wheel rim wobble (bent) - Chevrolet Colorado & GMC Canyon Forum
Old 03-07-2013, 08:00 AM   #1
Recently put a set of steel wheels on my truck that I had and after noticing a light vibration around 50 mph I took it back in to the tire shop. Found out the wheel has a "wobble" to it on the inside while on the balancing machine. I am not sure if this is the hub center that is bent or the lip of the rim. The inside lip looked to wobble around 1/8 to 1/4 inch.
Does anyone have a DIY fix for this that I can try? It is a cheap set of rims so looking to try and straighten things up myself before buying new ones. All local tire shops say they cant fix it and rim repair shop costs are probably more than a new rim.
I've heard of applying pressure to the rim while still mounted to the truck to try and bend it but this seems like it may do damage to the rear end. Any thoughts?
Ricky_Graber is offline   Reply With Quote
Old 03-07-2013, 10:33 AM   #2
Nation Elite  Contributing Member
Re: wheel rim wobble (bent)
Can you send it back to the supplier for a replacement?
Old 03-07-2013, 10:54 AM   #3
CUZICAN's Avatar
Steel or aluminum? I have a 5 lb dead blow all nylon hammer and have used it on many aluminum wheels to straighten out a bent lip, u could probably get one for a decent price at harbor freight if you don't have one. If it's a steel wheel, just smack it with a hammer.
I'm a responsible adult, whenever anything goes wrong, I'm responsible.
Old 03-07-2013, 12:45 PM   #4
Nation Elite  Contributing Member  Calendar Spread  355Loyalty  100K
moody1's Avatar
Believe OP stated they were steelies.
moody1 is offline   Reply With Quote
Old 03-08-2013, 07:04 AM   #5
yep they are steel wheels...bought used and definately not able to send back to a retailer.
Also I don't think it is the lip that is bent, looks more like the hub of the rim in the center making the entire rim slightly bent. Not 100% sure but plan to check things out tonight or tomorrow.
I just wanted to see if using the frame for a push point with cylinder jack to bend the rim while mounted on the truck would destroy the hub, bearings or any other part of the rear end.
Old 03-08-2013, 07:14 AM   #6
Purple Heart  Contributing Member  How-To CM  Public Service  100K  USASM2012  USASM14
Black_Rado's Avatar
Not sure our hubs are made for withstanding major horziontal forces lol. I would take the tire off and find you a perfectly flat surface (counter tops) and start measuring to find exactly where its bent and how much. Then bring out the BFH.
But the jack is a good idea, i think the leafs would twist and make it difficult so put pressure then hit it on the opposite side of the jack
Black_Rado is offline   Reply With Quote
Old 03-08-2013, 09:54 AM   #7
CUZICAN's Avatar
If it's a warped steel wheel, you are going to have to replace it.
Old 03-08-2013, 04:03 PM   #8
Sounds like we know why the seller was selling. Could have hit a curb or something.
Old 03-08-2013, 04:23 PM   #9
Military Service  Contributing Member  355Loyalty
gbc43's Avatar
Free one if you want it .
2004 Canyon Z-71 Ext Cab SLE
3.5 auto 3.42 gear
Michigan 355
86,000 miles
gbc43 is offline   Reply With Quote
