1 - 2 of 2 Posts
Hello. Im just a do it your selfer, give you a general run down. Bought a 05 3.5 canyon 300000 km from some one in toronto. Found it had a broken valve E valve on cylinder 3 bought couple new valves for Exhaust re seated cleaning. I have between 170 to 190 compression. I did balancer chain just chain and tensioner. I did timing chain insproket ,crank sproket , guides, tensioner. I did not do top guide and E actuator/ phaser sprocket. I blew the cam shaft actuator apart and put back together. Truck is running after i put back together. Im getting codes
Discussion Starter #2
340555
1 - 2 of 2 Posts
