM2012
GregDAP's Avatar
You're rubbing the sway bar because your torsion bars are cranked... it pulls the front wheels in closer to the frame
Sent from my LG-P999 using AutoGuide.Com Free App
2011 Colorado Z71 2LT 4WD Crew Cab 3.7L with some mods
PCM tuned by Justin @ Black Bear Performance
GregDAP is offline   Reply With Quote
Old 09-18-2012, 11:39 PM   #7
I understand that. He said he was thinking of possibly cranking his tb so I was just telling him my experience with a similar age and mile truck. And i also stated that i did not have any issue before cranking my tb.
"I'm was gonna tbar crank the front and shackle the rear to get me 2in but i want to explore both what sizes fit under stock with the 15s and lifted with the 15's."
Old 09-19-2012, 12:03 AM   #8
I Vanquish Boredom
CanyonAB's Avatar
It depends mostly on the offset of the wheels though...not all wheels stick out the same amount. You have to factor in the front suspension being a bit narrower after a TB crank. My factory 31x10.5 tires grazed the swaybar a tiny bit after the TB crank (2.5") where my 32x10.5 KM2's had lots of room to spare. All in the wheel offset. Wheel spacers can fix the narrower stance after a TB crank.
Old 09-19-2012, 12:46 AM   #9
Sounds like he is using stock rims as am I.
Old 09-19-2012, 01:07 AM   #10
Hooray! A shouting match.
Old 09-19-2012, 03:33 PM   #11
I Vanquish Boredom
CanyonAB's Avatar
And at the end of my last post I said that wheel spacers can stop that, allowing bigger tires to clear with stock rims after a TB crank than without.
Old 09-19-2012, 04:10 PM   #12
Super Hated
TOTM Winner Nation Elite OG Lifetime Contributing Member How-To CM Calendar Spread 355 Celebrity 355Loyalty 100K USASM2012 WCSM 10
dents-n-dings's Avatar
You'll fit 44's all day.....with a sawzall
Originally Posted by royrjs View Post
Bitches love gear swaps.
.................................................. .............................BBB crew...all day, every day.
dents-n-dings is offline   Reply With Quote
Old 09-19-2012, 05:06 PM   #13
BCS
BCS's Avatar
Stock 31's.
2" lift 32 x 11.50.
Done.
2005 Z71 2WD. 2" TB Crank, 2 " Shackles, 3" Body Lift. 285 75 16 Cooper STT's, 16" MB Chaos 6 Wheels
BCS is offline   Reply With Quote
Old 09-19-2012, 05:38 PM   #14
jmw2005's Avatar
I had the same question as Lou altough mine is already lifted with the 2.5" crank and 2" shackles. This thread is pretty confusing with all the back and forth, so will 32x11.5 work since you can't get 32x10.50 in a 15" stock rim, or do you need to get spacers? . Or are you stuck getting new rims with less backspace.
jmw2005 is offline   Reply With Quote
Old 09-19-2012, 05:47 PM   #15
Matte white rado!
Chapter Founder Nation Elite Lifetime Contributing Member How-To CM Calendar Spread 355 Celebrity MTS
Optrix's Avatar
Remember with spacers, you stick the tires out further, they are going to rub on other places.
Mines a 3 in TB crank with 31.5 tires with 15mm offset and it rubbed on the sway bar still
From Arizona? Join the AZ355 Local Chapter!
Optrix is online now   Reply With Quote
Old 09-19-2012, 09:45 PM   #16
BCS
BCS's Avatar
It worked for me without spacers. Minor rubbing at full lock.
Old 09-20-2012, 01:42 PM   #17
Public Service
FDlou961's Avatar
So Bman you had 31's under stock susp? With no issues?
-Lou
Old 09-20-2012, 01:48 PM   #18
Bump, I'm staying stock on my suspension but am putting 31's on it next month.
Sent from my iPhone using AG Free
08 Canyon Z71 2wd CC- mostly stock for now...
Bull_head360 is offline   Reply With Quote
Old 09-20-2012, 04:27 PM   #19
jmw2005's Avatar
I am currently running 31x10.50 x 15s on my 4wd z71 with no problems w/ stock ride height
Old 09-20-2012, 10:37 PM   #20
Correct. Stock z71 4x4 with stock rims. 31"x10.5. No issues. Even now with my 2" lift the rubbing is very minor and only full lock to the right.
LinkBack to this Thread: http://www.355nation.net/forum/wheels-tires/58105-biggest-fit-tire-under-stock-z71-susp.html
32 inch tires fit on colorado?? - Chevy Colorado & GMC Canyon This thread Refback 12-06-2012 10:31 PM
