So, for about a few weeks now, if I'm either in drive or neutral, my truck begins to dip well below 400rpms and spiking to around 800 - 1000. This problem is only occurring when I'm at a standstill for roughly 7-10 min and continues unless I either get on the gas and go, or keep it revved up. Again it only seems to occur after a good 7 min or so. I'm also getting a rough idle which I heard can be normal. I don't want it to turn into a serious problem so I'm looking deeper into the situation.
Here are the things I've done:
Cleaned the TB
Cleaned MAF
Cleaned air filter
Sea foamed twice over past few weeks
( Can't be bad gas)
My engine light is on so I can post the codes within the next day but, I plan on running sea foam through the intake, and also cleaning fuel injectors in hopes of fixing it. Which will happen a few days from now when I have time.
THANKS FOR ANY ADVICE!
Cleaned the TB
Cleaned MAF
Cleaned air filter
( Can't be bad gas)
